Like Tree3Likes
Old 07-09-2013, 01:18 PM   #511
AdrianM's Avatar
Originally Posted by EricF View Post
Why level as opposed to angled?
E
Short answer:
The 12R5.2 is pretty awesome the way it is. There is no value in messing with this.
Longer answer:
Level tubes will put the least average side load on the inside of the tubes as the pod rotates and the tubes slide in any out of each other. This makes them more consistent and last longer between rebuilds.
It really doesn't make a big difference. I mean, you could change the angles and mounting points 1-2mm and the car will go around the track the same.
Performance won't change unless you move both inner and outer mounting points closer to or further away from the center pivot. This would reduce or increase the leverage and travel or sweep of the piston in the tube thereby making the tube provide more or less damping for the same given fluid in the tube. The friction characteristics of the system would also increase the resistance to sudden movement (off roaders call this "pack") as you get further away from the center pivot or vice versa.
Adrian Martinez
Old 07-10-2013, 07:08 AM   #512
H I
H I's Avatar
Trader Rating: 18 (100%+)
Great result for Team Associated last weekend at AOC round 2. In modified 12th scale 8 R5.2s made A-main and secured top 7 in finals, TQ & win by Factory driver Keven Hebert.
1. Keven Hebert(TQ) - Associated
2. Sandy Iavazzo - Associated
3. Darrin Campbell - Associated
4. Chris Hamilton - Associated
5. Andy Bishop - Associated
6. Hiroshi Ishizaki - Associated
7. Jordan Cullis - Associated
8. Michael Clark - CRC
9. Jason Ercegovic - Associated
10. Chris Kyriacou - Serpent
H I is offline   Reply With Quote
Old 07-14-2013, 11:26 AM   #513
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Originally Posted by AdrianM View Post
Short answer:
Longer answer:
The 12R5.2 is pretty sweet straight of the box. The only mod that is worthwhile is the soft chassis from Red Mosquito. Besides more flex it also shaved weight to get you closer to the min for 1/12.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 08-02-2013, 03:47 PM   #514
Wazza22's Avatar
Trader Rating: 21 (100%+)
Hi everyone,
I was hoping someone could tell me if the 12r5.1 rear top plate will fit onto the 12r5.2. I was wanting to try the shock instead of the damper tubes.
Cheers
Wazza22 is offline   Reply With Quote
Old 08-02-2013, 05:45 PM   #515
EricF's Avatar
Originally Posted by Wazza22 View Post
Hi everyone,
Cheers
Yes it fits.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 08-02-2013, 06:49 PM   #516
Wazza22's Avatar
Thank you!
Old 08-02-2013, 09:29 PM   #517
Originally Posted by dr_hfuhuhurr View Post
Modding the battery stays?
Looks like they dremeled off the battery stays off the top plates on the one side. Has anyone done this and any adverse effects?
What brand wheels are on the car?
RoyU is offline   Reply With Quote
Old 08-02-2013, 09:56 PM   #518
LonnyJ1950's Avatar
Don't recognize the fronts, the rears on the car look like Trinity/TRC, the ones on the bench are ULTIs.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 08-03-2013, 07:49 PM   #519
SRC_DRIVER's Avatar
Trader Rating: 60 (100%+)
Originally Posted by AMZ View Post
3 of us ran our 12r5.2's Fridaynight for the first time. Its a local short carpet track, 17.5 blinky.
These cars are tough, smooth , and planted! Really no bugs, shakedown cruise was great.
Only one thing came loose, one of the side dampeners popped off, snapped it right back on.
It seems to me that its not nearly as twitchy or darty as other 12th scale cars I drove. The whole car , especially the rear end feels very well planted.
Nice car!
PM Sent
www.Medlinracing.com
http://www.youtube.com/watch?v=VVIyGKSyAGg
SRC_DRIVER is offline   Reply With Quote
Old 08-03-2013, 08:01 PM   #520
SRC_DRIVER's Avatar
Front's are BSR Racing tires
Old 08-21-2013, 04:29 PM   #521
TeamCody's Avatar
I just picked up the 12R5.2 to try out. Thinking I will run it in 13.5 class at IIC to start out. Any setup tips or is this thing pretty much dialed out of the box?
Haven't started building it yet because I have a 1/10 project on my bench to get out of the way first, but it looks like a nice car.
"Its just a hobby!"... or so I'm told.
TeamCody is offline   Reply With Quote
Old 08-21-2013, 07:52 PM   #522
Trader Rating: 32 (100%+)
It's pretty good out of the box. I never run stiffer than silver side springs most times it's green or black. I most always use 10k in the side tubes and a protoform AMR body.
The car is a bit on the heavy side, I would recommend getting aluminum screws from fastener express.
I also cut a 2mm thick chassis for the 12r5.2. It saves 12 grams of total weight on the car. I still sell them if you are interested at a later point.
Monti
Monti is offline   Reply With Quote
Old 08-21-2013, 10:19 PM   #523
Trader Rating: 23 (100%+)
Monti
You keeping your 12r5 or trying the top rebel?
bmcallister is offline   Reply With Quote
Old 08-22-2013, 05:41 AM   #524
Mach10_shooter's Avatar
Trader Rating: 36 (100%+)
Check it out. This should also help to get the cars down to minimum!
http://www.hobbytalk.com/bbs1/showthread.php?t=400223
https://www.facebook.com/pages/CM-Mo...53713248085996
Mach10_shooter is offline   Reply With Quote
Old 08-22-2013, 06:03 AM   #525
Originally Posted by bmcallister View Post
Monti
I am going to run both of them for a bit.
Monti
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
