Like Tree5Likes
Old 08-17-2016, 09:12 AM   #7261
Originally Posted by Damon View Post
Hi Ferox, what is the track? I'm Italian like you
I think BD7 is a fast car, but we have to change some ideas on setup that worked well with older BD7, now we have to work in a different way.
In my opinion we have the best results working on the roll center of the car, a thing that with older models was never changed, at least for me.
I made several tests with different tires, Sorex, Hotrace, Volante and LRP, and sometimes the BD7 works better with higher roll center, sometimes with lower, it depends on tires and asphalt condition.
A "must to have" is the 1-piece FR suspension block, for me it works always better on asphalt than the separate ones.
Another thing is to cut the topdeck in the front, specially with LRP G32 it have better corner entry.
If you want you can try this setup: http://site.petitrc.com/reglages/yok...vorno20160512/
I won a race with margin on the strongest local driver of the track, who runs with a T4. Maybe it can be useful also for you.
Hi Damon, do you have a picture of the cut top deck? I'd like to see what and how much you cut.
Thanks,
Oliver
DOTMAN is offline   Reply With Quote
Old 08-18-2016, 12:39 AM   #7262
Damon's Avatar
Thanks,
Oliver
at this page there is a photo, under the setup sheet: http://site.petitrc.com/reglages/yok...vorno20160512/
and in attachment a picture of the standard topdeck, the cut is on the red line
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 08-19-2016, 07:11 AM   #7263
mac853's Avatar
Dear anyone:
What is the difference of 2 front double joint universal:
B7-010FW
B7-010FWC(new)
and rear ones:
B7-010R
B7-010RA(new, despite aluminum bone)
Best regards
mac853 is offline   Reply With Quote
Old 08-19-2016, 11:52 AM   #7264
Damon, thank you for the pic. removing that little piece made a noticeable difference?
Old 08-20-2016, 06:37 AM   #7265
Djchow85's Avatar
Anyone used these spurs and know if they fit width wise
Not sure if rw make more than one type of spur in 48p
http://www.essentialrc.com.au/store/...p_image&pID=75
Lancer Corolla 3 Impreza
Djchow85 is online now   Reply With Quote
Old 08-20-2016, 06:48 AM   #7266
Damon's Avatar
yes, especially in corner entry
it works better with tires that aren't aggressive, like LRP, Hotrace, and so on
with Volante or Sorex I prefer the uncut standard or the new thin B7-00316H
Awesomatix A800
Awesomatix A800X
Old 08-21-2016, 03:02 PM   #7267
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Default Which DCJ are these?
After ordering both new and old Yokomo DCJ kits, I still don't have the right parts. So it's begs the question, what are these? The pins and barrels are much smaller than the Yokomo bits.
Dane is offline   Reply With Quote
Old 08-21-2016, 03:43 PM   #7268
evochick's Avatar
Lawrence they wont fit easily, RW spurs are a fraction wide to fit inside the carrier with standard screws,
I checked my spur collection for you and only have what you need in 64p spurs, the lowest 48P I could find was 72T
UnRetired
evochick is offline   Reply With Quote
Old 08-23-2016, 03:32 AM   #7269
If the yokomo do not fit, they are definitely aftermarket. Could be Roche, Arrowmax, Smokem Racing, Radtec, Yeah Racing etc. Sorry not much of a help. I think you would be better off buying a new set of DCJ's!
buzz777 is offline   Reply With Quote
Old 08-23-2016, 05:01 PM   #7270
shiston's Avatar
They look like Serpent DJC
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 08-23-2016, 09:53 PM   #7271
Serpent DJCs have at the inner bearing a bigger diameter than the outer. So definetly not Serpent
Worst87 is offline   Reply With Quote
Old 08-25-2016, 02:09 AM   #7272
Chrissy C's Avatar
Just been reading the RED RC coverage of the worlds and there are a couple of mentions of the soon to be released BD8 - so not a 'year' evolution, i.e. BD7 14,15 &16.
Has there been much speculation on what additions there will be? I assume the Samix/Techra style suspension mounts will be adopted, but what else? Maybe reverting to a slightly higher bulkhead set up to reduce the driveshaft plunge a little, lose the 'X' braces? Hopefully there won't be a wishbone / C-Hub / steering knuckle change as I've just built up a nice load of spares lol.
I can't see them changing the shocks after the SLFII introduction, so that really leaves chassis (weave / shape / thickness), but again this area has recently been updated with the introduction of the high and low traction chassis'. Other areas are the top deck and possibly amendments to the motor mount - although I think this area is pretty sound.
Maybe bulkhead updates to include a bearing style roll bar set up?
Any additional thoughts?
Chrissy C is offline   Reply With Quote
Old 08-25-2016, 10:21 AM   #7273
ATS
Pickthall is offline   Reply With Quote
Old 08-25-2016, 10:45 AM   #7274
Chrissy C's Avatar
Originally Posted by Pickthall View Post
ATS
Good spot! Possibly linked up to the suspected new RF suspension blocks, like the xray?
Old 08-25-2016, 11:24 AM   #7275
RC MARKET's Avatar
BD8 had ARS !!
RC MARKET is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
