Old 03-07-2005, 07:27 PM   #16
Joel Lagace's Avatar
Originally posted by snopro31
I think this is why its better to call it up travel then droop.
Basicly if you have to raise your ride hight up 1mm you will have 1mm less of up travel now so you need to loosen the droop screw to get back the same amount of up travel as before.
I can understand that after you set that up taking it and putting it on blocks to make sure left and right arms are at the same level at max travel so the car has no tweek to it.
Word! You got it
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
RMS-1 - Rotor Measurement System A. Rhodes Oval, Larger Scales and More 3 07-25-2008 07:41 PM
B4 measurement question.. Johnathan Electric Off-Road 6 06-04-2006 06:51 PM
setting droop on droop blocks mrgsr Nitro On-Road 3 01-08-2006 06:01 PM
Droop measurement EAMotorsports Electric On-Road 25 10-28-2003 01:53 PM
SEO by vBSEO 3.5.0
