Like Tree6Likes
Old 03-17-2017, 05:19 AM   #7456
Andy63's Avatar
Originally Posted by B.S. View Post
What will give using of FR 3.5 and FF 4.2 suspension blocks comparer to FR 3.5 and FF 3.5?
Wider front will reduce traction roll as it gives less steering. The feeling with more toe out angled front arms gives is more planted and can is faster indoors on carpet when traction is higher. That setup is recommended for all carpet tracks unless it's a really small track with low speed.
Is everyone running diffs high or low and why?
On the BD7 i liked the diffs in low position as it gives me a better feeling. But some others might like them in high position.
Cheers// www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 03-17-2017, 10:32 AM   #7457
Andy63 can you tell me what effect will be after bump steer changing?
B.S. is offline   Reply With Quote
Old 03-17-2017, 07:15 PM   #7458
mikeygar's Avatar
Trader Rating: 14 (100%+)
Andy, lower diff gives less roll, higher diff gives more roll right?
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-19-2017, 07:45 AM   #7459
Can anybody tell me, what will give bump steer changing?
Old 03-19-2017, 02:46 PM   #7460
Migigu's Avatar
more shim, more in corner steering.
Migigu is offline   Reply With Quote
Old 03-20-2017, 08:24 AM   #7461
Thank you.
Old 03-21-2017, 05:51 AM   #7462
Castradamus's Avatar
Trader Rating: 53 (100%+)
If anyone is looking for suspension mounts
FS: BD7 Samix Suspension Mounts
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 03-26-2017, 07:34 PM   #7463
esckalayd's Avatar
First time running the 2016 on asphalt and boy did it lack rotation and initial steering. I couldn't get the thing to rotate even after some drastic roll center changes along with narrowing up the wheel base. I was running the short shocks, short shock towers, and the lower CG bulkheads.
Check out the setup sheet. Would love some feedback.
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 03-26-2017, 11:49 PM   #7464
BardSmith's Avatar
Trader Rating: 61 (98%+)
I have a very clean bd8 that I'm going to be listing for sale on the national thread soon, hit me up if you're interested. Here's a picture with it with the electronics​ which I will strip out
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 03-30-2017, 10:27 AM   #7465
Trader Rating: 18 (100%+)
are all BD7 parts 2014 (or whenever they started the BD7) to 2016 compatible?
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 03-30-2017, 09:03 PM   #7466
mikeygar's Avatar
almost everything outside the chassis is compatible, arms, knuckles, bumper mount, axles.
Stuff in the middle that will work are the servo mount, steering wipers, diff carrier, center weight, toe blocks, sway bars, but the rest are all different. Motor mounts, bulkheads, shock towers, diffs, belts are different and specific to the year.
top deck will work but motor mount hole is different.
Not sure if i missed out anything else, but that's the most of it.
phatboislim likes this.
Old 03-31-2017, 07:41 AM   #7467
thanks man i appreciate it
mikeygar likes this.
Old 03-31-2017, 02:22 PM   #7468
What option is better, the RTC system on the rear or the Samix suspension mounts?
This will be for a BD7 2016.
SMOKESHOW86 is offline   Reply With Quote
Old 04-24-2017, 11:40 AM   #7469
HawkGT's Avatar
I think your issue is too little droop. The standard droop setting on touring cars is 5mm in front and 6mm in the rear, +/-1mm. Without enough droop, your car can't transfer weight easily.
Also, your rear suspension mounts will result in about 2.1degrees rear toe, not 3.0. This is actually helping your car turn more aggressively, but may make the car too loose after adjusting droop.
x3 Yokomo BD7 2016s: 13.5 TC, 17.5 TC, and USGT. Roche P10 World GT-R (building)
HawkGT is offline   Reply With Quote
Old 04-24-2017, 11:48 AM   #7470
HawkGT's Avatar
If you are looking for more customization of track width and toe angles, I would go for the BD8's suspension mounts over Samix. You get a lot more options.
Personally, I'm staying away from the RTC system until I become more familiar with how static setups affect car handling.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
