Like Tree5Likes
Old 02-23-2016, 01:10 PM   #6796
Originally Posted by LloydLoar View Post
I filled this out for a local and figured I would post it here too. The current iteration of my BD7 2016 setup for the new CRC carpet at 5280 Raceway:
http://chrishillier.com/wp/wp-conten...0_feb_2016.pdf
Are you running short front arms or 193mm width?
Josh Hohnstein is offline   Reply With Quote
Old 02-23-2016, 01:27 PM   #6797
Trader Rating: 15 (100%+)
Setup sheet is correct - normal arms with 5.0/5.7 blocks.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 02-23-2016, 05:38 PM   #6798
b20btec's Avatar
Originally Posted by bdmpastx View Post
Damn I need to find a diet for mine.
Your pack is probably way over 300 grams easily.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-23-2016, 05:38 PM   #6799
SLOW 77's Avatar
Trader Rating: 27 (100%+)
Originally Posted by 008-Racer View Post
I have the stock Orca caps stuck on top of the 20g centre weight ;-)
I run my the same way also.
John Hodges
Yokomo BD8 - KOPropo EX-RR -Xray NT1 -Mooreway Motorsports
SLOW 77 is offline   Reply With Quote
Old 02-23-2016, 07:35 PM   #6800
shiston's Avatar
Originally Posted by evochick View Post
mounted to side of speedy sitting above the centre weight is fine,
they don't weigh much
Originally Posted by acutts View Post
Hi guys struggling to find a mounting spot on my bd7 16 for the power caps? Looked at loads pics can't see where they are best being mounted. I am running an orca vx3 speedo and have the 20g centre weight on my car. Is upside down on the top deck good or better attached to the side of the speedo by double sided tape. Any help or pics appreciated thanks
As Evochick said, I just double sided taped it to the side of the speedo on my sons car. I'll try and get a pic up. He's got a VX3 also.
Hang around......we'll talk some more
shiston is offline   Reply With Quote
Old 02-23-2016, 11:42 PM   #6801
Salkin's Avatar
Chris,
What is the overall weight of the car? Mine was at 1422 without any added weight.
I have a hobbywing v3.1 120a ESC, Savox, D4, and intellect 7800mah pack on the aluminum chassis. The Gravity tires and wheels are a bit heavy compared to the Team Powers. So being at 1422 with no weights and you added 70 grams kinda blows my mind.
I add some 60-70 grams depending on tires (Sorex, LRP, Volante) to meet the 1350 grams limit.
Carbon chassis, LRP 5600 LCG lipo, Muchmore Fleta Pro and 5.5T motor, Highest DLP650 direct fit servo, titanium turnbuckles and screws, steel screws in bottom, LTC-R LW body, Sorex 28 tires, Sanwa RX482 reciever, Mylaps transponder, WTF 4x4 motorfan mounted with MR33 fanholder.
What keeps weight down in my car is a very neat wiring setup (absolutely no excess of wires), the LRP lipo (very lightweight) and the direct fit servo, which eliminates the servomount.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 02-23-2016, 11:56 PM   #6802
Default Salkin Take a picture of your wiring if you dont mind
VegasGator is offline   Reply With Quote
Old 02-24-2016, 01:59 AM   #6803
Salkin's Avatar
Here are some photos.
I have cut off the esc switch.
Old 02-24-2016, 09:08 AM   #6804
Just to follow up on this one. I was a little offended yesterday at the intimation that I am either cheating (over-width) or negligent and didn't trust my ability to respond nicely For the sake of clarity, I will explain further.
The car is very narrow with the stock blocks (3.5) - not even close to 190 mm. The 5.0 blocks also only add 1.5 mm (43.5 to 45.0 mm), so I am not even sure where the extra 3 mm you referenced (190 to 193 mm) would come from. With the standard 5.0 hubs and the 5.0/5.7 blocks with normal arms, my car is right around 188 mm.
(Note that Martin Hofer used this same setup at ICC on his 2016. Also note that if the 3.5 blocks made the car 190 mm, almost every setup you can find would be over-width, since everyone seems to be using the 4.2/4.9 combo or wider.)
Old 02-24-2016, 07:15 PM   #6805
RichFox's Avatar
Thumbs up
Like To Chris
RCAmerica l Xray l Hudy l T4 14 l Futaba
RichFox is offline   Reply With Quote
Old 02-24-2016, 10:22 PM   #6806
acutts's Avatar
Thanks for info on mounting power caps peeps got it done as suggested.
I am looking for a chassis fan mount for my bd7 16 any suggestions. I see Marka and samix make but for previous years. Will either of these fit or is there something better out there?
acutts is offline   Reply With Quote
Old 02-25-2016, 05:36 AM   #6807
b20btec's Avatar
The R1 Wurks fan mount is what I use, by far the lightest and your fan doesn't sit on the chassis. Unfortunately it's always sold out at most places, best bet is to contact R1wurks.
The days of taping to the chassis is over for me, although it is still the preferred method, most efficient and cheapest.
Soap
Old 02-25-2016, 06:15 AM   #6808
acutts's Avatar
Thanks but I'm specifically looking for chassis mount and not a mount attached to motor.
Old 02-25-2016, 06:59 AM   #6809
b20btec's Avatar
No problem, here's another option from RSD. I've actually used this fan mount on a BD5, if drilling a hole doesn't bother you.
Fan Mount
Soap
Old 02-25-2016, 08:47 AM   #6810
bdmpastx's Avatar
I used an old aluminum servo mount to mount mine. Worked like a champ.
bdmpastx is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
