Like Tree3Likes
Old 03-04-2013, 10:21 AM   #391
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by addicted2blue View Post
I finally pulled the trigger and ordered myself this chassis.
Have high hopes for it, as my tamiya RM-01 drives great and really like driving it but due to the tire issues i had to buy another 1/12th car.
Will be looking for a good setup to start with.
Should i start with the setup of the manual and go from there or am i better off with another setup?
Check out the setup Rick posted above
Enjoy your new car, with front tires that wear down to the rim
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-04-2013, 11:46 AM   #392
That's pure luxe, to be able to wear down the tires
addicted2blue is offline   Reply With Quote
Old 03-04-2013, 07:14 PM   #393
Car Breaker's Avatar
what us the diameter of the plastic side damper tube ? I want to see if I can fit that into my Kyosho plazma Ra
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 03-04-2013, 07:37 PM   #394
4.8mm inner tube/piston
Old 03-05-2013, 08:08 AM   #395
Edited - answered my own question.
rossb is offline   Reply With Quote
Old 03-05-2013, 08:39 AM   #396
even so...
You may want to check out the On Point Pro Tips for more info
+ YouTube Video
+ YouTube Video
+ YouTube Video
And for tons of 12th scale resource
Check the link in my sig
Old 03-05-2013, 04:58 PM   #397
Thank you, It looks like I will have to keep using damper tube set from X12
Xray X12 2015
ARC R10 ATS
Old 03-05-2013, 11:36 PM   #398
even so...
check the link in my sig
Thanks. Great stuff.
Old 03-06-2013, 01:40 AM   #399
Default Spur gear wobble?
Is anyone finding that the spur gear has tendency to wobble side to side? I've just built my new 12R5.2 and the spur gear moves from side to side? and its got me stumped on how to fix it?
Cheers Jackson
jacko4309 is offline   Reply With Quote
Old 03-06-2013, 03:01 AM   #400
Mine is on the way, but with my F1 cars we have the same thing about the spur.
it's normal to have a wobble for my F1 cars so i think it should be the same with the 5.2.
Old 03-06-2013, 03:43 AM   #401
Hi guys,I'm new to pancars,race onroad F1 and offroad normally.
Few questions,I want to know if the CRC side spring kit fit the 5.2 alloy spring mounts?
Also,is there a CRC center spring kit? And would you know if they will fit a Serpent WGT S100LT center shock? Are 1/12th and 1/10th pancar centre springs a generic size,I.E do they all fit each other?
Thanks for any help.
AE SC10 FT
Durango DEX210
Serpent S100 LT Corvette WGT
FGX Mckune Mercedes W02
Fleet powered by Thunder Power and Tekin,Spektrum and Hitec,painted by HABIBS BODIES
Peli is offline   Reply With Quote
Old 03-06-2013, 03:43 AM   #402
double post.
AE SC10 FT
Durango DEX210
Old 03-06-2013, 04:03 AM   #403
Radio Active's Avatar
or do i just buy the AE centre springs
Hey Peli,
The CRC side springs should fit on the AE holders, if not use a dab of super glue. the thing to know is that the CRC springs are progressive, and the AE ones linear, and that will have an effect on handling.
Centre springs tend to be the same diameter, but I don't know if there is a CRC kit.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 03-06-2013, 04:28 AM   #404
Thanks Daniel
I will be asking a few questions over the next few weeks as i get a handle on this car.
Cheers for the help,and for the info about tyres at SMA on Tuesday
AE SC10 FT
Durango DEX210
Old 03-06-2013, 04:45 AM   #405
avs
avs's Avatar
crc3299 is the encore shock spring set, same dimension but different color coding as AE's vcs shock springs. they will not fit the serpent shock. the serpent shock is shorter and larger diameter.
current 1/10 cars are using the same shock as the 1/12. but older 1/10 will have a 'macro' shock instead of the current 'micro' shocks.
i haven't tried to fit the older 1/10 springs on the serpent shock, worth trying it is a nice shock but serpent's spring color coding is inconvenient.
Tony Shimko
avs is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
