Old 11-09-2012, 06:23 AM   #976
Aaron_M's Avatar
Originally Posted by B00t13g View Post
Has anyone run the car with the stock front axles? I broke a dcj tonight and don't have a spare. It seems like the stock ones chatter violently.
The stock driveshafts do chatter quite a bit. Been running them for 6 weeks without a problem though. Thinking of getting the DCJ for running of carpet.
Yokomo BD7
Aaron_M is offline   Reply With Quote
Old 11-09-2012, 06:33 AM   #977
NolanP's Avatar
Snydr0me have you thought about taking the 1-2mm off the inside of the aluminum to be able to run the dcj's?
I am going to try running the actual BD-7 C-hubs with the aluminum steering knuckle. The only time I had an issue with the stock C-hubs so far was when my DCJ came apart.
The stock BD-7 C-hubs are supposed to be stronger than the BD5 c-hubs I had to replace them with.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 11-09-2012, 09:34 AM   #978
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm hoping Yokomo releases some aluminum c-hubs that are designed for the DCJ's. I'd rather not grind them up if I don't have to. I'm gonna see how durable the car is with the plastic c-hubs. I really think a proper bumper is the best choice. Like Ryan said, I made one from a Parma blank using a $65 scroll saw from Harbor Freight. It's not flawless, but it looks pretty decent and has the same shape as the stock bumper. I just need to be more careful when drilling the holes.
Did someone say Tamiya DCJ's are a direct fit? I've got some I'm gonna try. One of my Yokomo DCJ's has a defective thread. :-\
syndr0me is offline   Reply With Quote
Old 11-09-2012, 06:31 PM   #979
caltek1's Avatar
Trader Rating: 33 (100%+)
Yes. The Tamiya 44mm DCJ's are a direct fit and work well.
Later,
50 Cal
caltek1 is offline   Reply With Quote
Old 11-09-2012, 08:09 PM   #980
mikeygar's Avatar
Trader Rating: 14 (100%+)
any Yokomo boys miss out on TITC 2013 registration?
Really wanted to run modified with the BD7 but made a mistake with the registration process (didn't paypal separately, was waiting for a payment notification) so I missed the cut :-(....
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 11-09-2012, 11:48 PM   #981
syndr0me's Avatar
The Tamiya 44mm DCJ's do fit really well, though they start to rub the c-hub slightly before you reach full lock.
Old 11-10-2012, 01:40 AM   #982
peter.'s Avatar
what is the difference between black & stock bladders
peter. is offline   Reply With Quote
Old 11-10-2012, 05:40 AM   #983
black is stronger, stock will break after a few rebuilds
zzztech is offline   Reply With Quote
Old 11-10-2012, 09:49 AM   #984
pmc
Hello
Anyone know if the spur gears of the Kimbrough brand fit in the BD7 ??
Thanks in advance.
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 11-10-2012, 11:19 PM   #985
syndr0me's Avatar
Tamiya DCJ's are NOT a direct fit. They way the axle is machined is different, and it will let the hex slide in too far and bind up against the plastic.
Old 11-11-2012, 04:51 PM   #986
hanulec's Avatar
Trader Rating: 23 (100%+)
have you tried fitting anything else? maybe an RSD TC6 dcj?
one other thought -- what is the width of the front spool? i wonder if a TOP Photon spool would fit.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-11-2012, 05:39 PM   #987
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Are yo talking about inside the steering block ?
Can you add shims to fix the problem?
OVA is offline   Reply With Quote
Old 11-11-2012, 05:45 PM   #988
OVA
OVA's Avatar
I had the yokomo pulley 40t and it works in my photon
Old 11-11-2012, 08:00 PM   #989
syndr0me's Avatar
I haven't tried any others, but Yokomo makes their own DCJ's for the front and rear. One of my had a defective outdrive, so I figured I'd run the Tamiyas in a pinch since I had some. They could probably be shimmed to work, and the c-hub's could be modified so they don't rub, but I should have a replacement in a few days so I'll just try the Yok pieces. I'm not sure on the spool width.
The car was super easy to drive today with one of the setups from Yatabe. Definitely an improvement over the kit setup. It was extremely stable where other cars seemed to be struggling for grip. I'm gonna get some solid practice days in the next couple of weeks to really start working on fine tuning the setup, but so far, this car feels like it's going to be really good. And durability hasn't been a problem yet. I'm running the graphite parts with plastic c-hubs and a hard bumper and everything has been fine.
Old 11-12-2012, 01:50 AM   #990
Ultraspeed84's Avatar
Trader Rating: 44 (100%+)
So i got a few question for you BD owners in the US. First off who you buying the kits from? second is the car pretty tuff? or is it more fragile then say a 417 or t4? and how is parts support online? are parts hard to get for the car even online? often stuff on back order?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
