Like Tree19Likes
Old 01-02-2013, 12:05 PM   #256
Default I want to buy RC 12 R5.2
Originally Posted by Pulse_ View Post
Hi,
I'm about to buy..two 1/12 pan cars. How is the wear on the Associated? I plan to keep them for quite a long time so I rather buy something durable.
Hi to all and have i nice year.
I am from Greece and i wond to tell me where can i buy a RC 12 R5.2 to send to Greece.
drover is offline   Reply With Quote
Old 01-02-2013, 12:07 PM   #257
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
RC Market
http://rcmarket.com.hk/product_info....ducts_id=13749
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-02-2013, 05:34 PM   #258
Budman's Avatar
Trader Rating: 22 (100%+)
Originally Posted by AdrianM View Post
1. I don't run into stuff very often.
2. I use double sided tape, its thin tape with adhesive on both sides under the battery. Comes off clean and works great. Make sure its removable not the permanent kind.
3. The normal strapping tape through the chassis slots.
Whats up Adrain Its been a long time!!! I own Cooper Hobbies and talked to you a lot when you were at Schumacher. I have used that tape on my dirt oval cars and just didn't think about it!!! Thanks Buddy.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 01-06-2013, 12:43 PM   #259
Dear friends
About 20 years ago I was racing with my Asso in the 1/12 class. Swiss championship and European championship.
One month ago I did decide to come back and bough the R5.2 kit.
Fabulous I like it!
Of course a lot has changed in those 20 years, and I really have to learn a lot!
There is a local permanent race track. The track record is 8,0 sec. On the roll out day, 20 years after driving a car for the last time, I did 13, 0 sec. Yesterday I did a 11,3, so things are improving...
There are many things I need to improve, especially my driving skills.
Concerning the car, there are several things I have to improve, too:
- On a 180 turn to the left my car can flip over. What can I do to prevent it?
- My LIPO LRP 6300 1S pack does not fit quite correctly. It seems like it is about 2 mm too thick and it does not really fit under the "cover". Is this "normal" or have I made a building error?
Thanks for the help!
mitrovic is offline   Reply With Quote
Old 01-06-2013, 12:56 PM   #260
Post a pic of your car, and the settings/tires you are using
Adrian will be along shortly to help you out
Old 01-06-2013, 01:03 PM   #261
oladele's Avatar
Dear friends
Fabulous I like it!
Regarding your 180 flips, I have two suggestions first check your steering rate, your steering rate sounds as if it may be too high causing your issue if it's around 100 I would turn it down to about 60. If you are putting a traction compound on your front tires do not do the entire tire only do the inner 1/4 of the tire. Lastly check your drag brake try to possibly lowering it so you can let off the throttle and coast through it. I hope this helps like yourself I'm just getting back in the hobby about a 20 year layoff
oladele is offline   Reply With Quote
Old 01-06-2013, 01:25 PM   #262
Wow, thanks for the very fast answers.
The tyres are Jaco purple front and Jaco double pink at the back.
Settings are just out of the box, as the manual says.
I have reduced the steering way, may be I should reduce it more.
Another problem is, how do I reduce the differential slip?
It seems I can not share pictures yet, as I have posted only twice, so far...
Old 01-06-2013, 01:30 PM   #263
oladele's Avatar
You adjust the slip of the diff by tightening or loosening the diff nut which is the large plastic nut in the middle of the rear wheel. You don't have to remove the wheel to adjust it
Old 01-06-2013, 01:38 PM   #264
Done!
Thank you!
Old 01-06-2013, 01:55 PM   #265
oladele's Avatar
This video may help you out with set up a little bit. it's a little old 12r5.1 but the same rules apply.
http://www.youtube.com/watch?v=fRWk0...C0FA15FD83AD3C
Old 01-06-2013, 02:56 PM   #266
arn671's Avatar
Trader Rating: 14 (100%+)
Default Front width spacing????
Hey Guys, noticed on some of the 5.2 set up sheets that have the arms spaced out 2mm in the "upper arm" and others at the "lower arm", theoretically the upper link is lengthened either way. What is the difference in handling? Is it affecting the roll center? Thanks in advance!
arn671 is offline   Reply With Quote
Old 01-07-2013, 05:32 AM   #267
Robert_K's Avatar
The lower arms are wider, so that also gives a different track with.
But the pivot point of the upper arm in relation to the center of the car is also different
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 01-07-2013, 11:54 AM   #268
So, has anybody else a similar problem?
Old 01-07-2013, 11:57 AM   #269
I have ordered the Vortex R10 Brushless ESC (120A, 1-2S) by Team Orion. Does somebody else use it? Do you have the programing box? What settings?
Old 01-07-2013, 02:25 PM   #270
AdrianM's Avatar
Nothing fits over the battery, just tape. The top of the front plate and rear damper plate are flush with the top of the battery ~18.5mm
Adrian Martinez
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
