Like Tree5Likes
Old 08-25-2016, 07:41 PM   #7276
BD8 proto chassis focus by RedRC
http://events.redrc.net/2016/08/chas...nald-volker-6/
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 08-26-2016, 01:53 AM   #7277
Chrissy C's Avatar
Interesting pics of the new car, at first I didn't think a lot had changed, but looking again, aside from the obvious ATS and spur arrangement / top deck, there is a smaller servo brace which seems to attach to a long, central alloy or plastic piece (underside shot of car shows that this is connected via 4 screws), new c hubs, steering knuckle (front - rear has current piece) and also, although very similar looking, the wishbones have different webbing on them, looks as though they will give a little more flex than the current wishbones.
Springs have wider coils at the top than the bottom - are these progressive springs? I don't think Yokomo currently make them for their SLF shocks do they?
Also, grub screws in the spare camber pick up on the bulkhead to hold the bearing cam, I've read about people doing this on the older models, but maybe they have drooped the spring/ball set up completely now?
Looks like RV is using 3.5 blocks on the RF and RR - same set up as front kit setting, so the pins are parallel and all of the toe is added via the ATS set up.
Looks good and seems to be working better for them in the lower grip conditions than the '16 did.
Chrissy C is offline   Reply With Quote
Old 08-26-2016, 03:54 AM   #7278
daleburr's Avatar
The BD8 motor mount is much shorter between its chassis mounting points. This will give a lot more flex at the rear, and a lot more traction, something it's always lacked compared to the Xray.
The underside picture shows it's just mounted using the 3 black steel screws (and some locating pegs between them). The rest floats above the chassis:
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 08-26-2016, 04:03 AM   #7279
Chrissy C's Avatar
Good point Dale, that should be a big improvement. You can see the original motor mount holes in the chassis still and its a big difference.
Also, with the new belt set up, I didn't see at first that the front belt is now central (I just thought the spur was put to the end of the pulley set up and the gap between the two belts was the same as the 16), but with the cut outs you can clearly see a central pulley. Do you think the central plastic part I referenced above acts as a belt tunnel and a servo brace mounting platform?
The more I see, the more I like it.
Old 08-26-2016, 08:49 AM   #7280
tbrymer's Avatar
http://events.redrc.net/wp-content/u...0-1200x720.jpg
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 08-26-2016, 08:58 AM   #7281
Stuff Of Legend's Avatar
No more rear diff in the front I guess
They will have to make a casing for the front.... I hope
Stuff Of Legend is offline   Reply With Quote
Old 08-29-2016, 08:02 AM   #7282
Trader Rating: 23 (100%+)
Hi all,
I accidentally ordered a 2016 titanium coated main gear shaft for my BD7 2015 (B7-644T16). Can anybody tell me if they are compatible? Or will I need to order the 2014/2015 specific part (B7-644T14)?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 08-29-2016, 08:30 AM   #7283
So with the more flex on the BD8 for more rear traction and other neat features, since I have a BD7 2016 and likely just carpet racing, in getting a 2nd car with the sale at AMain on them on the 2016 would I just be best to do that you guys think and have common spares between a 17.5 and Mod or USGT chassis? Or get the BD8 if you were in my position?
The 2016's were railing top of A Main at our tracks locally no problem with the T4 2016 cars while last season I was struggling with the TRF419 on carpet to keep up.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is online now   Reply With Quote
Old 08-29-2016, 04:09 PM   #7284
AL1983's Avatar
Originally Posted by Zhangesh View Post
Hi all,
No, they are not compatible.
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 09-13-2016, 10:39 AM   #7285
Reese Bobby's Avatar
Hi Guys, im looking to get my first Yokomo and have been doing some research on parts, setups etc. I must say im struggling to find an english source of information or anyone to, or form of, contact at Yokomo.
Can you please assist by advising which part numbers are used in this setup? Yokomo BD7 Souta Goto
Thanks in advance.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 09-13-2016, 11:26 AM   #7286
Thanks in advance.
These springs front and rear https://www.amainhobbies.com/yokomo-...-14525/p483384
This arm mount in the FF position https://www.amainhobbies.com/yokomo-...-3149b/p483401
This arm mount in the FR position https://www.amainhobbies.com/yokomo-...-30142/p242066
This arm mount in the RF position http://banzaihobby.com/Yokomo-B7-3127BS
The 1.3mm sway bar from this set for the rear of the car https://www.amainhobbies.com/yokomo-...-412rw/p483411
anr211 is offline   Reply With Quote
Old 09-13-2016, 11:38 AM   #7287
Much appreciated, thanks anr211!
VBC Wildfires
Old 09-15-2016, 12:39 PM   #7288
Hey everyone, my bd7 just arrived today and I'm wanting some wheels and tires, what size should I get?
Photographer/Racer | Youtube rctrains | t5m | scte 2.0 |22 sct | Bd7 | 8ight E 3.0
rctrains is offline   Reply With Quote
Old 09-15-2016, 09:01 PM   #7289
Hi rctrains,
as the bd7 is a 1/10th scale tc you should buy wheels for this scale. Typical brands are sweep ride sorex...
Worst87 is offline   Reply With Quote
Old 09-16-2016, 12:42 PM   #7290
Default Yokomo BD7 2016
Hello all -
Just bought my first Yokomo BD7 2016. Looking for some advice.
USGT,Medium/Medium High Traction Grey Carpet. Which main chassis plate do you recommend? Any set-up advice is welcome!
Also, does anyone have experience (good/bad) with the Samix floating steering system?
Thank you in advance.
RC4413 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
