Like Tree6Likes
Old 10-03-2016, 12:01 PM   #7306
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
question: most of the 2015 BD7 are using aluminum chassis for carpet racing ?
It would be nice the BD7 2015 owner want shares their carpet set up!
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-03-2016, 12:06 PM   #7307
b20btec's Avatar
Yes, medium grip and up. I've also tried the new hard chassis on medium grip carpet and I liked it better than aluminum.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is online now   Reply With Quote
Old 10-03-2016, 12:23 PM   #7308
OVA
OVA's Avatar
how thick is the Carbon graphite chassis?
Old 10-03-2016, 01:39 PM   #7309
Trader Rating: 37 (100%+)
Interesting.
I have a 2016 with both a carbon and aluminum chassis. Never knew there was a thicker version.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-03-2016, 02:34 PM   #7310
OVA
OVA's Avatar
Originally Posted by Nexus View Post
Interesting.
I didn't say anything about there thick and thicker version..I just wanted to know What is the thickness of the hard chassiswhich I dont have in hand to check myself
Old 10-03-2016, 06:43 PM   #7311
evochick's Avatar
Its not thicker just different carbon weave, and cutouts (B7-00216H)
There is also a soft version, good for lower grip tracks, (B7-00216S)
I have been switching between the Soft and STD chassis depending on grip of the track (outdoor tarmac)
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 10-03-2016, 08:42 PM   #7312
Djchow85's Avatar
apologies if this has been asked before, tried searching but couldnt find it..
With the 14 BD7 has anyone compared the alu chassis (oem/arrowmax etc) vs the standard graphite on medium bumpy ashphalt?
pros/cons?
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 10-03-2016, 09:32 PM   #7313
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
pros/cons?
I selected CF because it flexes most and will help over the bumpy parts.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 10-03-2016, 11:03 PM   #7314
evochick's Avatar
pros/cons?
I am telling you now no!!!!! especially not at the hill. Come see me on Friday and ill go over your car.
Unretired
Old 10-03-2016, 11:23 PM   #7315
Djchow85's Avatar
[YOUTUBE][/YOUTUBE]
Haha I knew you'd respond. I didn't want to bother you too much but tbh with the last layout change, the second last bend before the straight, it was getting to me. I've ordered new tyres, mine were getting rings of death but also I realised I've had the mesh too tight. My car is now a lot quiet and rolls more...
Old 10-04-2016, 03:14 PM   #7316
So Yokomo USA is long gone, but are there any good Facebook groups or anything similar?
Other than Eric Albania is there a Yokomo USA team?
Old 10-06-2016, 10:23 AM   #7317
Just finished soldering my escape to motor on my bd7 charging a lipo and gonna go test it upside!:0 so hype, considering I am the worst at soldering I plugged in the lipo turned it on and tested motor and servo and nothing caught fire so pretty hype lol, ill be racing on small asfalt track. Mine has the aluminum chassis guess I should change that lol.
Photographer/Racer | Youtube rctrains | t5m | scte 2.0 |22 sct | Bd7 | 8ight E 3.0
rctrains is offline   Reply With Quote
Old 10-06-2016, 11:18 AM   #7318
First test of the bd7 is a success! My drive way has lots of little rocks so after a few minutes I seen it starting to stutter while giving power, so I toke it off and my back left wheel was moving freely, "oh no just blew my diff" so toke it inside and toke the body and wheels off, prepared to check the diff and a huge rock fell out of the rear axle and as is well!, gonna so sweep my whole drive way so I can get a nice tune, but man is 25.5 slow lol, plus I'm way under geared, running 95 after 5min lol
Old 10-30-2016, 06:36 PM   #7319
Wondering if someone can help. For Touring 17.5 Stock I am wanting to run a FDR of 3.8 to 3.9 and before racing today I was really frustrated at this car as I missed practice today after running my TRF419 and I wanted to quickly run back to back before qualifying to see how the cars perform with kit setup for the BD7 2016 vs the carpet setups of the TRF419 which without Alum Chassis was no good anyway on the TRF.
So the issue is I cannot seem to get a spur and pinion combo to work with my resources today at the track.
I had a Durango 86T spur on the car and with a 44 pinion I could not get the motor to move over enough to mesh with the spur. Limitations on both carbon top deck and the motor mount for the motor screws.
I feel it is a pain to get 45T plus pinions in there.
I grabbed I think a Kimborough type spur 102T in my box to try and make things work but it was thicker so the right pulley is like 0.7mm more over and it was rubbing on the carbon top plate (drivetrain was tight as I tightened the top deck down), so I had to file quite a bit and even angle the underside edge too and then was able to use the 46T but my FDR was way out at 4.43
So any suggestions? I was looking at the tables in the back for 64 pitch and since I got to get bigger than the 86T everything I looked at I wondered if anything would work out when thinking of 92T, 96T, 100T spurs. Anything bigger than the 102T and you really have to get big pinion gears going.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is online now   Reply With Quote
Old 10-30-2016, 06:43 PM   #7320
racer x 1's Avatar
Trader Rating: 27 (100%+)
Its gonna depend on track size and conditions but 17.5 blinky common would be 92-98 I personally like 96 at my local track
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
