Old 12-14-2012, 11:12 PM   #1246
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by B00t13g View Post
Has anyone tried running diff fluid lighter than 900? Anytime I've tried I've hated the way the car felt.
car drive well with 1200
but most setup they been running 2k
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 12-14-2012, 11:16 PM   #1247
B00t13g's Avatar
I wish I could see more US setups or just setups on low-medium bite carpet. I don't know if the car naturally doesn't like light diff fluid or if its just me.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-15-2012, 07:18 AM   #1248
The lighter diff fluid u need to set the rear diff position to high and front to low
Then it drives great
zzztech is offline   Reply With Quote
Old 12-15-2012, 09:37 AM   #1249
syndr0me's Avatar
Trader Rating: 32 (100%+)
I've been using 2k in 13.5.
The shocks build up much nicer when vented. We'll see if they last longer.
syndr0me is offline   Reply With Quote
Old 12-15-2012, 12:10 PM   #1250
B00t13g's Avatar
Your traction is probably a bit higher than ours at mikes. We're probably a solid medium on a good day. 1k seems to be working well for me now in 17.5.
Mackenzie Meyercord
Old 12-15-2012, 01:10 PM   #1251
theatriks's Avatar
Had the car out today and the car felt great! ...box stock setup was fine ....I felt it a little pushy in the infield chicanes but just a little ...don't have much time until tommorow a race to play with it but is it unimos setup that everyone is finding good for 17.5 stock ?
theatriks is offline   Reply With Quote
Old 12-15-2012, 01:29 PM   #1252
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
The is what I'm using..except I shorten the rear wheelbase all the way.and 1000wt gear diff .which give me more rotation and corner speed...
Our track grip med high end of the nite
OVA is offline   Reply With Quote
Old 12-15-2012, 03:26 PM   #1253
theatriks's Avatar
Thanks OVA I will try that
Old 12-15-2012, 05:27 PM   #1254
syndr0me's Avatar
I love you guys, truly I do, but I'm sad this thread consists of three people.
Old 12-15-2012, 11:01 PM   #1255
B00t13g's Avatar
Four on a good day. I was very happy with my car today I just couldn't catch a break. Only things I changed from my setup on petit is. 1k in rear diff. Laid the rear shocks down to hole 2 in the rear. Vented shock caps with almost no rebound .5 on the Ackerman and 1mm on the inner rear ball stud instead of .5
Mackenzie Meyercord
Old 12-15-2012, 11:19 PM   #1256
B00t13g's Avatar
For anyone measuring droop at the pins, what gauge are you using and how are you measuring it? My hudy one won't quite work I don't believe.
Mackenzie Meyercord
Old 12-15-2012, 11:19 PM   #1257
Danny-b23's Avatar
I'll be here soon. After my 2 month break. Watching intently as you guys figure different things out.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 12-15-2012, 11:25 PM   #1258
hanulec's Avatar
Trader Rating: 23 (100%+)
im sad that right c-hub #4 & #5 died tonight, along w/ my first knuckle.
this car continues to be a handful in stock blinky TC on a high bite track. i moved to lighter rear springs at the end of the night and the car go WORSE. i couldn't believe. i cannot get the car to stop rolling over on the front end and snap steering.
i produced my quickest lap w/ the car yet --- too bad its 0.2s slower than my EX, and 0.4s slower than track record...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-15-2012, 11:29 PM   #1259
mikeygar's Avatar
Trader Rating: 14 (100%+)
Am not measuring at the pin anymore because i forgot the difference in mm between regular droop and pin droop...
Was it 1.5mm difference? I use a Yokomo droop/ride height gauge but gradation is in 1's, no 0.5 steps
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 12-15-2012, 11:37 PM   #1260
Mike,
Have you given Hayato's IIC setup a go?
HawaiiBob is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
