Like Tree5Likes
Old 05-28-2017, 03:16 PM   #7471
Anyone have a good starting setup for a bd7 16 running mod on a smallish carpet track? Thanks
scytherat is offline   Reply With Quote
Old 06-18-2017, 07:15 PM   #7472
Monsta's Avatar
Hello.
Is anybody able to tell me if just the bottom chassis is interchangeable between the 14 and 16 bd7?
Monsta is offline   Reply With Quote
Old 06-18-2017, 10:51 PM   #7473
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Monsta View Post
Hello.
i don't think so. I have both and motor mount holes don't line up. Bulkheads, servo and center weights, suspension mounts and bumper do though
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 06-18-2017, 10:55 PM   #7474
Monsta's Avatar
No problems, thank you very much 😊
mikeygar likes this.
Old 06-22-2017, 03:23 AM   #7475
Question for yokomo experts: Do bd8 shock towers fit the bd7 16 and vice versa?
If yes i can buy the new "big diff/spool" pulley conversion for my 16...
Worst87 is offline   Reply With Quote
Old 06-22-2017, 11:02 AM   #7476
b20btec's Avatar
same towers, keep in mind the internal ratio of the bd8 is 1.7 vs the bd7 2.0, belts from conversion may not work...The difference would be the center pulley.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 06-22-2017, 09:00 PM   #7477
What about running a 20t center pulley from the '15?
cheapskate.brok is offline   Reply With Quote
Old 06-24-2017, 12:45 AM   #7478
If you wanna use 20t pulley from '15 you have to dremel topdeck a little
desaix is offline   Reply With Quote
Old 06-24-2017, 02:54 AM   #7479
are we saying this conversion is no good for carpet then?
BKUK is offline   Reply With Quote
Old 06-24-2017, 12:59 PM   #7480
What reartoe in does the car end up with if you run 2.8 and 7.2 rear blocks. Cant see it on any of the charts. Thanks
Old 06-24-2017, 01:10 PM   #7481
Why would it not be any good for carpet?
Scott_83 is offline   Reply With Quote
Old 06-24-2017, 09:03 PM   #7482
b20btec's Avatar
3.1
Soap
Old 06-25-2017, 12:27 AM   #7483
3.1
Thanks. Is that a wider 3.1?
Old 06-25-2017, 01:47 AM   #7484
DirkW's Avatar
Shouldn't that be 2.7 and 7.2? All I can find in my charts is a 42.7, no 42.8...
But yes, that would give you 3.1 degrees, and yes about 0.7mm wider than standard.
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 06-25-2017, 02:25 AM   #7485
Thanks. Its on a setup sheet that im trying, so could be that it should be 2.7. Is there a complete suspension block chart anywhere?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
