Like Tree6Likes
Old 05-16-2016, 05:22 AM   #7051
DirkW's Avatar
Originally Posted by Robbob View Post
Need to find a 42mm or preferably 44mm front DCJ that will work in the BD7 [...]
Appreciate any help for my project. Thanks
Originally Posted by M3CSLDreamin View Post
I've used Spec-R DCJ with no problems.
And do they also fulfill the special length requirements that were asked for? After all, Robbob wants them to be quite a bit longer than for example the original Yokomo DCJs, which are 40.6 (front) or 39.1 (rear) - so both nowhere near the length that was asked for. But unless Robbob is really doing some major modifications on his special project, creating a much wider front (200mm car?), I don't think such long DCJs could ever fit. After all, that length is about what the normal universal drive shafts have (44.0 / 45.5).
Dirk
My On-Road cars: ((Xray T4'18)) | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: ((Yokomo YZ-2 DTM)) | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory>>>((??Yokomo YZ-4SF??)) | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18))
DirkW is offline   Reply With Quote
Old 05-16-2016, 05:37 AM   #7052
Not wider - need them to reach a little further into the out drive cups. But your info gives me other ideas now, Thanks
Robbob is offline   Reply With Quote
Old 05-16-2016, 05:52 AM   #7053
DirkW's Avatar
I just took a look at my cars... 42 instead of 40.6 may indeed fit. That's only 1.4mm longer than original after all, and my cars sure have enough space left. But 44... I wouldn't bet any money on it.
But I'm curious about what you're trying to do...
Dirk
Old 05-16-2016, 10:46 AM   #7054
Got any leads on a set of 42?
They're the missing link in a cross breed using the BD7 suspension and another drive train.
Old 05-16-2016, 10:52 AM   #7055
DirkW's Avatar
Sorry, no idea.
Dirk
Old 05-16-2016, 03:01 PM   #7056
Djchow85's Avatar
I'm running an FDR of around 3.2 for 21.5t also and used the sound method to mesh. When gearing so high I found the window of having a very quiet mesh very small versus when gearing on my buggy for modified. Wondering if it's got to do with more teeth on the pinion.
That is, for the bd7 there's a lot less gap in mesh. Not sure if this is expected but sounds okay after giving it a quick test in the street
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 05-16-2016, 03:45 PM   #7057
DirkW's Avatar
Sound method for gear mesh? I've never heard of that (or seen anyone do it). How does it work?
Dirk
Old 05-17-2016, 06:06 AM   #7058
Djchow85's Avatar
Have the motor and pinion near flush to the spur. Apply light to medium throttle and slowly back off. Once the mesh is at its quietest, lock the motor in place. Mesh seems okay. New to 21.5t coming from 4wd mod buggy
Old 05-17-2016, 11:16 AM   #7059
DirkW's Avatar
Interesting... really never heard of this before.
Dirk
Old 05-23-2016, 11:24 AM   #7060
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Default Problems with Belt rubbing pinion
I have to run my pinions backwards to get mesh on my spur gear due to my motors key on the rotor moving the pinion too far out to get full gear width mesh . When I do this, the center shank(where the grub screw is on the pinion gear rubs on my front belt under some load circumstances.
Does anyone have the same problem and what do they do to resolve it. Also, is there any manufacturer that makes super narrow pinion gears to eliminate this issue since the X-ray narrow pinion gears don't help.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 05-23-2016, 12:18 PM   #7061
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I use Panaracer gears
No issues
http://www.tqrcracing.com/shop/produ...no=1&o_pg_no=1
Old 05-23-2016, 04:05 PM   #7062
RBLove's Avatar
Trader Rating: 72 (100%+)
I space my motor out 1mm.
RBLove is offline   Reply With Quote
Old 05-23-2016, 08:40 PM   #7063
Just finished my 2016 conversion from my '14 ........... Damn this thing is sexy.
What would anyone recommend for an indoor body? I always liked the P37 but never cared much for the Mazda's. Something balanced but aggressive?
Old 05-24-2016, 02:12 AM   #7064
RC295's Avatar
Default Kit for low-medium grip and bumpy asphalt
Need info. Which kit best for low-medium grip and bumpy asphalt. BD7 2014, 15 or 16??
Ty for help
[SPONSORED BY ME, MYSELF & I]
RC295 is offline   Reply With Quote
Old 05-24-2016, 10:52 AM   #7065
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
back in the days a lot of us did this trick , I know I did..
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
