Like Tree6Likes
Old 07-06-2016, 05:31 PM   #7156
evochick's Avatar
without going too radical with modified parts, I have found the following setup as a good starting point for most tarmac tracks
For a big fast nitro track I usually switch to 15 shocks with the longer shock towers (450 oil HPI silvers). But that's the only change to the starting point.
2 things that really help steering 4.5mm hex's and 1.5mm bump steer.
Removing the inner top deck screws helps overall traction and doesn't seem to effect turn in.
I get to have a drive tomorrow so will be testing some more SMJ spring combo's
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 07-08-2016, 10:05 PM   #7157
AL1983's Avatar
Hi,
I've seen some people put a spacer on the top part of the 2016 shock body to prevent the cap from screwing all the way down and which also gives the shock a polished ring look. Would somebody know which size spacer these are or where I can get them?
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 07-09-2016, 08:09 PM   #7158
The Evicerator
Anyone know of a source for pss sleeves/pistons for the 2015/long shocks other than T Works?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 07-10-2016, 07:25 AM   #7159
I have picked up a second hand 16 car, had 15 before hand. But I have this hinge pin holders and never gone from the kit ones on the 15. But I have a few which came with the deal. But I don't know if they are for the rear or front, anyone help because I have never used this before. But the manual says 43.5mm but they don't say that on the hinge pin holders
3.9
4.2
4.9
5.7
3.5 on the front on both
6.4 on the rear with 2 in the front on the rear of the car
But trying to under stand what it does to front and rear? But when I ask people at my local track are not helpful and don't have time to explain to me what it does. And my car is not as settled as there's, I know I am not the fastest but being lapped 5 times is starting to get dishearting
tiny tom is offline   Reply With Quote
Old 07-10-2016, 07:42 AM   #7160
bertottius's Avatar
Trader Rating: 19 (100%+)
3.9
4.2
4.9
5.7
the smaller the number, the narrower the track. Just put a "4" in front of it. So, a "3.9" is really a "43.9" ETC.
CHRIS BERTOTTI
Alpha Pace Racing
R.C. Hobbies
MSA Distribution
bertottius is offline   Reply With Quote
Old 07-10-2016, 12:21 PM   #7161
DirkW's Avatar
^This.
3.9
4.2
4.9
5.7
Standard kit setup is 3.5 FF / 3.5 FR / 2.0 RF and 6.4 RR.
Many (if not most) setups I found online use 4.2 on FF and 5.7 on RR instead. (putting 0.5 degrees of "toe out" to the front hinge pins - not the wheels) and reducing rear toe-in from 3.0 to 2.5 degrees.
So basically what the different pieces do, is altering the track width and the toe settings of the car.
Dirk
My On-Road cars: ((Xray T4'18)) | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: ((Yokomo YZ-2 DTM)) | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory>>>((??Yokomo YZ-4SF??)) | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18))
DirkW is offline   Reply With Quote
Old 07-13-2016, 09:55 PM   #7162
Jochim_18's Avatar
Originally Posted by mikeygar View Post
Did you put more camber and higher ride height? Are you using the standard suspension blocks or did you go wider?
Glad you got it working for you. In our indoor asphalt track, car lacks overall grip as well. Been 6 months and I still don't have a baseline setup :-(.
Did more testing on the car made a Lil more changes now it's getting more like the feel of my 14'... problem with the car on outdoor asphalt track is roll. It doesn't roll like the old car due to lower center of gravity. I lower the roll center 2mm to give it more roll to generate mechanical grip when cornering, - 2degree camber.
Pulled the suspension blocks out of my 14'
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-13-2016, 09:59 PM   #7163
Suspended
Raising the roll center will give it less roll, and vice versa....
bertrandsv87 is offline   Reply With Quote
Old 07-13-2016, 11:10 PM   #7164
Jochim_18's Avatar
I mean I lowered the roll center lol...
Old 07-14-2016, 09:08 PM   #7165
Shop Owner
rcmart's Avatar
Our friends over at RC-Xpress are looking for test drivers for their newly released DCJ's for Yokomo BD7! Head over to their page here to apply!
rcMart.com - We Help People Have Fun with RC
Fast worldwide delivery & low shipping rates
WebStore: www.rcMart.com
Blog: blog.rcmart.com
FB: www.facebook.com/rcmart
IG: www.instagram.com/rcmart2001
rcmart is offline   Reply With Quote
Old 07-15-2016, 02:22 AM   #7166
RC MARKET's Avatar
SAMIX Option Parts for BD7
rcmarket.com.hk
YOKOMO Touring Car BD-7-sam-sm-403s.jpg   YOKOMO Touring Car BD-7-sam-sm-603s.jpg   YOKOMO Touring Car BD-7-xr-362315.jpg
RC MARKET is offline   Reply With Quote
Old 07-15-2016, 05:24 AM   #7167
Chrissy C's Avatar
Hi all, would appreciate some help...
What combinations of FR and RR suspension mounts would I need to go wider than the kit 2.0(FR) and 6.4(RR), but still give me 3deg rear toe overall.
Thanks all
Chrissy C is offline   Reply With Quote
Old 07-15-2016, 07:09 AM   #7168
bertottius's Avatar
Thanks all
I think 46.4 is the widest you can go with the suspension mounts. You can get wider wheel hexes or put shims behind your wheels. Are you on carpet or asphalt? If you are on asphalt, you can always go a bit more narrow on the front.
CHRIS BERTOTTI
Alpha Pace Racing
R.C. Hobbies
MSA Distribution
Old 07-15-2016, 07:17 AM   #7169
Chrissy C's Avatar
Thanks Chris, after I posted I decided to stop being lazy and look back through the thread as I recalled seeing something EvoChick posted a while back, she said:
"I can confirm no issues with the 7.9 rr and 4.9 rf combo
Plenty of belt room with diff in high position"
So I suppose 7.9 minus 4.9 = 3 deg toe?
Evochick, did you ever try out this combo on the track? Any good?
What width does that take the car too?
Cheers.
Old 07-15-2016, 07:38 AM   #7170
DirkW's Avatar
Unfortunately, it's not that easy to calculate, no. See here.
That combination should leave you with quite a bit less toe than 3 degrees, since RF changes by 2,9mmm and RR only by 1,5mm (Change would have to be equal on both to keep the kit's 3 degrees)
Not easy to say, since the toe angle changes, but probably something around 2mm overall width.
Question is: why do you want to widen the rear in the first place?
Dirk
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
