Like Tree19Likes
Old 04-29-2013, 07:42 AM   #451
Default servo
Futaba S9650 fits perfectly
RCvetran is offline   Reply With Quote
Old 04-29-2013, 08:56 AM   #452
EricF's Avatar
Originally Posted by HBRC-LBD View Post
What size servo fits in this car?
Pretty much any 'mini' servo. The chassis is slotted to allow for the different output horn location of the servo.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 04-29-2013, 09:12 AM   #453
AdrianM's Avatar
The Spektrum H5020G is probably the best pan car/mini servo currently available. It's digital, metal gear, plenty of torque and twice as fast as any of the other common servos. Its designed as a Heli tail servo which is a much tougher and precise application than r/c cars.
Product Specifications
Size Category: Minis and Micros
Type: Digital
Application: 250- to 500-size helicopter tail rotor
Torque: 33 oz-in (2.4 kg-cm) @ 4.8V; 39 oz-in (2.8 kg-cm) @ 6.0V
Speed: 0.06 sec/60 @ 4.8V; 0.05 sec/60 @ 6.0V
Length: 1.37 in (34.7mm)
Width: 0.58 in (14.7mm)
Height: 1.2 in (30.5mm)
Weight: 0.86 oz (24.5 g)
Bushing Or Bearing: Bearing
Bearing: Dual
Motor Type: Coreless
Gear Type: Metal
Voltage: 4.86.0V
http://www.spektrumrc.com/Products/D...dId=SPMSH5020G
The real kicker is that it sells for $49.
I have been running them in my 12R5.2 and 10R5.1 for almost a year now and they have been perfect.
Adrian Martinez
Old 04-29-2013, 02:56 PM   #454
No9
No9's Avatar
Originally Posted by RedBullFiXX View Post
New mod+stock update board SXXcomp v2
Still runs flawless with 1s, and no booster
I know LRP does not support this, but it works
I tried this and yes the esc works fine but i constantly had issues with my laps being missed,and i was the only one .
I fitted a booster battery and the issue was gone.
Schumacher Mi5evo/Ko Ex1v2/LRP/R1 wurks
Supported by MRJ RACING.COM.AU
No9 is offline   Reply With Quote
Old 04-29-2013, 03:03 PM   #455
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
What servo in that car ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-30-2013, 01:39 AM   #456
No9
No9's Avatar
JR Ds3405
Old 05-08-2013, 05:39 PM   #457
I've just purchased a RC12R5.2 please help me for a starting point Gearing 10.5T Boosted!!
THANKS
pepito10.5 is offline   Reply With Quote
Old 05-08-2013, 10:20 PM   #458
I used this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYZW6
It works with the horn that comes in the kit.
rossb is offline   Reply With Quote
Old 05-25-2013, 04:24 AM   #459
Default GRIP ROLL PROBLEM is it the set up Advice please
Having ran my 1/12th 5.2 for 6 months now and not had a problem till last week. First big meeting of the year and running a new additive in the Uk. 110 runners .
By round 3 we had a very high grip situation and couldn't keep car on 4 wheels.
Set up used
1.Blue side and shock springs.
2.020 king pin spring
3.magenta tyres all round 44mm rear and 42 front.
4.ride height 3.6mm
5.side dampers corally red
6. shock 30wt oil
7.Camber -1
8.droop 1.3mm
9.running 10.5 blinky with AMR shell.
any ideas guys.
Old 05-25-2013, 05:36 AM   #460
Set up used
4.ride height 3.6mm
6. shock 30wt oil
7.Camber -1
8.droop 1.3mm
any ideas guys.
Tire size will make the most difference
Smaller tires, with very round edges 42Rr, 40Fr, Half sauce front, full rear, apply grip additive no more than 10m on front tires, from application to run
One run per day, per set of tires
Softer roll setup, 10k side dampers, could test by removing 1 side damper to see if less damping feels better
Side springs, Silver just touching, or Black 2 turns down
Pod should be level with chassis, with full weight of car on surface, no droop front
What brand wheels are you running ?
Old 05-25-2013, 06:16 AM   #461
AdrianM's Avatar
+1
I saw his post on the ask Keven thread and said the same things. Keven's 2013 Snowbirds and IIC setups are good for crazy grip too.
Adrian Martinez
Old 05-25-2013, 06:25 AM   #462
Default grip roll
Tyres used are new Mogbums, Magenta all round.These new wheels are not the Jaco rubber..
Addy is SPYDER GREEN this addy is new and being tested in the Uk for th BRCA all other addy have been removed for the approved list and starting from scratch .Latest addy is oil free.
Old 05-25-2013, 07:20 AM   #463
Trader Rating: 18 (100%+)
Default Savox servo
Did anyone try a Savox 1250-MG yet in their 5.2 or any 1/12
How is it compared to Futaba 9650 ?
thejo3 is offline   Reply With Quote
Old 05-25-2013, 07:40 AM   #464
Try Pink/Pink instead of Mag/Mag.... and go about 2mm smaller front and rear, like Dave said. Heavily radius the sidewalls, etc.
JamesL_71 is offline   Reply With Quote
Old 05-26-2013, 07:43 PM   #465
Default GEARING 10.5T BOOST
Please help me for a starting point Gearing 10.5T Boost!!
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
