Like Tree6Likes
Old 12-16-2012, 08:30 PM   #1276
NolanP's Avatar
Originally Posted by hanulec View Post
I've replaced these 2.5mm screws a bunch of times already. These lay shaft screws have to be one of the weakest part of this car.
Yup already replaced. Tighten every round just in case.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 12-16-2012, 09:26 PM   #1277
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Originally Posted by theatriks View Post
I'm trying to figure out what I'm doing wrong...I'm screwing both screws in each end as per instructions but when I go to change spurs as I unscrew the left side the right side screw comes out but the left wont come out ...I only drove this car one race weekend and love it so far but can't figure out what I'm doing wrong on these spur pulley screws.
That's strange..I just snug one side and tighten other side and done..mine never came loose
OVA is offline   Reply With Quote
Old 12-16-2012, 09:42 PM   #1278
caltek1's Avatar
Trader Rating: 36 (100%+)
Default RONALDS SETUP
Hi,
Just downloaded this from Team Yokomo FB page. There is text to go with this setup. Mainly deals with adding weight to the car to get it up to legal weight. Either placed in the middle of the chassis or to the side.
I have included the link for the page and a copy of the PDF file. Also talks about 1mm and 1.1 mm piston holes. It would be easier to access the FB page and read for yourselves.
http://www.scribd.com/doc/115525617/Untitled
Hope it helps someone.
Regards,
Calvin.
caltek1 is offline   Reply With Quote
Old 12-16-2012, 09:59 PM   #1279
caltek1's Avatar
Default Word Doc
Find attached an abridged version of the comments from the FB regarding the above setup.
Later,
Calvin.
File Type: doc Comments to Ronalds BD7 setup for carpet.doc (23.0 KB, 198 views)
Old 12-17-2012, 06:00 AM   #1280
theatriks's Avatar
Well that could be what doing wrong I think I'm tightening the left screw too much ,...
theatriks is offline   Reply With Quote
Old 12-17-2012, 06:04 AM   #1281
Smoothest car I've ever witnessed going round a circuit... period.
Mi4cxl is offline   Reply With Quote
Old 12-17-2012, 08:17 AM   #1282
5tylez's Avatar
I've ran into this problem.
whats happening is when you tighten the left side, the spur shaft isn't exactly perpendicular, so effectively you are screwing it in on a slight angle...
to get the screw out, you have to hold down the spur shaft with pliers, and screw it out the screw.
once you screw it out and attempt to remount the spur, if you notice any resistance in the screw before fully being screwed in, its at an angle, and you will have the same issues...
make sure you shims are flush to the shaft ends...I noticed different spurs have slight different widths, so the supplied shims dont go flush to the ends of the shaft with different spurs. They must be flush.
follow this, and you will be fine.
5tylez is offline   Reply With Quote
Old 12-17-2012, 08:25 AM   #1283
5tylez's Avatar
Default Binding Bearings
I also noticed that I've been getting bearing binding issues..
I came to the conclusion that the yokomo hexes are the problem. when you tighten your wheel nut on tight, especially serrated ones, this is where the binding happens...
to trouble shoot, I tested tamiya 5mm hexes and had no issues. just added a 0.1 mm shim to get rid of the play.
the Yokomo hexes really pull in the pin and put a lot of pressure on the centre of the bearings.
what I found helped was adding tamiya 5 x 1.5mm shims inside between both bearings inside the hub. This helped prevent the yokomo hexes from pushing the center of the bearings too tight causing binding..
Shim part # is 9804372.
Cheers,
Chris.
Old 12-17-2012, 08:35 AM   #1284
Trader Rating: 30 (97%+)
is there support for yokomo in the usa or canada yet, if so where , thanks
zaraz is offline   Reply With Quote
Old 12-17-2012, 08:48 AM   #1285
5tylez's Avatar
Nope not in Canada,
I live in toronto and bought my bd7 + parts from Rcmarket.
talking to LHS, HK prices are cheaper than canadian dealer costs...go figure...
Old 12-17-2012, 08:54 AM   #1286
hanulec's Avatar
Trader Rating: 27 (100%+)
Calvin thx for the data. I haven't read the word doc.. But I can tell u that setup doesn't work for stock racing. Way too much steering. I've run three very similar setups to that already. Id imagine all of that steering is what makes the car so good in mod racing. Makes me wanna drop a 4.0 in it...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-17-2012, 09:27 AM   #1287
Trader Rating: 24 (100%+)
Yes. Amainhobbies.com carries Yokomo.
newob is offline   Reply With Quote
Old 12-17-2012, 09:37 AM   #1288
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
I'd like to see this..........
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 12-17-2012, 09:51 AM   #1289
hanulec's Avatar
I want this on video too...
Old 12-17-2012, 10:07 AM   #1290
NolanP's Avatar
No what you want to see is gonna be my transistion to mod in 2013......on video
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
