Like Tree5Likes
Old 01-24-2017, 01:56 PM   #7411
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by Scott_83 View Post
Hi Pete.
Are you based in the uk?
I think the guy live in Quebec, Canada
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-24-2017, 04:16 PM   #7412
Alrighty, got another question. What size/dimensions do I look for when ordering wheels for my BD7? I don't want just the solid white wheel as my only option. The manual doesn't mention it.
I know it needs to be for a 12mm hex hub. But what are the 5.0, 3.5s? Are those for offsets? Can I use a wider wheel to help fit some of the 200mm bodies?
ponchota is offline   Reply With Quote
Old 01-29-2017, 07:06 AM   #7413
Thought I'd give an update on my BD7.... HOLY MOLY!!! This thing Sca...Reams. Can you say zoom zoom! . Just what I was looking for in speed, too fast for normal racing but perfect for bashing around a parking lot. Very satisfying. If you could hear me I'd be grunting like Tim Allen. Roads are a bit to salty to really stretch its legs but still tons of fun.
Old 01-29-2017, 03:05 PM   #7414
Djchow85's Avatar
To fill a 200mm body you'll probably need a +3, +5mm offset depending the look you want. Most 1/10 road cars are 12mm hex I think.
Lancer Corolla 3 Impreza
Djchow85 is online now   Reply With Quote
Old 02-01-2017, 12:32 PM   #7415
Andy63's Avatar
Anyone else tried the extra hard suspension arms? I reviwed them here www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 02-10-2017, 10:42 AM   #7416
pete68's Avatar
does the t-works bd7-15 front spring steel spool
fit for the bd7-16
thanks in advance
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 02-11-2017, 08:25 PM   #7417
Has anyone had issues with the belt tensioner cams shifting on the car after hitting the wall? One decent hit and the cam turns and the belt is loose.
SMOKESHOW86 is offline   Reply With Quote
Old 02-11-2017, 08:49 PM   #7418
drsfly's Avatar
4-3 x 3mm set screws go in the inner camber link holes.
these stop the cams from turning.
No bumps on top of eccentrics like on BD7 to stop them from spinning.
I guess there was a blurb about it in the kit..... but not the upgrade kit!
Anyway just dab some locktite on and put them in just to tension the eccentrics.
Do One Brave Thing Today And Then Run Like Hell!
Darrald Spencer
drsfly is offline   Reply With Quote
Old 02-11-2017, 08:55 PM   #7419
drsfly's Avatar
I just realized this was the BD7 thread.
The setscrews are for the BD8 eccentrics.
If your BD7 eccentrics are spinning then you need to check if the spring & ball
are still in the cup of the bulkheads.
Darrald Spencer
Old 02-12-2017, 07:08 AM   #7420
I was just talking about this yesterday with a racer who asked me about the grub screws for the eccentrics and I am like Huh? I never seen this in the manual. But he had a BD8. I look at the those threaded hole as the inner link mounts options.
If your eccentrics are spinning then you would see it in a different position after your run say on one side vs the other correct? Or both sides moved to different position?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 02-12-2017, 09:17 AM   #7421
drsfly's Avatar
Yes, they are link mounts. But since the eccentrics are different in the BD8, no bumps on top of the eccentrics, set screws are needed.
I know it was not in the conversion manual.
Yes, different positions both sides , F & R.
Anyway, no issues since.
Darrald Spencer
Old 02-12-2017, 10:03 AM   #7422
I am getting one side rotating only. I will check to see if the cam spring is still in the bulkhead. Thanks for the information guys.
Old 02-12-2017, 11:52 PM   #7423
Andy63's Avatar
Hello! I glued my tensioner balls into the bulkhead. Never had an issue since. I also glued a little on top also. This have worked fine for me, but be careful so you dont get any glue anywere else! Cheers// www.andrefossto.wordpress.com
Old 02-13-2017, 04:41 AM   #7424
nudge2325's Avatar
1st place in the Bayside RC Presidents Shield race in 21.5t.
Not too bad for a BD7'15. Still some life left in them yet
YOKOMO Touring Car BD-7-16602969_10207639014245783_7374338336412536596_n.jpg
Club Secretary BRCCC. www.wynnumrc.org.au
My Rides:
2015 Yokomo BD7 Black
2015 Yokomo BD7 Black For the kids to drive
Losi XX4 WE
nudge2325 is offline   Reply With Quote
Old 02-13-2017, 07:26 AM   #7425
Congrats..... I think the bd7 is still the best yokomo kit out there...
bertrandsv87 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
