Like Tree19Likes
Old 12-08-2012, 09:57 PM   #226
Send a message via AIM to tnt2671
Default servo choices
have a 5.2 kit on the way and need to get a servo , what do you guys suggest fut 9650 , spektrum 5010 or 5020 , or savox 1350 they all seem to be in the same price range ,thanks for the help in advance
tnt2671 is offline   Reply With Quote
Old 12-08-2012, 10:04 PM   #227
oladele's Avatar
I'm running the Savix 1250mg, works great and super fast
oladele is offline   Reply With Quote
Old 12-09-2012, 12:22 PM   #228
AdrianM's Avatar
See this post in the 1/12th thread. The attached image highlights the two newest best servo choices.
1/12 forum
Adrian Martinez
Old 12-09-2012, 12:25 PM   #229
Default Servos
Best choices are the Futaba S9650 should be your number 1 choice. Also a very close second is the Savox 1250 .I run the futaba in my 1/12th and the savox in my WGT10
RCvetran is offline   Reply With Quote
Old 12-09-2012, 12:53 PM   #230
AdrianM's Avatar
The Futaba 9650 has been used for years but it and the Savox 1250 are very slow servos. There are better choices available today. The Spektrum H5020G and the Savox 1257 are both lighter, faster and less expensive than the 9650.
Adrian Martinez
Old 12-09-2012, 01:25 PM   #231
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Are the Savox servos weight listed in grams?
Old 12-09-2012, 01:32 PM   #232
AdrianM's Avatar
Yeah, I forgot to convert them
Adrian Martinez
Old 12-09-2012, 02:22 PM   #233
Adrian thanks for the detailed answer I think in am going to give the 5020 a shot , I agree w you that torque should not be an issue due to servo savers deflecting before overcoming the servo
Old 12-23-2012, 07:20 PM   #234
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
2 Questions: What gauge of wire is everyone using?, and what gearing for 17.5 medium size, medium grip track?
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 12-23-2012, 08:09 PM   #235
Logi Maker's Avatar
Trader Rating: 49 (100%+)
16AWG and your rollout will be around 97-106ish mm. I run at 104mm with a Reedy Sonic and our track is 104x48... 76 spur/57-62 pinion range.. tires are at 42/41
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 12-23-2012, 09:09 PM   #236
AdrianM's Avatar
You only need to run 16g wire if you have a short span between the speedo and motor. 13g wire in a short span would impede pod movement.
On the 12R5.2 the speedo is far from the motor and flexible 13g wire will work fine.
See the pic.
BTW, its not my pic. I snagged it as I will be running the same speedo in my R5.2
Adrian Martinez
Old 12-24-2012, 04:51 AM   #237
Awesome, thanks
Old 12-24-2012, 03:37 PM   #238
See the pic.
I found that the 16g wire I was previously using was getting warm, so I switched back to the 14.
Old 12-25-2012, 09:02 AM   #239
I think a lot of guys in stock have switched to TQ 20g. Wayne won Cleveland this year with 20g. Wire should never get hot with 17.5 For mod 13.5 is still the standard.
sdunnmcp is offline   Reply With Quote
Old 12-26-2012, 01:37 AM   #240
Will this be a suitable substitute ?
http://www3.towerhobbies.com/cgi-bin...?&I=LXVFW6&P=7
Or does it have to be this?
http://www3.towerhobbies.com/cgi-bin...?&I=LXCPBB&P=7
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
