Like Tree6Likes
Old 02-02-2016, 01:35 AM   #6706
Chrissy C's Avatar
Thanks evochick, at least its not just my kit then...
But, just to prove I'm not going mad, here is the image from the Mibosport website, it shows the brace, it doesn't mention it in the description, but still a little misleading. Maybe Yokomo had a change of heart as they got up to release? Anyway, it doesn't matter too much, just wanted to make sure I wasn't missing the part.
Chrissy C is offline   Reply With Quote
Old 02-02-2016, 05:12 AM   #6707
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Will the '14 aluminum chassis work with this conversion kit...bulkhead holes and such?
Brian McGreevy is offline   Reply With Quote
Old 02-02-2016, 05:21 AM   #6708
Chrissy C's Avatar
There are others on here better qualified than me to answer this, as I came to the BD7 line at the '15, but from what I have read, I don't think the alu '14 chassis will work due to bulkhead spacing and motor mount differences - I stand to be corrected though...
Old 02-02-2016, 06:23 AM   #6709
mac853's Avatar
Nope, i checked then verified both are different.
But Alu deck of 2014 fits 2013 car.
mac853 is offline   Reply With Quote
Old 02-02-2016, 10:36 AM   #6710
Darn, oh well. I'd look at that 2016 conversion, but I don't want to then spend another $90 on a new aluminum chassis . Hopefully they come out with a conversion with that chassis.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Old 02-02-2016, 04:42 PM   #6711
the 15g balancing weights... does anyone have a photo of how these should fit in the car?
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 02-02-2016, 05:28 PM   #6712
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Note* these weights only work on 2014 and 2013 car. 2015 and up use 10g weights
Racing4Evo is offline   Reply With Quote
Old 02-02-2016, 07:27 PM   #6713
thanks for the reply. thats kinda what i thought after i was trying them.
Old 02-03-2016, 09:29 AM   #6714
mikeygar's Avatar
Trader Rating: 14 (100%+)
had to take a second look to check but this is correct - but you *can* install the 15g weight on the battery side, but you will not be able to tape up the battery since there are no holes on the chassis.
Though when I corner weighted my car, i needed to put 10g on the battery side and the 15g on the servo side so no problem there
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 02-04-2016, 11:41 AM   #6715
dawgmeat's Avatar
Anybody has a setup using the new CRC black carpet for 17.5?
dawgmeat is offline   Reply With Quote
Old 02-04-2016, 12:15 PM   #6716
acutts's Avatar
Guys anyone got a link to spring rates of bd7 springs. I normally run ride blue .287 rate
Are yokomo springs best or is there better option?
acutts is offline   Reply With Quote
Old 02-04-2016, 01:42 PM   #6717
bdmpastx's Avatar
You can use XRay or RSD Springs. both fit the 2016. RSD Has a wide selection and a chart on the page. http://reflexracing.net/RSD-Universa...art_ep_58.html
bdmpastx is offline   Reply With Quote
Old 02-06-2016, 01:31 AM   #6718
evochick's Avatar
Finally got a chance to run the 16 on our lowish traction but very bumpy track last night. Kit setup + 3k diff and the new vilante 32t tyres was very good. Certainly carries more corner speed then the old car.
Also did some testing with a team driver running the longer shocks. But the difference was marginal, so we are all sticking to the short shocks on the very bumpy track. My last change i tried in the final was running the diff and spool in high position. I won the stock final so must have worked
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 02-06-2016, 05:01 AM   #6719
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Can you give me an idea of the feel with the diffs in the high position?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 02-06-2016, 05:57 AM   #6720
chasingthepack's Avatar
did you make any changes when you built the diff? mine was very tight after the build,i ran it and it didnt loosen up any so i took the 2 outer shims off and its like butter now ,but i havent ran it to see if it will leak,find out tomorrow,no vid this week?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
(0000000000)
