Like Tree6Likes
Old 01-09-2016, 04:43 AM   #6586
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by acutts View Post
I am using panaracer so really confused as to what it could be
Two things to check.
1. Ensure the bearing holders on the diff and spool, are sitting in their correctly.
2. On the front pulley, ensure you have attached the plate to the correct side of the pulley. (The side wth the dots around it) A quick way to check this is to look at the car upside down and ensure the pulley falls in the centre of the chassis cutout. If not, you know it's the wrong way around.
Nathan
NR is offline   Reply With Quote
Old 01-09-2016, 05:14 AM   #6587
acutts's Avatar
Nathan
Hi Nathan
Just checked both things and they are correct. as soon as the top deck is removed it stops so it looks like it must be something to do with the spur gear holder rubbing the deck maybe, i am going to lightly sand it and shim the spur gear holder so there is no movement side to side to see if that is a solution?
acutts is offline   Reply With Quote
Old 01-09-2016, 06:04 AM   #6588
Moderator
DaveVera's Avatar
Hi Nathan
I had the same issue with both kits i built, the diff pulley gear (front belt) rubs slightly on the top deck. Filed it a touch and it was nice and free again.
Motiv, Gravity RC, Joe Conte Racing ,Blast RC Paint, Sanwa, #~MASAMI~ . ROAR#27050. #FSEARA
DaveVera is offline   Reply With Quote
Old 01-09-2016, 07:51 AM   #6589
acutts's Avatar
Yeah reckon that is it Thanks ..... did you show the diff pulley slightly as there is a bit of side movement?
Old 01-09-2016, 10:38 AM   #6590
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
What RSD springs are being run for carpet medium bite tight track?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 01-09-2016, 11:01 AM   #6591
mikeygar's Avatar
Trader Rating: 14 (100%+)
How is everyone finding the new diff? I built mine and it feels like something is binding. Built my second diff without the outer o-rings and it feels just right. Are you able to get it right following kit instructions?
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 01-09-2016, 12:19 PM   #6592
CristianTabush's Avatar
I am running gold front progressives and now yellow progressive rears. Our track is medium high bite right now, so it should get you in the ball park. If you prefer a less responsive car, perhaps out pink all around or pink F blue rear can do the trick as well.
CristianTabush is online now   Reply With Quote
Old 01-09-2016, 03:19 PM   #6593
evochick's Avatar
There is 2 ways to build an awsome 15 or 16 free diff.
First is to use the black 500gob o rings instead of the red ones.
Second is to use kyosho p5 o rings and leave the outer black o ring but remove the 0.1m outer washer. I have found both work really well and be consistant.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 01-09-2016, 07:29 PM   #6594
EDWARD2003's Avatar
Reflex Racing I would like to buy some bladders for my 2016 ( Clear bladders, right?). Which bladders and other options are worth trying?
Cheers.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 01-09-2016, 08:07 PM   #6595
mikeygar's Avatar
Thanks evochick! Sorry for my ignorance - what are 500gob or rings? My car kept on spinning out on left turns so am trying to isolate the problem :-(
Old 01-09-2016, 10:49 PM   #6596
evochick's Avatar
These ones
http://www.teamyokomo.com/partslist/...bd_500gob.html
You really need to get the diff consistent and free if you are having issues.
Unretired
Old 01-10-2016, 02:22 AM   #6597
acutts's Avatar
Guys just putting the rear assembly together and where the rear hub assembly attaches to the rear suspension arm it feels quite tight. Do you sand the faces to allow these parts to move completely freely? Or will this free up after a few runs?
Old 01-10-2016, 08:22 AM   #6598
chasingthepack's Avatar
yes a very light sanding does the trick,although mine were still a little tight after sanding,(i didnt want to induce slop),i ran the car today for the first time so i will see if it has loosened up some more since
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-10-2016, 08:23 AM   #6599
acutts's Avatar
Originally Posted by chasingthepack View Post
try tapping the arms with a tool forwards and back,if that dont work loosen both mounts and push them away from each other when tightening back up,you should then find the tiny bit of movement in the arm which frees it up
It's the hub assembly in the arm looks like I will need to do a bit of sanding?
Old 01-10-2016, 08:31 AM   #6600
after typing i realised you were talking about the outer pin,post changed to reflect what you said,but yes a light sanding did the trick for me
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
