Like Tree5Likes
Old 10-30-2012, 12:04 AM   #856
jumpnjack's Avatar
Originally Posted by NolanP View Post
Adam I haven't tried. The DCJ's will be in next week.
As well as my regular c hubs BD-7 style
If it gets posted (I know there is video of the main) you have to watch the punishment the car went through. I saw X-rays broken.....no aluminum but still. I went through a sweeper and was trying to make it through a traffic accident. It was pretty brutal.
Yes you can, you will need to cut the inside you the hub if you are running DCJ
Awesomatix A700L, T.O.P. Rebel 10
Apex RC Pro Shop
ORCA/Pro Spec, Team EA Motorsport, Awesomatix USA, RC America, Team Powers
T.O.P Racing USA, John's BSR Racing Tires, Gravity RC, R1werks, 3Racing, TQ Wire
jumpnjack is offline   Reply With Quote
Old 10-30-2012, 09:50 AM   #857
Default Yokomo BD7 Spurs and Pinions
I was just wondering what what is the best spur and pinion to use on the BD7when running 17.5 blinky as I have read people were having slight problems when mounting certain brands of spur and pinion.
Many thanks.
415tam is offline   Reply With Quote
Old 10-30-2012, 10:16 AM   #858
swimbikerun's Avatar
Trader Rating: 100 (100%+)
Many thanks.
A 96t spur gets you down to a FDR of 3.84 with a 50t pinion. If you want a lower FDR you will need a 92/93 spur. The problem is going to be your pinion size due to the clearance it has with the motor mount aluminium support piece. On the 96t spur I don't have room for anything bigger than a 50t pinion without the pinion grinding metal.
-Xray T4 '16/Xray X12 '16
-2010 Cincinnati Beer Mile Champion
swimbikerun is offline   Reply With Quote
Old 10-30-2012, 10:55 AM   #859
syndr0me's Avatar
Trader Rating: 32 (100%+)
What's the story with pinion gears? There's not enough flat spot on the rotor shaft to tighten them down. If you flip them around, on the motors where that even works, the screw is obstructed by the top deck.
I need to find some smaller spurs that fit. There's not nearly as much room as other cars to fit a big pinion.
syndr0me is offline   Reply With Quote
Old 10-30-2012, 11:13 AM   #860
I'm running PRS pinions and flipped around the edge of the pinion run flush with the edge of the rotor shaft (Trinity D3.5). I ended up tightening the set screw of the pinion with a cheapy l-shape allen wrench. It seems as more touring cars are making their designs more centerlined (not sure how else to describe it) the more it may obsolete pinions with taller stack heights.
Old 10-30-2012, 11:14 AM   #861
NolanP's Avatar
At our asphalt track I had to run an 84 spur to hit the correct fdr.
This car takes more work.
Syndr0me don't you take your top deck off anyway to change gearing?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 10-30-2012, 11:20 AM   #862
syndr0me's Avatar
Nope, never had to before. And with the top deck being so tall on this car, you can get big pinions in there pretty easily.
I think the d3.5 shaft is long enough to flip the pinion around, and I guess there's always the option of grinding more flat spot, but...
It seems to be a side-effect of how much things have been moved toward the center. The hole in the bottom of the chassis makes it clear they intended for the grub screw in the pinion to be toward the motor, but none of the ones I've looked at have a flat spot that extends far enough to actually use them that way.
Old 10-30-2012, 01:51 PM   #863
What would you say the best spur is to use in the BD7, that lines up and doesn't need any holes made bigger when running 64 pitch.
Old 10-30-2012, 02:00 PM   #864
Panaracer...
I also use arrowmax pinions, but i dont know if they are available outside from germany... They fit right on and you can use the hole on the bottom to tighten the screw!
Update on my BD7! Now with T-Shox!!! And a motor-fan!!!
YOKOMO Touring Car BD-7-yokomo-bd7-t-shox-1-.jpg   YOKOMO Touring Car BD-7-yokomo-bd7-t-shox-2-.jpg   YOKOMO Touring Car BD-7-yokomo-bd7-t-shox-3-.jpg   YOKOMO Touring Car BD-7-yokomo-bd7-t-shox-4-.jpg
Philipp1990 is offline   Reply With Quote
Old 10-30-2012, 02:01 PM   #865
NolanP's Avatar
go to speedtech rc and they have spurs that fit just right.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 10-30-2012, 02:14 PM   #866
Originally Posted by Philipp1990 View Post
Panaracer...
Nice, What pistons, rebound springs and oil did you use in your T-Shox?
kdempsey is offline   Reply With Quote
Old 10-30-2012, 02:26 PM   #867
Stock 1,1 x 3 Pistons, the short and soft rebound springs, and 400 mr33 oil all around!
Also the stock yokomo pink springs in the front and the blue ones in the rear! ;-)
Old 10-30-2012, 03:10 PM   #868
Thanks for the info, let us know how you get on with them!
Keith
Old 10-30-2012, 08:00 PM   #869
B00t13g's Avatar
The rw spurs from speed tech work perfectly. The reedy motors have a shaft long enough to run aps or Robinson pinions. The schurr speed motor fits either as well, but just BARELY.
B00t13g is offline   Reply With Quote
Old 10-30-2012, 09:29 PM   #870
MikeXray's Avatar
Trader Rating: 73 (100%+)
I was off Larry's fast lap at the Gate but I could run laps to put me last in the A or in the B.
You're officially on the same drugs as bertrandv87... You're .6ths off larry and .3ths out of the b, maybe, and your consistency is horrid, but yeah maybe everyone needs to hear what setup you're running.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
