Like Tree19Likes
Old 12-26-2012, 12:51 PM   #241
AdrianM's Avatar
There is no good reason to run 20g wire over 16g. 16g is plenty flexible and certainly has less resistance (and the accompanying voltage losses) than 20g. Just look up the specs for the current carrying ability of 20g wire.
I run Deans or TQ 16 on my WGT where the speedo is close to the motor. On my 12R5.2 I run TQ 13g since the wires are longer, have a smooth line to the motor and thus will not affect tweak.
Adrian Martinez
Old 12-26-2012, 01:47 PM   #242
Adrian,
Just giving options for the guy.
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 12-26-2012, 05:12 PM   #243
AdrianM's Avatar
Originally Posted by sdunnmcp View Post
Adrian,
Steve Dunn
Sorry, I didn't mean to come off that harsh. It my girlfriend's fault.
She got me this shirt for Christmas:
Adrian Martinez
Old 12-27-2012, 05:01 AM   #244
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
So in closing, 14g is fine?
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 12-27-2012, 08:50 AM   #245
CypressMidWest's Avatar
As long as it's flexible enough to keep the pod tweak free.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-27-2012, 08:51 AM   #246
If you are running Stock, I would run 16g or 20g from TQ. The problem with anything larger is that it is very hard to keep it from tweeking the pod. In 1/12 Mod we run 13g because of the high current, but we have to check the wires frequently. Only use TQ as it is the most flexable and probably the best for our industry.
To find out if your wire is tweeking the pod, get the chassis balanced with everything soldered, then remove the wires from your motor and see if it is still balanced.
Hope this helps.
Steve Dunn
Old 01-02-2013, 09:32 AM   #247
Budman's Avatar
Trader Rating: 22 (100%+)
If you are using the thunder power battery like this one that has the step down on the front how do you keep it from sliding under the front battery holder.
Thanks so much
Chris Cooper
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 01-02-2013, 09:46 AM   #248
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Send a message via Yahoo to Jim Frahm
Thanks so much
Chris Cooper
I run shorter post which lowers the battery holder. I got the post from an On-Point racing chassis. Stormer Hobbies carries the parts for On-Point racing chassis'.
Jim
Serpent S411 ERYX, Reedy 25.5, FLOW
AE 12R5.2, Trinity 17.5, ORCA
Jim Frahm is offline   Reply With Quote
Old 01-02-2013, 09:47 AM   #249
Send a message via AIM to tnt2671
Thanks so much
Chris Cooper
Just securely tape it , I have the same packs
tnt2671 is offline   Reply With Quote
Old 01-02-2013, 10:41 AM   #250
Pulse_'s Avatar
Hi,
I'm about to buy..two 1/12 pan cars. How is the wear on the Associated? I plan to keep them for quite a long time so I rather buy something durable.
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 01-02-2013, 10:44 AM   #251
AdrianM's Avatar
Thanks so much
Chris Cooper
1. I don't run into stuff very often.
2. I use double sided tape, its thin tape with adhesive on both sides under the battery. Comes off clean and works great. Make sure its removable not the permanent kind.
3. The normal strapping tape through the chassis slots.
Adrian Martinez
Old 01-02-2013, 10:56 AM   #252
jsinclair's Avatar
Thanks so much
Chris Cooper
I run a short cf block glued to the chassis in front of the battery.
jsinclair is offline   Reply With Quote
Old 01-02-2013, 11:01 AM   #253
jsinclair's Avatar
Originally Posted by Pulse_ View Post
Hi,
They are just as resistant to wear as the other cars, the only parts I've gone through are front springs and rear bearings.
Old 01-02-2013, 11:47 AM   #254
Pulse_'s Avatar
Even plastics?
I'm running offroad in parallel and Xray plastics are far more durable than AE that's why I'm asking if it's also the case in pan cars.
Old 01-02-2013, 12:02 PM   #255
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Even plastics?
AE front end is the most popular & durable
AE 12 cars are very strong, and as fast as anything
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
