Like Tree5Likes
Old 01-05-2016, 03:49 PM   #6571
evochick's Avatar
thanks for everyone's setup suggestions, the champ gave me the following setup to try that was working well for him on the weekend. I think the 4.5mm front hex +5K diff + the tyre prep difference will help
My conversion kit just arrived so I must now resist upgrading.......
UnRetired
evochick is offline   Reply With Quote
Old 01-06-2016, 11:57 AM   #6572
reg
Was excited to see the setup🤓........god damn iPad 😏
reg is offline   Reply With Quote
Old 01-06-2016, 12:24 PM   #6573
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
download Acrobat Reader from App Store.
Racing4Evo is offline   Reply With Quote
Old 01-07-2016, 06:51 AM   #6574
Originally Posted by choisan View Post
the rear belt worn is much higher in 16 than 15. anyone has experienced this already?
Also curious...
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 01-07-2016, 12:27 PM   #6575
acutts's Avatar
Is B7 TBS the correct titanium turnbuckle set to fit the bd7 2016 car?
acutts is offline   Reply With Quote
Old 01-07-2016, 01:54 PM   #6576
Racing4Evo's Avatar
Fits all BD7's. For the 2016 you might have a little trouble getting the specified link length with the turnbuckles for the rear sway bar but it works ok on the new car.
Old 01-07-2016, 02:01 PM   #6577
chasingthepack's Avatar
i have my 16 built but havent ran it yet but would like to know which rear blocks give which rear toe in?its kit 3 degree at the mo with the 2.0 fr and 6.4 rear
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-07-2016, 02:41 PM   #6578
evochick's Avatar
Yep you wont need the rear rollbar ones. But Volker was still using them just all the way wound in.
UnRetired
Old 01-07-2016, 04:03 PM   #6579
CristianTabush's Avatar
Each 0.7 change gives 0.5 degrees of toe.
ie: 45.7 at the rr with the 2.0 (42.0) is 2.5 degs of toe in
CristianTabush is offline   Reply With Quote
Old 01-07-2016, 08:55 PM   #6580
Looking into purchasing a BD7 '15 or '16. I can get the '15 from Banzai for just under $300 USD. Is there much of a difference for "on-track performance" between these 2 chassis? It is a lot cheaper than the '16, and still leaves money left over for a motor and tires.
I am a A or B main driver at my local track, used to drive a T4 and a AE TC6.2, sold those to try offroad for a couple years, now want to get back into on-road. My local track is med grip carpet.
ModularGT is offline   Reply With Quote
Old 01-07-2016, 10:07 PM   #6581
Racing4Evo's Avatar
From my own experience and what others at the local track are saying, the 2016 is a HUGE step up from the 2015 just because of drivability. Setup window is larger, car is more consistent; just plain easier to drive. I wouldn't even consider going back to the old car and I'm sure a lot of people will echo that.
Old 01-08-2016, 05:03 AM   #6582
picco007's Avatar
Trader Rating: 87 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
So I have to agree with the above post. I drove the car on asphalt this past weekend. I had much more rear traction, I used the kit springs and the car was decent, changed to RSD springs and the car got better (lap times) but did not feel too much different between the two different springs. So echoing what was just posted as there is a larger set up window. Maybe could be the 4 hole Pistons and etc. and the lower CG. I have two 15's and they are definitely different.
picco007 is offline   Reply With Quote
Old 01-09-2016, 02:22 AM   #6583
acutts's Avatar
Hi Guys busy building my car after moving from Tamiya 419. Seem to be having an issue that when I fit the top deck there is definitely something rubbing when the belts are moved? It seems and only very lightly, it looks like there may be some float in the spur gear holder that just lightly touches the top deck.. has anyone else had this issue?
Old 01-09-2016, 03:45 AM   #6584
Racing4Evo's Avatar
What spur gear brand are you using? I've had this problem with thick spur gears and you just have to find a thin spur gear from Panaracer or similar.
Old 01-09-2016, 04:18 AM   #6585
acutts's Avatar
I am using panaracer so really confused as to what it could be
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
