Like Tree6Likes
Old 06-25-2017, 02:34 AM   #7486
DirkW's Avatar
Originally Posted by scytherat View Post
Thanks. Its on a setup sheet that im trying, so could be that it should be 2.7. Is there a complete suspension block chart anywhere?
No idea. Did one myself in MS Excel.
Dirk
Current cars: Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): (Xray T4'18) | Xray X1'17(8) | Yokomo YZ-2 DTM | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 06-25-2017, 04:43 AM   #7487
Send me your email address and I can send you a picture of a chart
Scott_83 is offline   Reply With Quote
Old 06-25-2017, 07:39 AM   #7488
b20btec's Avatar
It should be 2.7 but he asked for 2.8 and that is what it calculates to.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 06-25-2017, 03:02 PM   #7489
Is there a calcultaion for working out what toe etc you will get then.
scytherat is offline   Reply With Quote
Old 06-25-2017, 08:35 PM   #7490
mac853's Avatar
Hi anyone:
In fact i run asphalt with bd7 2013.
Could anybody tell me would have any breaking issue if i remove motor mount post to put gear ratio less than 2.8 fdr, please?
Best regards
mac853 is offline   Reply With Quote
Old 06-26-2017, 06:20 AM   #7491
Originally Posted by mac853 View Post
Hi anyone:
Best regards
I ran my '14 without the post and it was fine.
Serzoni is offline   Reply With Quote
Old 06-26-2017, 06:30 AM   #7492
mac853's Avatar
But post of 2013 needs also remove that screw on lower deck to remove it completely, because i just want without that post of motor mount in my car to run bigger pinion gear.
Best regards
Old 06-26-2017, 11:06 AM   #7493
DirkW's Avatar
Yes, but it's Trigonometry (Sines, Cosines, Tangents and that stuff).
Dirk
Old 07-11-2017, 01:07 PM   #7494
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Hello, does anyone remember what the difference was between the SLF shock and the SLF II? Are there changes in length or volume? What was the design change?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 07-12-2017, 06:29 AM   #7495
Can confirm for sure the SLF II's are a shorter shock 50mm off the top of my head. Believe they have more volume (for a small shock) in the shock body to make up for the distance change. Team drivers use to switch towers and longer shocks for asphalt at times from memory.
Buy the black bladders, the pink ones are terrible and don't seat well at all... Drilling a small hole on the top cap for 0 rebound is a great tuning option as well. Love running mine dead, indoor or out it seems sucked to the floor.
[Yokomo 16' BD7 17.5 Stock] [Yokomo 16' BD7 21.5 USGT] [Tamiya TT-01E Hahn Truck] [Tamiya TA06 Exo 17.5 Stock *Retired*]
DaSilva3525 is offline   Reply With Quote
Old 07-12-2017, 07:31 AM   #7496
mikeygar's Avatar
Trader Rating: 14 (100%+)
has anyone done a 40T gear diff and spool conversion on their BD7 2016?
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 07-12-2017, 09:40 AM   #7497
Would like to know this aswell
Skimming through the BD8 thread, the Bulk head braces are different on the 40 tooth set up. So if you run them front and rear currently that's going to be another $50-60 for them.
Raising the bulkhead for clearance is also key.. still trying to figure out all these new combos..
pitch system, pitch system minus rod, RTC (mixing and matching between parts in kit and parts needed to buy) , new bulk head spacers / 40t diff gears So much to try and do on a yok these days :P
Old 07-12-2017, 09:40 AM   #7498
CL
CL's Avatar
Trader Rating: 32 (100%+)
Yes, it's called BD7 2015.
OVA likes this.
More racing and less typing!
CL is offline   Reply With Quote
Old 07-12-2017, 06:14 PM   #7499
mikeygar's Avatar
Old 07-15-2017, 03:38 AM   #7500
So am I right in saying the the lower shock mounts work with SLF ll shocks on the bd7 15. What shock towers tho as the are some for the 14 and 16. Can't find the 15.
Cheers
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
(0000000000)
