Like Tree6Likes
Old 07-25-2016, 02:32 AM   #7186
Andy63's Avatar
Originally Posted by mikeygar View Post
could be your o-rings are swollen, pressing hard the washer under the pin. I had that same problem and my diffs felt really tight and gritty. My 3k diff felt heavier than a 5k diff from an older car. Upon inspection the metal washer had wide scratch marks which probably caused the rough and heavy feel.
I changed my o-rings from the orange ones to the black ones (BD-500GM) and diffs now feel free with no binding.
Thats weird, i have the black ones. What part number are you using? Maybe i got the wrong ones :S
Cheers//
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 07-25-2016, 09:44 AM   #7187
Andy63's Avatar
Sry, i saw the part number now hahaha. But i had the tok-bd-500gob ones, is that the wrong o-rings???
Old 07-25-2016, 07:40 PM   #7188
mikeygar's Avatar
Trader Rating: 14 (100%+)
not sure what the difference is between the GM and GOB rings are, but disassemble your diff and remove the small gears that form a cross. Spin the outdrives and feel if they are sticky. Remove the gear inside and the pin, spin again, if there is a big difference in the way they feel then you have a problem somewhere there. Thats how I found my o-rings were swollen.
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 07-26-2016, 08:09 AM   #7189
What is general consensus of the 2016 version of BD7 versus 2014 version? Is the new car so significantly better that is worth of upgrading? What option parts are upwards compatible, can use springs, swaybars or front diff from the old car?
I am solely running on medium-high traction indoor carpet tracks.
micsa is offline   Reply With Quote
Old 07-26-2016, 09:24 AM   #7190
Jochim_18's Avatar
If you're strictly running carpet get the 2016 BD7.. they have the conversion kit at amain hobbies on sale.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-27-2016, 02:39 AM   #7191
Default TECHRA blocks
Hi BD7 racers. Has someone used the TECHRA blocks and give a feedback on quality, sloppy or not, and maybe durability? Would like to order them or the much more expensive samix blocks...
Thanks!
Worst87 is offline   Reply With Quote
Old 07-27-2016, 08:56 AM   #7192
Thanks!
I have the Techra blocks and they seem to be pretty durable, no apparent sloop, it looks like they use the same inserts as the VBC cars. The split mounts have more of a lip machined into them so there is less likelihood of popping the back of the insert out from arm impact. They are the same height as the stock parts so no difference in the lower roll center. Seem pretty decent.
Rodney Racer is offline   Reply With Quote
Old 07-27-2016, 10:06 AM   #7193
Hey Rodney thanks a lot for your review! So its not possible to change roll center height via inserts right? Still willing to order them
Old 07-27-2016, 03:00 PM   #7194
Thats correct, only one height for the inserts, lower roll center done via spacers like original intent. Samix use the xray inserts with the two variables build in.
Old 07-27-2016, 03:04 PM   #7195
They are .5mm lower than the standard blocks
kdempsey is offline   Reply With Quote
Old 07-28-2016, 10:12 AM   #7196
RC MARKET's Avatar
New Yokomo Belt
RC MARKET is offline   Reply With Quote
Old 07-28-2016, 01:33 PM   #7197
anyone know what the spring rates are on the YOK springs? want to compare to other springs like xray and axon etc????
madmikepags is offline   Reply With Quote
Old 07-29-2016, 09:07 PM   #7198
SLOW 77's Avatar
Trader Rating: 27 (100%+)
Originally Posted by evochick View Post
Sorry yes about 2mm wider, i also made the front wide as well i think it was 5.0 fr and 5.7 ff
This wide setup is aparently great on carpet for stock, but i am yet to run on carpet.
For high bite new CRC black carpet, what rear combo is a good start?
I am going to try the 5.7/5.0 wide front.
Curious on what combo in the rear with 2.5 toe?
SLOW 77 is offline   Reply With Quote
Old 07-30-2016, 04:48 AM   #7199
DirkW's Avatar
For ~2.5 rear toe (or more precise: between ~2.4 and ~2.6, no combo gives exactly 2.5, when calculated), you could use either of the following combinations:
#1: 2.0/5.7 (most commonly used for 2.5 toe)
#2: 2.7/6.4 (for a 0.7mm wider track)
and for even wider track (but these mounts were actually introduced for the use with the shorter arms) you could theoretically (never tried any of these) also use:
#3: 3.5/7.2 (0.8mm wider than #2)
#4: 4.2/7.9 (0.7mm wider than #3)
#5: 5.0/8.7 (0.8mm wider than #4)
Dirk
My On-Road cars: ((Xray T4'18)) | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: ((Yokomo YZ-2 DTM)) | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18)) | ((??Yokomo YZ-4SF??))
DirkW is offline   Reply With Quote
Old 07-30-2016, 02:41 PM   #7200
bertottius's Avatar
Trader Rating: 19 (100%+)
Can someone tell me what the overall length of a standard rear suspension arm is please? I have a pair of arms that look short to me. Thanks.
CHRIS BERTOTTI
Alpha Pace Racing
bertottius is online now   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
