Like Tree5Likes
Old 02-12-2016, 01:41 PM   #6736
Anyone know the main difference of the 2 sets of Short Nitride Coated Shafts?
B7-S5ST for SLF Short Shock
B7-S516T for the SLF Short Shock II for the BD7 2016 car
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 02-12-2016, 01:43 PM   #6737
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
B7-S5NT for SLF Short Shock
B7-S5S16T for the SLF Short Shock II for the BD7 2016 car
16 SLF II shocks are shorter than old SLF
B7-S5S16T
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-12-2016, 01:56 PM   #6738
Thanks,
So it sounds like the S5ST is a bit longer shaft and may come in handy on putting the SLF II set on the Tamiya in case I need a bit longer shaft.
I have 2 sets of lower profile shock towers that are made in the UK for this 419 coming and bought the SLF Short Shock II full set.
Also getting a BD7 2016 in the next week or so anyways. Lots of spending going on!
Old 02-12-2016, 05:46 PM   #6739
bertottius's Avatar
Trader Rating: 19 (100%+)
Does anyone have a 2015 BD7 for sale?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is online now   Reply With Quote
Old 02-13-2016, 08:48 AM   #6740
jrmarquez.702's Avatar
Trader Rating: 85 (100%+)
Talking
I just finished my 2016 build, super nice.... There are still a few items I need to get for it though. The car needs a better servo mount..
Anyways, I'll be excited to try it out agains my 2015.
Rite Eye Designz.. Painting Vegas.....
702-373-8205
https://facebook.com/Riteeyedesignz/?ref=bookmark
jrmarquez.702 is offline   Reply With Quote
Old 02-13-2016, 03:00 PM   #6741
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Selling local
-BD7 2016 New In Box
-Yokomo Servo
SoCal RC Market
Racing4Evo is offline   Reply With Quote
Old 02-13-2016, 08:53 PM   #6742
rcejk's Avatar
Trader Rating: 19 (95%+)
Send a message via AIM to rcejk
Wondering if anyone else is having issues snapping or tearing the rear belt on the 16' running mod? I know myself a couple others here locally have snapped a few belts running mod. Previously ran the 15 and had no issues with belts.
rcejk is offline   Reply With Quote
Old 02-13-2016, 08:58 PM   #6743
evochick's Avatar
The mod guys are running their belts tight to mitigate some of the tearing issues. But still a slight problem.
UnRetired
evochick is offline   Reply With Quote
Old 02-13-2016, 09:04 PM   #6744
b20btec's Avatar
Flipped my panaracer pinion around,notice it would rub the belt and catch the set screw.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-13-2016, 09:08 PM   #6745
rcejk's Avatar
Thanks, just find it odd that it's the rear belt only snapping or tearing. I've had the tension tight, slightly loose to see but still doing it regardless. I'll have to stock up on some belts than
Old 02-14-2016, 08:46 AM   #6746
chasingthepack's Avatar
i had a problem on mine where the belt wouldnt sit in the middle of the diffs,i tweaked the adjusters and got them back central again,i didnt use the spring and ball bearing to hold the adjusters i opted for putting a screw in the spare camber link hole and nipped them very lightly,i was told the spring and bearing pinch the adjuster and causes binding in the diff bearings
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 02-14-2016, 09:01 AM   #6747
The Tank's Avatar
I am having the same issue. I'm certain that my rear belt is not touching the spur gear mount screw, as they do not protrude into the pulley at all. With all that said, I'm usually having to replace the rear belt each race day. It's just simply not holding up. Noticeable signs of delamination and shredding after the first run in open modified. I run the belt tension very firm. My only conclusion as to the cause of this, is due to the smaller pulley sizes on the '16 from the '15. The belt simply doesn't have enough wrap around the drive pulley(spur gear pulley) to keep it from skipping under load. Perhaps if the belt was wider, it would have a greater surface area on the pulley and wouldn't skip as often and increase longevity of the belt.
The Tank is offline   Reply With Quote
Old 02-14-2016, 11:07 AM   #6748
rcejk's Avatar
I was able to get maybe 10 runs on mine when it decided to shred the teeth off of them. I did notice that my 3x5m button head screws were protruding some and may cause it but will have to put in shorter screws.
Old 02-14-2016, 11:32 AM   #6749
Just Dremel the spur gear holder screws down a little
Never had a problem ;-)
008-Racer is offline   Reply With Quote
Old 02-14-2016, 04:06 PM   #6750
EDWARD2003's Avatar
For the time I had my BD7 2016, it was great and handled really well. Sadly, I sold my 2016 for something else...
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
