Like Tree19Likes
Old 03-22-2013, 05:45 AM   #436
Originally Posted by Logi Maker View Post
If you can still... everything has moved to the FLOW. If you buy used, make sure it has the original board and not the upgraded one which eliminates the 1S....
When it comes to electronics i allways buy it new from a shop.
The SXX is still the best choice if i choose to buy an LRP esc.
But thx for the info.
addicted2blue is offline   Reply With Quote
Old 03-22-2013, 05:55 AM   #437
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
New mod+stock update board SXXcomp v2
Still runs flawless with 1s, and no booster
I know LRP does not support this, but it works
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-22-2013, 06:47 AM   #438
That's good to know
thx dave
Old 03-22-2013, 07:17 AM   #439
I just bought a new flow and unfortunately it requires a booster for 1s. I am going to try the Novak booster.
This is my first time trying a 1s car and it seems like my 13.5 motor is not very powerful on the bench. I guess the lower voltage of a 1s batt results in a slower motor.
rossb is offline   Reply With Quote
Old 03-22-2013, 11:47 AM   #440
Logi Maker's Avatar
Trader Rating: 49 (100%+)
http://www.amainhobbies.com/product_...ck-74V-3000mAh
BUSTED! Tech!!!!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 03-22-2013, 11:53 AM   #441
Got one of those for F1
Keep forgetting to set it up w/21.5 in
the R5
Old 03-29-2013, 01:14 PM   #442
I used the LRP flow with my 1S batteries and a 10,5 motor without a booster. But after one month the ESC broke down, with a bit of smoke and a lot of stinking.
Now I use the Orion ESC and am much happier with it.
mitrovic is offline   Reply With Quote
Old 04-11-2013, 03:11 PM   #443
Trader Rating: 32 (100%+)
Default 2mm chassis and bottom plate
Red Mosquito Racing products is proud to annouce our new 2mm chassis and bottom plate for the Team Associated 12r5.2 and 12r5.1!
This chassis is made out of high grade 2mm graphite which will allow the extra felx and grip needed for asphalt and carpet racing. This is chassis and bottom plate is 12g lighter than the standard Associated equipment which makes this a must have product for the serious racer!
Pricing
Chassis and bottom plate $59.95
Chassis only $39.99
Bottom plate only $19.99
Limited time FREE shipping on both Chassis and bottom plate orders in the low 48 states. I will ship to where ever please e-mail for pricing.
For questions or order please e-mail [email protected]
Thank you!
Monti
Associated RC 12 R5.2-picture2-001.jpg   Associated RC 12 R5.2-picture2-003.jpg
Monti is offline   Reply With Quote
Old 04-22-2013, 04:03 PM   #444
Rick Hohwart's Avatar
Default New setup posted
Mike Haynes - Mile High Indoor Champs 13.5 1/12
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-22-2013, 05:46 PM   #445
RacinJ's Avatar
Rick, Do you have Joe Trandell's set up for 17.5?
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 04-26-2013, 07:59 AM   #446
Yesterday i've driven the car for it's first time (we had a clubrace) and without having the time to get a better setup i had to start with the kit settings and my fastest laptime is 0.1s slower then with my RM-01.
I guess with a little training to find a better (read faster) setup i will be able to go faster.
The only problem i have is the ride height at the center, front and rear are 4.2mm and in the center i only have 3.8mm. I've tried several things with the pitch damper but so far i'm unable to raise the center ride height to get it equal to the front&rear.
The roll damper itself is perfect; but to mount the ball end with the aluminium piece that holds the 3mm grub screw that must be tightend on the damper shaft isn't the best way i've seen.
Also in the manual at the setting sheet section there is mentioned that the pitch damper is 66,5mm, the maximum i get is about 66mm with the ball end being unscrewed on the aluminium piece for about 1mm.
Do you guys have the same problem or is it just me?
Old 04-26-2013, 09:04 AM   #447
Logi Maker's Avatar
I had the same problem with the spring adjuster maxed out... put on a longer RPM ball cup and problem solved....
Kyle Predmore
Old 04-26-2013, 10:38 AM   #448
Do you perhaps have a part nr of those longer RPM ball cups?
Thx for the info
Old 04-26-2013, 12:43 PM   #449
AdrianM's Avatar
The kit parts work fine for me. I run around 1mm of droop.
Adrian Martinez
Old 04-28-2013, 02:13 AM   #450
What size servo fits in this car?
HBRC-LBD is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
