Like Tree19Likes
Old 11-29-2012, 09:02 AM   #196
Default weight
What the obsession with weight, my car comes in at 758gms with out even trying.
Standard car, futaba servo S9650, LRP SXX V2 esc, amr light weight shell, jaco tyres all round 45mm rear and 43 front.Lipo is NVISION,Mini amb transponder.
total weight is 758gms.
LRP Cell weighs 8 gms more
RCvetran is offline   Reply With Quote
Old 11-29-2012, 12:31 PM   #197
My cars are at @770 Grams, and am not worried about it. I do use some alum screws but also run a reciever pack. I don't think that extra weight hurts you much if at all.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 11-30-2012, 07:45 AM   #198
John.C's Avatar
Trader Rating: 36 (100%+)
Just tickering between race day. Little to no impact to the standings on race day I'm sure.
I do have a performance related question regarding Parma/Jaco tires. For stock (17.5) what would be best tires for the rear (Orange, Yellow, Pink)? They all seem to be similar/same shore rating.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 11-30-2012, 08:10 AM   #199
Default stock 17.5
Fastest option would be yellow/orange rears and black fronts.
Old 11-30-2012, 11:53 PM   #200
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I went through my car tonight and noticed I don't have the same ride height from left side vs right side. Has anyone else seen this and if so, how do you fix it?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 12-01-2012, 01:26 AM   #201
Default fix it
The fix is what is causing it,
1.odd size tyres
2.odd size ride height adjusters in back
3. sticky king pin ,
4.sticky top arm
5.car is tweaked
6.sticky centre rear pivot
body mounted in correctly, wires catching some where.List is endless .Let us know what the solution is and what caused it.
Old 12-01-2012, 01:35 PM   #202
Can someone do me a favor and measure the dimensions of a completed RC12R5.2 shock? Diameter and length, in millimeters preferably.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 12-01-2012, 04:04 PM   #203
ToysRUsKid's Avatar
Do you guys run any toe out or camber on the front end of the car? I don't see anything about it on the setup sheets.
Old 12-01-2012, 08:25 PM   #204
geeunit1014's Avatar
0 toe, start with 1* of camber and adjust. I noticed my car was off a little L/R ride height, but it didnt seem to affect anything. Everything else was square, it drove square, and it was fast
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 12-02-2012, 04:33 AM   #205
Default long top arm testing
Ran my car last night for the first time with the long top arm , after a number of runs with and without ,found my car best lap with 0.19 of a sec faster .So long arm it is.
rest of set up was
1. Side springs blue just preloaded
2.shock spring blue
3.shock oil 30,000wt
4.side tubes red medium spooge
5.1 droop
6.long top arm 2mm spacers with carbon brace fitted
7.front springs 020 and preloaded top of king pin 4 washers and 1 on top of steering arm.
8.caster block mid position
9.camber -1
10.ride height 3.8mm
11.Jaco magenta all round
12reedy 10.5 blinky 40 advance and 72mm rollout.
13.front wheels parallel . 0 toe
14.ARM shell
15.LRP SXX V2 with new board upgrade
large track 12mts wide and 30mts long,additive was speedtech Meduim grip
Old 12-02-2012, 05:43 AM   #206
The camber and toe settings are in the top left corner of the setup sheet under Front Suspension.
Tuner EM is offline   Reply With Quote
Old 12-02-2012, 06:30 AM   #207
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
I donT want this to turn into a "wiring thread" but I'm running a SXX with Novak booster, and mini receiver and I feel the car is packed. Can some of you start showing your cars. Just like to get some ideas. Thanks fellas
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 12-02-2012, 06:34 AM   #208
Originally Posted by SuperFastSnail View Post
Hey everyone, I'm wandering if anyone has come across ordering a drill bit to make new holes into the carbon chassis fitting 3mm flat head screws. Any info on part no. or the bevel angle on the flat head screw is greatly appreciated. I tried looking it up on granger.com but lordy, it's taking me forever.
The metric flat head screw angle is 90 degrees. A simple way to drill the countersink is to use a countersink bit for wood. You can find these in many stores. one example is P/N 858 on this page
http://www.ptreeusa.com/drill_products.htm
I found that when you starting a hole in CF a small bit may wander and your hole ends up off center. You can correct with the larger bit but it's easier to start the hole with a center drill bit.
Old 12-03-2012, 10:37 AM   #209
ToysRUsKid's Avatar
1.odd size tyres
4.sticky top arm
5.car is tweaked
I think it was tires because I ran the car for 8 mins and measured again and it eventually evened out.
I didn't try it yesterday because I hadn't seen this post. I will try it next time.
Old 12-03-2012, 10:58 AM   #210
ToysRUsKid's Avatar
I'm having trouble understanding how to build the tubes. I read the manual that says use the #6636 grease, but then the setup sheets have 20K silicon oil for the tubes. Which is it? I thought tubes used different grease, but can I use silicon oil here also?
Associated RC12R5 Ferrarimk13 Electric On-Road 3811 05-08-2016 09:02 PM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
