Like Tree6Likes
Old 04-05-2016, 02:04 PM   #6961
miller tyme's Avatar
Originally Posted by TJames987 View Post
For bd7 2015 what spring do u all recomend for outdoor? Thinking about Ride Reds supposed to be same as HPI silvers
I ran the Ride Reds, last year since the HPI silvers were unavailable, worked about as well as the silvers I borrowed a time or two.
Ken Miller
RCTarget - Capricorn - Sanwa - Pro Level RC - MAX Power - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 04-05-2016, 02:06 PM   #6962
HPI SILVER
Pickthall is offline   Reply With Quote
Old 04-06-2016, 02:59 AM   #6963
Andy63's Avatar
Hello! I am new to the bd7 2016 family and hope i will enjoy this ride. I will run my 2016 outdoors on high speed asphalt with med-low grip. What springs do you think fit best for this condition? Thanks!//www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 04-06-2016, 05:38 AM   #6964
Migigu's Avatar
Yokomo silver or smj silver
both go well
Migigu is offline   Reply With Quote
Old 04-06-2016, 11:30 AM   #6965
Andy63's Avatar
both go well
Thanks! Seems like yokomo silver is standard on the 2016, guess i am lucky :P
I need some advise on options i might need to get, i know i should get the ALU steering block, anything else good to have as option for both asphalt and carpet?
Old 04-06-2016, 11:35 AM   #6966
bertottius's Avatar
Trader Rating: 19 (100%+)
I would recommend you get the RSD front bumper brace.
http://www.reflexracing.net/RSD-Yoko...ce_p_2572.html
Also, any of the Yokomo upgrades are nice. If you run carpet, you should get the Yokomo aluminum chassis plate.
CHRIS BERTOTTI
Alpha Pace Racing
bertottius is offline   Reply With Quote
Old 04-06-2016, 10:16 PM   #6967
Migigu's Avatar
i think sub block is first important parts to you get.
asphalt FF 44.2 and RR 44.9 and 45.7
carpet FF 44.2 FR 44.2 singel and RR 45.7. weights in center 20g and front 20g would take be important to.
Old 04-07-2016, 05:42 AM   #6968
Ralph289's Avatar
Have had some good luck with the Hobbypartz D770 Solar servo, but seems they always sell out. And suggestions on a good servo without spending a ton of $$.
1970 Firebird VTA TC4
TOP Photon EX 17.5 Touring
TOP Photon EX 25.5 VTA
RC10T4.1 3300KV
Ralph289 is offline   Reply With Quote
Old 04-07-2016, 08:01 AM   #6969
I've had good luck with Sanwa ERS-971 ( http://sanwa-denshi.com/rc/car/servo/ers-971.html )
Metal gears, plenty fast and strong. Mine suffered quite a few bad hits and are still going good with minimal backlash.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 04-07-2016, 09:40 AM   #6970
Futaba 9550 used or 9551 used or new both low profiles, metal gear dual ball bearing are nice in touring car
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 04-07-2016, 11:27 AM   #6971
CL
CL's Avatar
Trader Rating: 32 (100%+)
I tried them and they're not so good. After a month of use, they make a lot of buzzing noise.
More racing and less typing!
CL is offline   Reply With Quote
Old 04-07-2016, 11:47 AM   #6972
Default Quick release battery holder/ strap
Hi,
I will be racing in a enduro event later on the year, it's a 6 hour race. Need a quick release battery holder or strap that will be secure enough for racing but super fast to in regards to changing lipos. Any suggestions? It's for bd7 -16 btw
Will smith is offline   Reply With Quote
Old 04-07-2016, 01:51 PM   #6973
JimmyMac's Avatar
Velcro? Velcro over straps and Velcro under the batteries? Unstrap it. Pull off the battery. Push down the new battery and strap it back in. Simple and easy. Just put one Velcro strap at the back of the battery and one at the front (underside) to prevent the battery from slipping out from the side. Velcro strap on top will hold it in.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-10-2016, 08:34 PM   #6974
AL1983's Avatar
Hi,
The one piece RearFront suspension mount used in this picture is the same as the one normally used for FrontFront? Or is it different?
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 04-10-2016, 09:19 PM   #6975
evochick's Avatar
Originally Posted by AL1983 View Post
Hi,
looks like a standard 4.9 block with some more spacers, he is also running the diffs in the high position,
rear I am guessing it the narrow arm 7.9 block, I am also assuming no belt rubbing issues with the diff high, if I find some time tonight ill see if that's what it is, as I have all those blocks.
so it looks like a wide track is something worth trying,
I couldn't see what the FF block is but the FR block was the split 5.0
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
