Like Tree2Likes
Old 01-01-2013, 10:29 PM   #1456
caltek1's Avatar
Trader Rating: 35 (100%+)
If you are going to run a one piece front rear block then you need to get the proper front rear block that is designed to fit. These parts would be the same as that fitted to the BD5.
For carpet you want the 44.2 blocks front and rear. These are different part numbered for both.
Later,
Calvin.
caltek1 is offline   Reply With Quote
Old 01-02-2013, 10:02 AM   #1457
NolanP's Avatar
Later,
Calvin.
You run 44.2 blocks front and rear?
Don't you want sweep for better steering?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 01-02-2013, 11:03 AM   #1458
Hey guys , there are downstop o-rings in the partlist.
Is there someone who used them ?
I really have no idea where to instal these O-rings.
Should i push them on the setscrew for downstops ?
grtz
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 01-02-2013, 01:48 PM   #1459
grtz
Don't use them, the are for in the dampers under the piston.
Use only the droop scews.
MJ
PS, sent you a PM.
Remember Koen
pajenova is offline   Reply With Quote
Old 01-02-2013, 01:52 PM   #1460
peter.'s Avatar
Using one of you also center Balance Weight from Yokomo for the bd7
peter. is offline   Reply With Quote
Old 01-02-2013, 03:13 PM   #1461
Hi Peter,
I use the center weight when i'm driving LRP CPX tires.
Because they aren't so heavy as the sorex or ride tires and otherwise my car does not weigh 1350gr.
many groetjes
PQ
neys_p is offline   Reply With Quote
Old 01-02-2013, 08:20 PM   #1462
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
What is arm sweep? If I switch. If I switch to a wider FF block will that give me more steering or less?
Racing4Evo is offline   Reply With Quote
Old 01-02-2013, 10:12 PM   #1463
Arm sweep is when your FF is wider than your FR. Consensus on RCTech and a few local experienced guys I've asked seems to be that it will give you more mid corner and exit steering. Although one person has said it gives more steering everywhere. So it might depend on how you do it.
My understanding and limited experience says that a wider front track width will give less agressive steering, and narrower front track width makes the car more aggressive. So I'd suspect that going with a wider FF (wider overall front width) will probably give you more middle and exit steering, without making the car much more aggressive, but going with a narrow FR (narrower overall front width) might give more middle and exit steering, combined with a more aggressive feel. That's pure speculation, though, as I've never personally tried arm sweep.
-Mike
Old 01-03-2013, 07:15 AM   #1464
Cadman1981's Avatar
I finally got my kit last night in the mail, at 7:30pm! I put my kids to sleep and went to work!
As i am building it, i am following tips i read on here, and also finding more things to suggest.
So far, i am disappointed with the ball cups, there is a lot of slack in there, they will be swapped for RPM units.
I put 2mm spacers in the rear hubs so when i bolt the wheel it won't squeeze the bearings and warp the hub. Also in the front, i put a 0.2mm shim that rests on the bearing race between the pin and bearing to remove the play in the CVD/universal.
Also for my spur gear, i filed down the screws so i can fit thicker units, there is now a little gap in between the pulley and screws, box stock it was actually touching and making it wobble.
I also rebuilt my rear diff, and i put lithium grease on the 2 o-rings to help seal the unit.
Cadman1981 is offline   Reply With Quote
Old 01-03-2013, 07:53 AM   #1465
I'm surprised you dislike the ball cups, I thought they are very good!
Your build looks very nice so far though, which spacer did you use in the rear hub? I was surprised the kit doesn't include them tbh.
cyclonetog is offline   Reply With Quote
Old 01-03-2013, 10:04 AM   #1466
Cadman1981's Avatar
The ball cups are a little loose, unless i am missing a step? do i have to pinch them?
For the spacers, i used 4 0.5mm shims, i tested with 3, then 5, and found 4 was just right to remove all the movement of the axel, it's tight, but no binding.
When my kids take their afternoon nap, i'll continue building it, i'm hoping to get it done by tonight so i can spend the day testing it tomorrow
Old 01-03-2013, 11:19 AM   #1467
No, I paid them no attention at all, they're free but don't seem sloppy to me but if you know of something better then that's cool
Hope you have fun testing!
Old 01-03-2013, 11:30 AM   #1468
NolanP's Avatar
Just remember certain cars require a certain amount of "slop" as we call it to function properly.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 01-03-2013, 04:12 PM   #1469
syndr0me's Avatar
Trader Rating: 32 (100%+)
I put the car back to stock, set it up with Umino's setup and mounted up T-Shox with Yokomo springs. Here's what I found so far in 17.5:
Arm sweep is good in the front. Helps mid-corner steering quite nicely without much tradeoff.
Car was slightly better with screw out of the top deck over the steering, but had a little more tendency to snap oversteer. Overall I think it's a worthy tradeoff, but maybe add it back if the car gets too much front bite as tires wear or grip comes up.
T-Shox seem like they might be amazing.
DCJ's in the rear were BAD! I tried them later in the day after I knew how the car was feeling, and they immediately introduced a feeling I did not like. A very unstable feel in the middle of the corner. The car rotated better through the center, but it was unpredictable and unpleasant to drive.
I removed the DCJ's from front and rear before today's testing so I could add them back in a controlled situation rather than start the day with them. I never got around to testing fronts since they're broken, but I assume they're okay there. Not a fan of them in the rear, however.
syndr0me is offline   Reply With Quote
Old 01-03-2013, 04:21 PM   #1470
theatriks's Avatar
So after installing the T-shox you noticed a diference rite away?
theatriks is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
SLIPPERY76
