Like Tree6Likes
Old 05-10-2016, 09:13 PM   #7036
Adonis_mp's Avatar
Originally Posted by evochick View Post
Serpent, panaracer, leespeed, Xray,
Thanks!
I'm going to use this car for USGT, any one have a set for a large med/high grip asphalt track? Specially gearing, coming from AE, I'm sure it's a little different.
Is it really necessary to get the floating servo mount and steering rack or can I stay with what the kit came with?
Adonis_mp is offline   Reply With Quote
Old 05-10-2016, 10:10 PM   #7037
Migigu's Avatar
Xray Spur can only use two screw, not perfect
I would sometimes look at Axon! i switch from Panaracer to Leespeed to Axon ...
For me is the Axon Spur and Leespeed Titan pinion best combo
Migigu is offline   Reply With Quote
Old 05-11-2016, 02:10 AM   #7038
Andy63's Avatar
I posted my first bd7 setup at www.andrefossto.wordpress.com hopefully it can help someone with the setup of the new 2016 car.
For me the car was very stable at high speed. The track was super low grip. A unprepped outdoor asphalt track wich takes time to build up grip.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 05-11-2016, 02:34 AM   #7039
DirkW's Avatar
Correct, Xray only fits when you're using half the screws (could theoretically lead to some wobble - don't know if it's a issue in reality though).
So Axon gears fit? Even with normal button head screws? IIRC some spurs were a little too wide for that (on the inner part, not the teeth), that's why I haven't tried anything but Panaracer yet. That and the fact that Axon doesn't (yet?) sell the size I'd like...
Dirk
Current cars: Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): (Xray T4'18) | Xray X1'17(8) | Yokomo YZ-2 DTM | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 05-11-2016, 01:42 PM   #7040
Migigu's Avatar
Panaracer, Leespeed and Axon are the same width at hole
I have with all Spur screws no problems for about stand duck
Panaracer 2.01mm
Axon 1.98mm
Leespeed 2.08mm
What is interesting is the weight
Panaracer 114Z 4.2g
Axon 116Z 3.4g
Leespeed 115Z 4.22g
Axon Spur fit well
Old 05-11-2016, 02:03 PM   #7041
DirkW's Avatar
Great to hear. Now I only need them to make some smaller TC spurs.
Dirk
Old 05-11-2016, 02:25 PM   #7042
Migigu's Avatar
okay, I've seen it ... axon have only Spur 100-116
I would otherwise recommend Leespeed Spur... I was better pleased with this as Panaracer regarding quality and durability
Old 05-13-2016, 02:04 AM   #7043
Hello,
I would like to know the length in millimeter of the anti roll bar stopper (B7-412S2) thank you.
Rally-game proto Clo-products - Toro 150a - HW 2250kv - Turnigy a-spec - Futaba 3PKS
Tamiya M03S mini cooper - Novak 410M1C - Orion Core 27x1
Kyosho Mini-Z MR03 and MA015
Xray T4-2014 - Hobbywing V3.1 - LRP X20 spec 10.5 - Turnigy ultimate
Xray X12-2014 - Reedy Mach2 6.0
christophed83 is offline   Reply With Quote
Old 05-13-2016, 12:19 PM   #7044
Need to find a 42mm or preferably 44mm front DCJ that will work in the BD7 ..... any one know of one?
CSO shows one to fit the Yokomo but really unsure of the quality or their fit.
Appreciate any help for my project. Thanks
Robbob is offline   Reply With Quote
Old 05-13-2016, 01:34 PM   #7045
DirkW's Avatar
Originally Posted by christophed83 View Post
Hello,
21.75mm according to my calipers.
Dirk
Old 05-14-2016, 12:07 AM   #7046
thank you
Old 05-14-2016, 08:16 PM   #7047
snip3r66 is offline   Reply With Quote
Old 05-15-2016, 08:24 PM   #7048
Djchow85's Avatar
For those running the floating battery mounts how does this compare to taping the battery under the chassis
And is there a cheaper alternative than the yokomo ones
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 05-15-2016, 09:11 PM   #7049
I've used Spec-R DCJ with no problems.
Adrian Clements
Team Meech
Yokomobd7 2016
Kyosho MP9E TKI
M3CSLDreamin is offline   Reply With Quote
Old 05-16-2016, 03:44 AM   #7050
DirkW's Avatar
It's supposed interfere less with chassis flex. And I think it's easier and nicer to operate. Although I have modified it a little and will continue to do so, in order to get rid of the tape and use velcro instead.
On my 2014, I tried the Spec-R battery holder. Didn't fit perfectly, but could be made to work. I much prefer what I now have over that.
Dirk
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
