Like Tree5Likes
Old 01-15-2016, 06:39 AM   #6616
Chrissy C's Avatar
Hi, if I wanted to use the SLF II shocks on a '15, would I just buy the short towers that were brought out for the '15 and the original short shock set up, or could I bolt the '16 towers on to the '15?
Also, what are the differences between the '15 and '16 bulkhead caps? Is the shock tower mounting point just a little lower? The bulkhead caps are a cross over part I think, so could I combine the '16 bulkhead caps, short towers and SLF II shocks to bring me very close to a '16 set up?
Hope that makes sense!
Cheers all.
Chrissy C is offline   Reply With Quote
Old 01-15-2016, 01:11 PM   #6617
evochick's Avatar
Cheers all.
It will be cheaper to use 15 short towers with the slf2 shocks.
The bulkhead caps are not the same they have made them wider at the tower mount to stop the breakages that the 15 suffered, and subsequently the shock tower mount holes are slightly further apart as well.
So yes you could use 16 bulkhead caps and 16 shock towers but as the bulkheads sit lower on the 16 it will be a fraction too high if you install them on a 15 to use the short shocks. Just use the short 15 towers and the slf2 shocks.
UnRetired
evochick is offline   Reply With Quote
Old 01-15-2016, 01:27 PM   #6618
bdmpastx's Avatar
I think Cristian at RSD is making some shock towers. You may want to ask him about them.
bdmpastx is offline   Reply With Quote
Old 01-15-2016, 06:20 PM   #6619
porsche928gs's Avatar
Cheers all.
I have mine '15 with 15 low shock towers and xray shocks. It works great.
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 01-16-2016, 02:07 AM   #6620
lill question here ..
whats for you the best spend money on option parts in a top 5 on a black-2016 fresh out of the box ?
1:
2:
3:
4:
5:
Greetings From Belgium
Peterke is offline   Reply With Quote
Old 01-16-2016, 03:21 AM   #6621
miller tyme's Avatar
1: Aluminum Diff Cam
2: Ti Screws
3: Ti Turnbuckles
4: Al Nitrite coated shock pivot balls
5: Al Chassis (if you running on med-high traction)
then a few optional toe blocks 4.2 front 4.9/5.7 rear
Ken Miller
RCTarget - Capricorn - Sanwa - Pro Level RC - MAX Power - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-16-2016, 05:37 AM   #6622
2: Ti Screws
3: Ti Turnbuckles
You mean the Aluminum Belt Tension Cam? (1)
Old 01-16-2016, 06:20 AM   #6623
acutts's Avatar
Getting to the end of my build of the BD7 16 and have a couple of questions regarding shocks.
Is it best to build with 0 rebound so put cap on with shaft pushed in?
For low grip outdoor what is a good oil rate to start with?
Any other tips in building the yokomo shocks?
What type of springs do I need to buy as assume the stuff I had to use with trf cars will not fit?
acutts is offline   Reply With Quote
Old 01-16-2016, 06:27 AM   #6624
my friend over at mibosport recommended me this to start .
17,5 blinky shock 400 front, 450 rear and 3000 in the diff?.
don't have my 2016 but wil be starting 450 front and rear and 2000 in the diff and of from there
Old 01-16-2016, 06:28 AM   #6625
acutts's Avatar
Do you have a part number for these?
Found it B7-s8h
Old 01-16-2016, 10:38 AM   #6626
yes, the plastic ones tend to bind the bearings a little when the bulkhead is tightened
Ken Miller
Old 01-17-2016, 02:59 PM   #6627
evochick's Avatar
0.1m shims fixes this
my list would be the following
1: alloy bell crank B7 202SS
2:B7 8DF16 Black shock bladders
3:B7 46616T titanium main gear shaft
4:B7 S8H pivot balls
5: titanium turnbuckles
UnRetired
Old 01-17-2016, 03:50 PM   #6628
EDWARD2003's Avatar
Depending on your track conditions, I've found the kit setup to work really well.
The things I switched out from the kit setup was...
Bladders (use black bladders)
Shock o-rings (use blue o-rings)
Differential gear o-rings (use black o-rings)
Drilled a hole in the shock cap
1 mm spacers on the outer front and rear hubs
2.5 rear toe in
Front end I used 4.2 front and rear blocks
This car has a lot of steering and rear grip. I've found it has too much rear grip (which isn't a bad thing) but you might have to tune some of it out with rear toe blocks or even a heavier rear roll bar.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 01-17-2016, 05:06 PM   #6629
EDWARD2003's Avatar
For those who are still running the BD7 2014. I have a decent setup for 17.5 that's worth trying out. The traction is medium-high and highly recommend x-gear springs for this setup.
Here's the setup.
https://drive.google.com/file/d/0B_Y...ew?usp=sharing
Here's the run. The guy ahead of me is considered the "Samurai" of the track. Rightfully so, this guy is stupid fast in every rubber tire class he enters in.
https://www.myrcm.ch/myrcm/report/en/24470/162777
                 VBC 12M - D08 - FX
Old 01-17-2016, 07:49 PM   #6630
Tiny.24's Avatar
If anyone is still looking for Conversion kits and finding them out of stock I've got 13 in stock. Check out my facebook page options-rc.com. Only 1 Full kit left until the next batch at the end of January. I can't advertise the price but PM me for details or for a quicker response message the FB Page.
Ryan "Tiny" Welch
Overgeared Racing BOD (Facebook - Overgeared Racing)
options-rc.com Trading Ltd. Featuring Yokomo and MOTIV RC (Facebook 0ptions-rc.com)
tiny.optionsrc@yahoo.com
Tiny.24 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
