Like Tree19Likes
Old 12-03-2012, 11:24 AM   #211
geeunit1014's Avatar
Originally Posted by ToysRUsKid View Post
I'm having trouble understanding how to build the tubes. I read the manual that says use the #6636 grease, but then the setup sheets have 20K silicon oil for the tubes. Which is it? I thought tubes used different grease, but can I use silicon oil here also?
I use 20k diff oil. It works just fine. The oil is thick enough it doesnt run out of the tubes. Using silicon oil lets you fine tune the tubes more easily
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 12-03-2012, 12:33 PM   #212
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Mike, have you raced at Jackson before? is that why your name sounds so familiar to me?
Do you have a 17.5 stock setup you care to share?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 12-03-2012, 12:44 PM   #213
Yes I have Ive been running 13.5 blinky. Im running Keven's IIC setup, with .020 front springs and GQ 40/30 tires (Like a jaco Black/yellow), I would think that it would be solid in 17.5 as well.
Mike Gee
Old 12-03-2012, 05:31 PM   #214
ToysRUsKid's Avatar
I'm going to try that setup on wednesday. I got my parts to upgrade to the 5.2 tonight so time to rebuild. thanks for the help.
Old 12-04-2012, 06:20 PM   #215
Originally Posted by beyondthepack View Post
I donT want this to turn into a "wiring thread" but I'm running a SXX with Novak booster, and mini receiver and I feel the car is packed. Can some of you start showing your cars. Just like to get some ideas. Thanks fellas
Here is a pic of my 13.5 car
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 12-04-2012, 08:07 PM   #216
ToysRUsKid's Avatar
when building these tubes, I only need to put a coat of the of the oil on the tube (black part)? It doesn't seem smooth when I do it that way.
Old 12-04-2012, 09:03 PM   #217
you should put enough on so that it comes out the pin hole in the blue tube when you put them together.
Old 12-04-2012, 11:18 PM   #218
Send a message via AIM to Jonesy112
I fill the blue part about 1/3 of the way up before putting them together. Then squirt most of it back in the bottle as it comes out of the pin hole.
I can show you how I build mine on Sunday Dorian if you would like
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 12-05-2012, 07:26 AM   #219
ToysRUsKid's Avatar
Sounds like a great ideal, let's make it happen!!!
Old 12-05-2012, 07:56 AM   #220
Default new car, long arm conversion
Car all prepared and ready to go. We have a 1/12th national this coming weekend a 2 day event 10.5 blinky for me which is stock in the Uk A Sunday is another day ,2 classes open mod and sportsman which again is 10.5 blinky.I have to say this car and the WGT10 have rekindled my interest in RC racing enogh so to drag me back in to 1/12th. Ive also sold my CRC Mckune WGT10 which I never thought I would as its such a good car.But makes sense to have both the same for spares etc.
Associated RC 12 R5.2-l1010946.jpg   Associated RC 12 R5.2-l1010947.jpg   Associated RC 12 R5.2-l1010948.jpg   Associated RC 12 R5.2-l1010949.jpg   Associated RC 12 R5.2-l1010950.jpg
RCvetran is offline   Reply With Quote
Old 12-05-2012, 02:22 PM   #221
Good to hear! Good luck!
Old 12-06-2012, 06:35 AM   #222
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Default Adjustable Pod
Speedmerchant have a few custom adjustable Blue pods for sale
Limited qty...
http://www.teamspeedmerchant.com/news.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-06-2012, 07:21 AM   #223
I.T.Guy's Avatar
Limited qty...
now that is pretty spiffy!
www.5280Raceway.com | Racing. Elevated.
I brake for Drake's Coffee Cakes...
I.T.Guy is offline   Reply With Quote
Old 12-06-2012, 08:30 AM   #224
Default Weight saving
A pal of mine has just bought a set of ally screws and fitted complete car out with them .
Total weight saving is 9gms only. His car come in at 749 gms. Ready to roll ,he is using 45mm rears and 43mm fronts.So with smaller tyres will be very close to weight.
Servo is the Savox 1250
motor sonic 10.5
esc LRP SXX
receiver Sanwa 451
MR shell
Old 12-06-2012, 01:05 PM   #225
Jim Frahm's Avatar
Trader Rating: 68 (100%+)
Send a message via Yahoo to Jim Frahm
This is our new 12th scale rear pod. It features a new ride hieght adjustment system incorporating a independent bearing carrier. This bearing carrier has a set of small precision machined serrations in the face of it that mate to matching serrations on each rear bulkhead. These serrations are .5mm appart allowing for quick and easy ride hieght adjustment. Simply loosen the 4 screws at the back of the pod, move the bearing carriers to the new position using the engraved lines to match each side and retighten. No need to disassemble the rear axle or hunt down the right ride hieght adjusters. This pod also allows us to use a larger 1/4 x 1/2 x 3/16 bearing which rolls more freely and lasts longer than the old small flanged bearing we have used for all these years. This pod is available for the Speedmerchant Rev7, CRC, Associated, and Xray 12th scale cars. It uses a different bottom and rear pod plate, but uses the stock top plate for each car. As of now, the entire pod assembly which includes the bottom plate, rear brace, motor mount, left mount, screws, and bearings will be available from Team Speedmerchant. As always, the aluminum is the best aircraft grade 7075 or 7050 aluminum available for strength and durability.
I've been using one for over a year, it's the easiest pod to adjust and the bearings last longer than the stock flanged bearings.
Jim
Serpent S411 ERYX, Reedy 25.5, FLOW
AE 12R5.2, Trinity 17.5, ORCA
Jim Frahm is offline   Reply With Quote
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
