Like Tree6Likes
Old 01-19-2017, 08:47 PM   #7396
b20btec's Avatar
Originally Posted by desaix View Post
Thank you very much
Everything lines up, one thing to note 2015 allows the use of FMC that's why there's extra holes.
Carbon is 2015
Aluminum is 2016
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 01-20-2017, 09:10 AM   #7397
Carbon is 2015
Aluminum is 2016
Thanks a lot
desaix is offline   Reply With Quote
Old 01-20-2017, 10:30 AM   #7398
Andy63's Avatar
Carbon is 2015
Aluminum is 2016
That's great news actually! cheers// www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-21-2017, 12:34 AM   #7399
Wacker1's Avatar
Carbon is 2015
Aluminum is 2016
I did'nt think that the BD7 '15' Chassis would Fit onto a BD7 '16', due to the Rear Mounting Location of the Motormount?
Yes, I think the Holes are in the same place, but the '15' had 2 Screws with a centre location lug, whereas the '16' has 1 centre securing Screw, with 2 lugs.
Wacker1 is offline   Reply With Quote
Old 01-21-2017, 07:45 AM   #7400
b20btec's Avatar
You're 100% correct, I didn't catch that, my apologies for the bad info.
Soap
Old 01-21-2017, 02:14 PM   #7401
Default Front shaft blades
Hi all.
Is there an upgrade to fit front shaft blades on the 15.
Cheers
Scott_83 is offline   Reply With Quote
Old 01-22-2017, 02:59 AM   #7402
Originally Posted by Scott_83 View Post
Hi all.
Cheers
Stay away from them mate
cheapskate.brok is offline   Reply With Quote
Old 01-22-2017, 05:03 AM   #7403
Just trying to save on shafts and diffs. They are wearing out really quickly.
Old 01-22-2017, 06:49 AM   #7404
Originally Posted by ponchota View Post
Hey guys, I picked up a cheap sensorless Hobbywing motor and ESC from Amain. I just tried installing the motor and discovered it doesn't fit! There's nothing in the manual stating any diameter specifics. This is a 540 motor, the edges are a sharp 90deg. so it hits the upper deck, too much to lightly modify the motor or upper deck. I have a 96T spur and a 35T pinion and the space is huge.
I'm gonna have to return it. Is there a specific type of motor I need to order? I now realize I'm gonna need a motor with chamfered edges. I was hoping to do this on a budget to get my feet wet and have some fun, then go with something much nicer later on.
Just wanted to give an update with motor. I decided to keep the motor because shipping was too expensive. I ended up marking where the motor hits the upper deck and filed the corner of the motor to fit. It fits great now. I just need to get some new spur gears because my 39T pinion is the only one that meshes/seats well on the 96T spur. Got it powered up last night and I have some tweaking to do before she hits the streets of NH!
Thanks for all the help and support!
ponchota is offline   Reply With Quote
Old 01-22-2017, 10:02 AM   #7405
b20btec's Avatar
If you're bashing set it up for low traction to make the car easier to drive. I would run as much droop and ride height I could get away with.
I use a 14 to practice in a parking lot with a 4.5T motor. Running close to 6mm ride height 5.5 front, 4.5 rear droop. 388cst and yokomo black springs all around. Diff oil at 1k and roll centers set low.
Soap
Old 01-22-2017, 01:54 PM   #7406
Andy63's Avatar
Hello everyone, i have big announcement to make on my website https://andrefossto.wordpress.com
Also i will put in a longer review on the extra hard suspension arms for the bd7/bd8 in a couple of days. ALSO new videos are coming!
Cheers//
Old 01-23-2017, 07:06 AM   #7407
Cheers//
Congratulations! That is good news, you must be very excited.
Old 01-24-2017, 10:48 AM   #7408
pete68's Avatar
hi if someone wants to sell his bd7-15
email me at
[email protected]
thanks
pete
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 01-24-2017, 01:29 PM   #7409
Korey Harbke's Avatar
Email Sent!!!!
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-24-2017, 01:48 PM   #7410
Default Bd7
email me at
[email protected]
thanks
pete
Hi Pete.
Are you based in the uk?
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
