Like Tree6Likes
Old 02-06-2016, 08:22 AM   #6721
Originally Posted by chasingthepack View Post
did you make any changes when you built the diff? mine was very tight after the build,i ran it and it didnt loosen up any so i took the 2 outer shims off and its like butter now ,but i havent ran it to see if it will leak,find out tomorrow,no vid this week?
I did that and it didn't leak, nor the orings got broken
cheapskate.brok is offline   Reply With Quote
Old 02-06-2016, 09:34 AM   #6722
The next 12 days cannot come soon enough for my next pay to buy this 2016 model.
I seen the aluminum/carbon servo mount offered with the kits, was that just some online stores for the initial release only? According to the manual and exploded view of the parts looks like a plastic servo mount.
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 02-06-2016, 11:02 AM   #6723
its offered by a lot of shops.
tomorrow i got my 2016 finally and will be going to ets round 2 aswell to talk to some yokomo guys
Grtz From Belgium
Peterke is offline   Reply With Quote
Old 02-06-2016, 11:33 AM   #6724
chasingthepack's Avatar
i got the alu/carbon mount with my kit,but it came in retail packaging in the box which i thought was odd
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 02-06-2016, 11:58 AM   #6725
evochick's Avatar
Originally Posted by fpart View Post
Can you give me an idea of the feel with the diffs in the high position?
Car was a little less edgie and more consistent on our low grip track. Its a 3 second change so something to try in low grip.
I run the diffs with kyosho p5 o rings without the outer metal shim. No leak and smooth.
Yokomo black 500gob o rings with the outer still in also works.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 02-06-2016, 01:12 PM   #6726
acutts's Avatar
Originally Posted by onroad dude View Post
thanks for the reply. thats kinda what i thought after i was trying them.
How do you do the bumper like this? Are the foam inserts glued? Thanks
acutts is offline   Reply With Quote
Old 02-06-2016, 05:26 PM   #6727
This wide bumper is called Front Upper Bumper Plate Part # is BD-001W. Does this go in between the BD-001 "front bumper" and the B7-001FS urethane foam bumper support? I wouldn't think on top of it as there is the top piece of the BD-001 set.
http://www.amainhobbies.com/rc-cars-...d-001w/p242126
Old 02-06-2016, 05:54 PM   #6728
It goes under the foam
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 02-07-2016, 09:36 AM   #6729
got to race the 16 again today,put the car on track and it was dialled ,didnt change it from the wet race a few weeks back,we started with a wet/damp track which slowly dried out,i was the 1st to stick some slicks on in rd 3 after rd 4 id done enough for pole,2 wins and a 3rd(rd by rd format),won the first a final and 3rd in the second,what made it a better race for me was that 2nd and 3rd ran new tyres for the finals,mine had done 4 runs before the finals,roll on next week,vids will be posted soon,very pleased with the bd7 16
ps 2nd was also a bd7 16 and 3rd was an xray t4 16
Old 02-07-2016, 03:36 PM   #6730
Start building my kit yesterday and then got stuck at the steering bell crank part.
Can someone tell me why a top level competition kit does not include this as standard? i thought it was missing and went back to the store. i ended up buying bd7 '15 bellbrank system. is there a difference between the 15 and the 16?
what does the letter A mean at the end of the part numbers.
jonston is offline   Reply With Quote
Old 02-07-2016, 03:45 PM   #6731
b20btec's Avatar
They stop including the bellcrank and now includes DCJ's. Xray T4 comes with plastic bellcrank and that's a top level kit. The letter A is for aluminum.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 02-07-2016, 05:21 PM   #6732
For 2016 there looks to be a specific one for the Bellcrank Aluminum Set as B7-202SS
Old 02-08-2016, 10:27 AM   #6733
Someone can verify this is needed or you can run the 2015?
XCRAZYBENX is offline   Reply With Quote
Old 02-08-2016, 11:08 AM   #6734
Salkin's Avatar
We use the alu bell crank from the 2015 without issues
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 02-08-2016, 11:43 AM   #6735
Trader Rating: 15 (100%+)
Quick FYI for those running this car on high-bite carpet with softer springs - the front end of this car seems to roll around a lot more than previous BD7 chassis. If you are chasing issues where the car seems to spin out or be tweaked, especially in sharper corners where the car is on its nose, check to make sure your bumper isn't dragging. I never had to trim the underside of my BD7 2015 bumper, but I had to take off huge swaths of my 2016 bumper to get it to stop dragging.
Another PSA is that xray 2.7 springs are very similar to the yokomo blue springs, so if you are having trouble getting the new yokomo springs, try the xray ones in the meantime.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
