Like Tree2Likes
Old 12-06-2012, 08:09 AM   #1171
B00t13g's Avatar
Originally Posted by 5tylez View Post
wouldn't shorting the wheel base make the car less stable on turning? I thought making the wheel base longer will smoothen out the car a little?
Has any one tried using the forward most mounting holes for steering rack to change the ackerman to smoothen out the car on flowing corners?
It smoothed out the initial turn in because its not transferring as much weight forward off throttle.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-06-2012, 08:15 AM   #1172
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
plus longer wb also take wider turn
OVA is offline   Reply With Quote
Old 12-06-2012, 08:25 AM   #1173
B00t13g's Avatar
It's technically shorter though?
Mackenzie Meyercord
Old 12-06-2012, 10:40 AM   #1174
OVA
OVA's Avatar
maybe we are talking two differnt things...
Longer car can't turn harder than shorter wheelbase car around the turn
Old 12-06-2012, 09:21 PM   #1175
Trader Rating: 21 (100%+)
Is A-Main going to get restocked with parts soon?
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 12-06-2012, 09:41 PM   #1176
hanulec's Avatar
Trader Rating: 25 (100%+)
let me guess -- right c-hubs?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-06-2012, 10:26 PM   #1177
B00t13g's Avatar
Haha you as well. I have like 4 lefts and no rights. I ordered a few sets from futaba pro shop. Thankfully our new lay out is running the opposite way so I can break into my stash of lefts!
Mackenzie Meyercord
Old 12-07-2012, 12:22 AM   #1178
Aaron_M's Avatar
A longer wheelbase will make the car more stable. I didnt mean i was going to try a shorter wheelbase, just to play around a bit with the wheelbase in general
Havnt tried the forward ackerman holes in the chassis but have had 1mm to 2mm behind the steering link ballstuds to move them forward more.
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 12-07-2012, 08:54 AM   #1179
syndr0me's Avatar
Trader Rating: 32 (100%+)
The Yokomo DCJ's are currently taking up all 10 spots on my s*** list.
syndr0me is offline   Reply With Quote
Old 12-07-2012, 09:24 AM   #1180
B00t13g's Avatar
Lol why? I haven't really had any issues with mine?
Mackenzie Meyercord
Old 12-07-2012, 10:08 AM   #1181
hanulec's Avatar
McMaster 1.5x10mm pins cut down really help along with shrink wrap. But yes... They suck.
Old 12-07-2012, 12:02 PM   #1182
syndr0me's Avatar
It's almost as if the pins are too short. They weren't breaking, just coming out during an impact. I'm gonna revisit making the Tamiya DCJ's work.
I finally broke a c-hub last night. I think I caught an axle on a flapper.
I didn't have a great night with the car to be honest. I was chasing electronics issues all night (turned out to be a sensor wire) and that kinda put me behind the curve making setup adjustments. The grip was up and I thought the car was worse for it. Pushed a bit in the sections where I needed a lot of steering. I need to spend some time working on the setup in higher traction.
Old 12-07-2012, 12:15 PM   #1183
CristianTabush's Avatar
Our XRAY DCJs/ TC6 V2 DCJs will arrive in like 10 days. We will sell the parts separately. The coupling is interchangeable with the yokomo ones and it uses captured pins. We have a guy locally running them and he has had success with changing the parts over. I have been running the V2 DCJs in my RSD6 for about 3 months running modified on the same set of DCJs. Karl Hoffmeister ran the Proto XRAYs for a good while with great success in blinky 13.5 and 17.5 with even a little bit of mod in there.
In my case pin failures were not an issue, but rather just wear from heavy usage running mod 2x per week for 2-3 months at a time. Usually at this point it's time to rebuild the unit. The coupling is usually the part I do not need to replace.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-07-2012, 12:20 PM   #1184
syndr0me's Avatar
This sounds very interesting to me. So I would only need to replace the coupling with your pins and rings? The Tamiya DCJ's interfere with the c-hubs slightly, any idea how the diameter of yours compare? I'm definitely good for an order and some testing, I'd much rather not use grub screws and shrink wrap. I don't mind replacing worn parts after a few months, that's expected. It's the breaking I can't abide by.
Old 12-07-2012, 12:34 PM   #1185
Syndrome, that is correct. The diameter should be nearly identical to the Yoke unis. There is going to be a little bit bigger diameter just at the point where the clips are, but this is a total of maybe 1mm more overall and usually at a point where they are not in the way of hitting, at least nothing was mentioned to me by the person running them in the Yokomo. I have personally not measured the Yokomo units, but I know they work.
For what it's worth, the XRAY, RSD and Yokomo Universals have interchangeable parts, they all have the same measurements. When we designed ours, I kid you not, the dimensions were practically identical to the XRAY units and we DID NOT EVER measure the XRAY ones. It was pretty weird. Come to find out, the Yokomo ones are the same way.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
