Old 12-15-2012, 10:48 PM   #1261
B00t13g's Avatar
Originally Posted by mikeygar View Post
Am not measuring at the pin anymore because i forgot the difference in mm between regular droop and pin droop...
Was it 1.5mm difference? I use a Yokomo droop/ride height gauge but gradation is in 1's, no 0.5 steps
You know, I'm not really sure. If uminos setup is the "ideal" droop and the difference is only 1.5 I'm way off from where he is. I'll see if I can bum a droop gauge to measure from the pins or I guess I could just use a caliper. I wonder where they are measuring on the pins.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-16-2012, 12:46 AM   #1262
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by HawaiiBob View Post
Mike,
Have you given Hayato's IIC setup a go?
Got a link?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-16-2012, 12:54 AM   #1263
Originally Posted by hanulec View Post
Got a link?
i don't have a link, I took the info from him at IIC.
HawaiiBob is offline   Reply With Quote
Old 12-16-2012, 01:16 AM   #1264
mikeygar's Avatar
Trader Rating: 14 (100%+)
I remember reading somewhere that the pin droop is taken at the center of the pin and that measurement basis is thickness of arm divided by 2. Or something like that. Was just too complicated for me if it's a bad day at the track so I stuck to conventional measuring. What sucks is most of Umino's setups are pin measurements. Haha
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 12-16-2012, 05:02 AM   #1265
rosko's Avatar
Ronald volkers bd7 setup must be g14 classified
rosko is offline   Reply With Quote
Old 12-16-2012, 07:21 AM   #1266
hanulec's Avatar
Anyone aware of other bd7 forums? Even if they are not in English?
Old 12-16-2012, 08:39 AM   #1267
Do you find it that good?
Philipp1990 is offline   Reply With Quote
Old 12-16-2012, 08:50 AM   #1268
B00t13g's Avatar
My current setup
http://www.petitrc.com/reglages/yoko...yShop20121216/
Mackenzie Meyercord
Old 12-16-2012, 10:52 AM   #1269
For anyone measuring droop at the pins, what gauge are you using and how are you measuring it? My hudy one won't quite work I don't believe.
It'll be the same as the HB guys do it. Chassis flat on your board, measure from the board to the centre of the hinge pin with a steel rule. No need to measure wishbone thickness or do any calculations, very simple really.
cyclonetog is offline   Reply With Quote
Old 12-16-2012, 02:42 PM   #1270
theatriks's Avatar
I'm having trouble with the spur pulleys ...i guess I'm over tightening because when I go to take out the spur the right screw comes out but the left screw just keeps spinning with the whole unit ....should the screw on the left not be tightened too much or am I doing something wrong .
theatriks is offline   Reply With Quote
Old 12-16-2012, 04:31 PM   #1271
B00t13g's Avatar
You're doing something wrong I believe.
Mackenzie Meyercord
Old 12-16-2012, 05:00 PM   #1272
theatriks's Avatar
I'm trying to figure out what I'm doing wrong...I'm screwing both screws in each end as per instructions but when I go to change spurs as I unscrew the left side the right side screw comes out but the left wont come out ...I only drove this car one race weekend and love it so far but can't figure out what I'm doing wrong on these spur pulley screws.
Old 12-16-2012, 05:22 PM   #1273
hanulec's Avatar
I've replaced these 2.5mm screws a bunch of times already. These lay shaft screws have to be one of the weakest part of this car.
Old 12-16-2012, 05:45 PM   #1274
B00t13g's Avatar
A local guy(the only other bd7 guy) had this issue as well. I'm not really sure why or how, but I haven't had it at all.
Mackenzie Meyercord
Old 12-16-2012, 07:26 PM   #1275
theatriks's Avatar
That's alright ...if this car continues to perform the way it did today I will accept that lol...maybe I will order another pulley set see if that ones the same .
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
