Like Tree5Likes
Old 05-02-2016, 03:17 PM   #7021
DirkW's Avatar
Yep. What he said.
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 05-02-2016, 04:08 PM   #7022
Great , thank you for the reply.
I would think that is something I should invest in when I get the kit.
wcalaker is offline   Reply With Quote
Old 05-02-2016, 08:29 PM   #7023
Trader Rating: 14 (100%+)
subscribing. Seriously considering a RS3. Kind of stumped why it doesn't see more attention. Looks like it has all the important things,other than a better spool. Just lacks the bling. First TC i have had since a TC6.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 05-03-2016, 03:24 AM   #7024
DirkW's Avatar
IIRC, the RS3 is basically a BD7'14, just with some aluminium replaced with plastics, i.e. spool, lower bulkheads, FF and RR suspension mounts (FR and RF are aluminium) and it comes without sway bars. Also, some plastic parts like the arms (probably C-hubs and knuckles as well) seem to be normal plastic, instead of the graphite version (judging just by the looks, I don't know if that's really the case.) But then again... it's only about half the price of a "full" BD7 kit.
Dirk
Old 05-03-2016, 04:58 AM   #7025
Thanks. It seems the only things it would need are the spool and the sway bars.
Old 05-03-2016, 05:55 AM   #7026
DirkW's Avatar
Maybe aluminium FF and RR suspension mounts for tuning purposes, as well. But probably different sizes than kit, since many setups use 44.2 instead of kit* 43.5 as FF (0.5° toe out at the hinges, instead of 0°) and 45.7 instead of kit* 46.4 as RR (2.5° rear toe, instead of 3°), assuming that it comes with the standard kits 43.5 FR and 42.0 RF split blocks.
Oh and floating servo mount or a direct mount servo is also nice to have.
*) referring to the normal BD7 kits - not sure what size the RS plastic mounts actually are
Dirk
Old 05-04-2016, 02:22 PM   #7027
I just built a BD7 RS and it is indeed a very nice kit. The standard rear toe is 3.5 degree but a 2.5 mount comes on the tree as well. Not sure if the arms are carbon but they are quite stiff and the whole car is slop free. Quite impressive actually.
speed90 is offline   Reply With Quote
Old 05-05-2016, 01:52 AM   #7028
nice chassis
TG MAN is offline   Reply With Quote
Old 05-08-2016, 06:58 PM   #7029
bertottius's Avatar
Trader Rating: 19 (100%+)
Can anyone recommend a good tire/insert/wheel combo for the BD7 for open tire 17.5 on asphalt? I never ran open tire before so, I'm not sure what the proper way to go is. Thanks
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 05-08-2016, 07:12 PM   #7030
tbrymer's Avatar
Sorex, Yellow insert. Just buy the ones that suite your temperature.
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 05-08-2016, 08:13 PM   #7031
AL1983's Avatar
Hi,
Which front and rear stabilizer set is the one for 2016? Are the previous stabilizer the same? Confused with all the updated part numbers.
I had for my 2014 and 2015 front BD-412W and rear BD-412RS (silver with marking on flag) are these still OK?
Thx for help.
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 05-09-2016, 02:20 AM   #7032
DirkW's Avatar
The bars of the stabilizers didn't change, but the turnbuckles between the plastic ballcups (for the back) were replaced by grub screws (to make them shorter, since they're now mounted lower, because of the lower bulkheads.) The front rods still fit, but you need to screw them deeper into the plastic, to get them shorter over all as well.
Dirk
Old 05-10-2016, 01:41 PM   #7033
New BD7 up in the for sale threads...
Old 05-10-2016, 06:02 PM   #7034
Adonis_mp's Avatar
Default Started my build
I started my build today and realized that the kimbrough spur doesn't fit unless I drill new holes. What other brand of spurs can I use?
Adonis_mp is offline   Reply With Quote
Old 05-10-2016, 08:18 PM   #7035
evochick's Avatar
Serpent, panaracer, leespeed, Xray,
UnRetired
evochick is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
