Like Tree5Likes
Old 07-15-2016, 06:40 AM   #7171
bertottius's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Chrissy C View Post
Thanks Chris, after I posted I decided to stop being lazy and look back through the thread as I recalled seeing something EvoChick posted a while back, she said:
"I can confirm no issues with the 7.9 rr and 4.9 rf combo
Plenty of belt room with diff in high position"
So I suppose 7.9 minus 4.9 = 3 deg toe?
Evochick, did you ever try out this combo on the track? Any good?
What width does that take the car too?
Cheers.
Oh ok. Good to know. Is this on a 2016 chassis?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 07-15-2016, 06:44 AM   #7172
evochick's Avatar
Cheers.
Yep tried it on outdoor low grip track but just took too much bite away from the car, would probably work on super low grip, to make more stable and easier to drive but wouldnt be quick. My above setup still works when the track temp was in single digits (its winter here in Sydney)
UnRetired
evochick is offline   Reply With Quote
Old 07-15-2016, 06:48 AM   #7173
Chrissy C's Avatar
Thanks Dirk, I read your other comment when you originally posted it, but didn't really take it in, it makes more sense now, thank you.
I'm just trying to line up a few set up changes that I might like to try, and see what gaps I have in the suspension blocks. I note there are a lot of new parts in this area of late (i.e. lowered 1mm blocks, brass blocks, insert type blocks etc), so I'm just trying to get my head round it.
A couple of questions for you Dirk
With the standard rear suspension mount set up, do you know roughly what width you get?
Where do the governing bodies tend to measure track width from? ends of axle - which would be the widest part, or other
What would you expect from a wider rear track width?
Thanks.
Chrissy C is offline   Reply With Quote
Old 07-15-2016, 06:49 AM   #7174
evochick's Avatar
Sorry yes about 2mm wider, i also made the front wide as well i think it was 5.0 fr and 5.7 ff
This wide setup is aparently great on carpet for stock, but i am yet to run on carpet.
UnRetired
Old 07-15-2016, 06:53 AM   #7175
Chrissy C's Avatar
Thanks Evo. Looking back at what Dirk said on the RF and RR set up, do you think the lack of rear toe hurt you / your set up?
Thanks for the FF & FR combo, I wasn't sure of the combo, but heard same as you. Seems the 419x is rocking a wide front end as standard, so maybe worth trying on asphalt as well?
Old 07-15-2016, 06:57 AM   #7176
Chrissy C's Avatar
Yes Chris, a 2016 chassis, but it will translate to all BD7's...although from reading the last few posts, this set up doesn't look advisable!!
Old 07-15-2016, 07:26 AM   #7177
DirkW's Avatar
Usually more stability, but less grip. Like Evochick said, an option for carpet (one way to avoid traction rolling).
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 07-15-2016, 08:50 AM   #7178
Default 1mm lower suspension mounts
Just wondering about the 1mm lowered suspension mounts coming out. Are these more useful for asphalt setups? It seems like the carpet setups run raised lower roll center settings, so are the standard mounts a better choice for carpet? Thanks
Rodney Racer is offline   Reply With Quote
Old 07-17-2016, 01:31 AM   #7179
Jochim_18's Avatar
1mm lowered suspension mount lower the roll center of the car which is good for asphalt for more over all grip.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-22-2016, 02:49 AM   #7180
RC MARKET's Avatar
SAMIX BD7 1mm Lower Suspension Mount
YOKOMO Touring Car BD-7-sam-sm-403s-1.jpg   YOKOMO Touring Car BD-7-sam-sm-603s-1.jpg
RC MARKET is offline   Reply With Quote
Old 07-22-2016, 02:52 AM   #7181
Chrissy C's Avatar
RC Market, do you use the xray bushing set (362315) with these?
Old 07-22-2016, 05:42 AM   #7182
Yep you need a set of the T4 inserts to go with. Not sure about the measurements thought.
http://www.rcsamix.com/index.php/fea...-full-set.html
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 07-24-2016, 09:17 AM   #7183
Andy63's Avatar
Hello!
I have problems with my diff, it sounds like i have sand grinding in them. I dont know why but i have never had this problem before with other brands. I have 2 diffs for my 2016 bd7, and both sound and feel like they have sand in them. I tried changing gears but the same after 1 run.
PLEASE HELP!
cheers//
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 07-24-2016, 10:16 AM   #7184
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Andy63 View Post
Hello!
PLEASE HELP!
cheers//
could be your o-rings are swollen, pressing hard the washer under the pin. I had that same problem and my diffs felt really tight and gritty. My 3k diff felt heavier than a 5k diff from an older car. Upon inspection the metal washer had wide scratch marks which probably caused the rough and heavy feel.
I changed my o-rings from the orange ones to the black ones (BD-500GM) and diffs now feel free with no binding.
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 07-24-2016, 08:11 PM   #7185
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Hello all,
I have a TC7 but looking to pick one of these up, how much better is the BD7 and what should I expect?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
