Like Tree5Likes
Old 08-05-2016, 12:35 AM   #7216
Originally Posted by mac853 View Post
Could anyone tell me if is doable if remove upper deck post of bd7 2013 car?
Would affect the car or even damage it since motor mount has less screw?
Since i want to run bigger pinion.
It is not advisable to completely remove upper deck. You would have problems with tweak and slippage of front belt. Car would be a handful to drive too.
Why not running a smaller spur gear instead of a bigger pinion?
Also what you could do is raise the upper deck by inserting 1 to 2mm shims under upper deck, but always make sure there is enough clearance of the front belt
buzz777 is offline   Reply With Quote
Old 08-05-2016, 05:14 AM   #7217
mac853's Avatar
Not upper deck, that post which attached by screw in motor mount.
Do you know:
The smaller spur can use is 82t, due the biggest can use is 58t, you cannot reach closer than this condition.
If until 1 month from the event i would go still cannot put the car run less than 2.8 fdr, the only way is swap into 2014 lower deck.
mac853 is offline   Reply With Quote
Old 08-06-2016, 09:31 AM   #7218
chasingthepack's Avatar
just get the correct size spur,i use a 68 spur and a 37 pinion which is 3.6fdr using 48dp it also helps the balance of the car as the motor sits further back
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-07-2016, 06:42 AM   #7219
mac853's Avatar
Not good, not enough speed.
I need a car run 2.4 to 2.6 fdr.
If still has no solution, i would put 2014 main parts into this chassis.
Btw, thanks?!
Old 08-07-2016, 09:54 AM   #7220
Btw, thanks?!
can you post a pic or vid of the track?
Old 08-07-2016, 10:01 AM   #7221
Btw, thanks?!
66 spur and a 58 pinion 48dp would give 2.28
dont have that size pinion so cant check but im sure it would mesh,i have used 40/66 to get 3.30 and the motor still has plenty of travel left for a bigger pinion
Old 08-07-2016, 04:00 PM   #7222
mac853's Avatar
Maybe don't need.
To be honest, i have never been there.
But is local driver told me about that.
This ratio was him suggested me.
About other case, could anybody share me samix mount setup, please?
Best regards
Old 08-07-2016, 04:03 PM   #7223
mac853's Avatar
Problem of 2013 car is the biggest pinion can afford is 58t, different than 2014, which i know can reach more than 60t.
Old 08-07-2016, 07:33 PM   #7224
porsche928gs's Avatar
Maybe don't need.
Best regards
for samix setup use xray setups from petitrc and add .5mm spacer under every block.
porsche928gs is offline   Reply With Quote
Old 08-07-2016, 10:14 PM   #7225
mac853's Avatar
Why put spacer?
I use 1mm lowered mount is not for gain better traction?
About petitrc setup?
Which one, give me the name, please?
Old 08-08-2016, 02:45 PM   #7226
Why put spacer?
1mm lower is to be used for asphalt only for more grip. If that's the case use Hagberg's setup on asphalt for the blocks inserts only and Volker's euro championship setup for everything else.
Old 08-08-2016, 05:55 PM   #7227
mac853's Avatar
You right.
I use 1mm lower mount is really for a asphalt low-medium traction fast track which i would run further race.
Old 08-08-2016, 09:06 PM   #7228
AL1983's Avatar
Hi all,
Did anyone test the Samix mounts? Are they top quality or just a nice try like many aftermarket option parts? If you guys have pictures of one mounted please post one.
Thx.
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 08-09-2016, 01:03 AM   #7229
mac853's Avatar
Could anybody tell me if 2016 upper deck fits 2015 car.
Even motor mount position is different could be acceptable.
I just want to know if can use on Spice FWD.
Thank you
Old 08-09-2016, 01:29 AM   #7230
Chrissy C's Avatar
Hi Porsche928gs, can you point me in the direction of that Hagberg set up (that uses the insert spacers) please, as I have the Samix blocks, but not had a chance to bolt them on and play with inserts / measure widths of pin etc.
Is a good place to start as per the xray T4 15 manual?
AL1983, the blocks are well made, Samix make some nice stuff. As above, I've not got them on the car yet, but they feel solid and nicely made in hand. HTH
Chrissy C is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
