Like Tree5Likes
Old 03-16-2016, 09:32 AM   #6886
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by fasfury View Post
İ am running stock and also tried kit silvers but xrays just give more front bite under hard braking, we had a hairpin at the end of straight so preferred 2.5-2-8s.
That makes sense
Those springs have more initial rate than Silver or Pink
What body are you using
I think low diffs almost always the better setup
Was your car sliding front & rear the same ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-16-2016, 09:53 AM   #6887
Trader Rating: 15 (100%+)
Maybe for stock or for the old CRC carpet, but I personally don't agree for the new CRC carpet or for mod. My impression when going diffs high at Denver was that it made the car feel a bit more free and also made the car feel more consistent over the entire run. I haven't run stock or on the old carpet, though, so who knows
I know that Andrew H was running diffs high with silver/black springs and a front gear diff with ride hard putty at ROAR nats. Word from the ETS guys was also diffs high on carpet - 'always'. But that would, again, be for mod.
So maybe the moral of the story is to trust no one
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 03-16-2016, 10:23 AM   #6888
Cool
Dude says he's looking for side grip
Low diffs fo sho
I always run a 2.5m front diff, but that's just a preference
Our carpet is less carpet, more carpet backing these days, maybe similar to ETS rug
Old 03-16-2016, 10:52 AM   #6889
That makes sense
PF mazda 6 lw.
Front was loose but the biggest problem was rear.
fasfury is offline   Reply With Quote
Old 03-16-2016, 10:55 AM   #6890
PF mazda 6 lw.
Loose where
On Power
Off Power
Mid corner
everywhere ?
Old 03-16-2016, 11:18 AM   #6891
Low diffs fo sho
Sorry - 'I think low diffs almost always the better setup' - didn't think you were referring to just this case. Carry on.
Old 03-16-2016, 12:06 PM   #6892
dawgmeat's Avatar
Low diffs fo sho
Can you post your set-up for the new CRC carpet, thanks
dawgmeat is offline   Reply With Quote
Old 03-16-2016, 12:18 PM   #6893
bdmpastx's Avatar
I don't know how someone didn't have enough traction on the new carpet. I was driving it on edge. That new stuff has instagrip. The stock out of the box setup was pretty dang good with that RSD pink rear springs, Gold fronts and the aluminum chassis. This was also with a LTCR body.
bdmpastx is offline   Reply With Quote
Old 03-16-2016, 03:25 PM   #6894
Don't have a setup for new CRC Black carpet
Our old CRC rug is several years old and missing most of it's fibers in the sweepers
Still fun though
+ YouTube Video
Old 03-17-2016, 01:17 AM   #6895
Damon's Avatar
Shock positions:inner 2nd hole mm450 shock oils, 3mm inner 1mm outer upper link shims, 5k diff, 5.8-4.8 downstops, 5-5.2 ride height, 2degrees camber, ff4.2 fr3.5 rf 2 rr6.4 susp holders, short front wheelbase, standart rear wheelbase 0 bumpsteer 0 ackerman, standart rollbars and high diff cam positions, removed motor mounts upper deck screw.
Used volante tires and schumacher sxt3.0 additive.
Car was terrible with x braces, then I removed and was better and put the shocks from 3rd hole to 2nd and better, but still was very hard to drive. It just couldnt create any side grip. Also tried different sauces and xray front2.5-2.8 rear 2.7 springs but nothing.
wondering what would happen if I had put the diffs in low position.
few things to try:
- ff4.9 fr4.2(separate) rf2.7 rr6.4: wide car on carpet seems more stable, but still with good corner speed, also on smaller tracks
- diffs down
- graphite C-hubs
- 1.3 post sway bar
- 4 Yokomo blue springs
- Hudy additive
- 5.4 / 4.4 downstop (try also 5.0 / 4.0)
- long post camber link (you need shorter threaded balls)
- 4 mm inner ant link shims
I made several tests on carpet and asphalt, in my opinion the car needs to roll much more than the old 2015, has anyone tried in this direction?
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 03-17-2016, 01:29 AM   #6896
Originally Posted by Damon View Post
few things to try:
- diffs down
- graphite C-hubs
- 1.3 post sway bar
- Hudy additive
The carpet was 2 years old so it doesnt have grip like new. Thanks for the tips. I will buy the suspension mounts. I will race on tarmac from now on so will these settings still may helpful on medium grip asphalt?
Old 03-17-2016, 06:30 AM   #6897
few things to try:
- diffs down
- graphite C-hubs
- 1.3 post sway bar
- Hudy additive
Diffs up should give more roll
Old 03-18-2016, 12:18 AM   #6898
Damon's Avatar
on tarmac it depends on the tires you use, but generally I found that wide car doesn't give advantages, I use almost always ff3.5 fr3.5 rf2.0 rr5.7, very close to the basic setting
diff always down
other settings can be useful, you can try, except the additive obviously
Awesomatix A800
Awesomatix A800X
Old 03-18-2016, 12:21 AM   #6899
Damon's Avatar
yes, but for me the diffs down generate more overall traction in all cases
Awesomatix A800
Awesomatix A800X
Old 03-18-2016, 07:08 AM   #6900
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
