Like Tree6Likes
Old 03-03-2016, 08:09 AM   #6826
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Anyone here tried any of the floating steering systems (Samix, Spec-R/RSD)?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-03-2016, 08:57 AM   #6827
dawgmeat's Avatar
Originally Posted by mikeygar View Post
Looked all over and can't find it. Does anyone have a spring chart for the short Yokomo springs?
SLF Short Shock II Spring Chart:
Softer
YOKB7-14600: Black
YOKB7-14575: Blue
YOKB7-14550: Silver (standard)
YOKB7-14525: Pink
YOKB7-14500: Gold
YOKB7-14475: White
Harder
dawgmeat is offline   Reply With Quote
Old 03-03-2016, 09:11 AM   #6828
mikeygar's Avatar
Trader Rating: 14 (100%+)
thanks dawgmeat :-D would you know the spring rates?
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 03-03-2016, 12:00 PM   #6829
bdmpastx's Avatar
Softer
YOKB7-14600: Black Spring Rate 6.00
YOKB7-14575: Blue Spring Rate 5.75
YOKB7-14550: Silver (standard) Spring Rate 5.5
YOKB7-14525: Pink Spring Rate 5.25
YOKB7-14500: Gold Spring Rate 5.00
YOKB7-14475: White Spring Rate 4.75
Harder
Added the Rates which align with the last 3 numbers of the Part. Imagine that lol.
bdmpastx is offline   Reply With Quote
Old 03-03-2016, 01:13 PM   #6830
evochick's Avatar
I thought it was the spring turns rather then the actual rate itself.
Happy to be proven wrong.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 03-03-2016, 01:16 PM   #6831
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Softer
Harder
Yes, Yokomo includes spring data in the p/n
YOKB7-14600: Black Spring:
Wire dia 1.4mm x 6 coils
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-03-2016, 01:59 PM   #6832
evochick's Avatar
The SMJ short springs feel extremely close to the yokomo springs and have the same turns and dimensions.
There is a chart with their actual ratings here
http://smj-rc.com/products-2/springs/1002-2?lang=en
I dont know if the smj springs have been oemd out to yokomo or not, but will give you a ballpark on their ratings.
Unretired
Old 03-03-2016, 02:15 PM   #6833
CristianTabush's Avatar
Those SMJ Spring rates look about right with what they will measure out, but man, those are some stiff springs. Much like with the XRAY car, I would think this car requires softer, not harder rates than the old car.
Personally, I have liked springs in the 13.5-14.5 range with this car on carpet. Like the new silvers, which the car comes with are the rating equivalent of old HPI silvers, it's like a 15.5-16.0lb spring. I don't know, and I just can't believe this is true, but when I look at some of the Factory set ups recently I almost think they are tuning themselves out on carpet. I am sure this is not the case,definitely know what they are doing but I think that the recent performance from them seem to indicate that they are a bit lost and still trying to learn the new platform.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-03-2016, 02:28 PM   #6834
b20btec's Avatar
I tried the SMJ 2.8 short on carpet at Banana, car felt way too stiff. The Axon 2.8 felt better and was softer on the spring tester. As far as the 3.0 I didn't bother trying it. Ultimately swapped to Axon 2.7 all around in the main.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 03-03-2016, 03:54 PM   #6835
evochick's Avatar
I only race on tarmac, so I really cant comment on the springs for carpet use, but it did seem strange that at the last ETS round some drivers were going as hard as the gold springs.
On tarmac so far most of us have stuck with the kit silvers but when the grip came up at my local track recently I found myself going to the pink fronts. But I think I may have been under dampened (425 AE35) rather then under spring. I just haven't had enough time with the new car.
Unretired
Old 03-03-2016, 03:59 PM   #6836
I am probably going to buy the G-Force Spring Rate Checker tool station.
Anyways anyone building their SLF II short shocks with zero rebound? I did not do any drilling of hole in plastic shock cap but with the shaft in and held in when putting on the bladder and capping it I get a slow full rebound.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 03-03-2016, 04:10 PM   #6837
evochick's Avatar
I can get close but still not 100%, just make sure when you put the bladder on you push down on the center of the bladder with one of your hex drivers as well, as the bladder compresses down a fair bit when the cap is screwed on.
but drilling is the way to go.
Cristian's bladders may be softer as well, but I think there is a greater amount of air in the cap which is also not helping.
Unretired
Old 03-03-2016, 05:03 PM   #6838
I put in the black bladders too. The stock ones these pink silicone ones are too flexy (soft) correct?
Old 03-04-2016, 06:32 AM   #6839
b20btec's Avatar
If you haven't tried drilling you should give it a shot. Before you do so maybe purchase a extra set of shock caps just in case for any reason your car drove worst with drill caps. Its a small investment with major gains.
Soap
Old 03-04-2016, 06:49 AM   #6840
Anyone?
USVTA Member #211
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
(0000000000)
