Like Tree5Likes
Old 12-20-2015, 01:24 PM   #6481
Salkin's Avatar
Originally Posted by evochick View Post
Yokomo have given it a new part number but i cant see what has changed. The 15 one will fit and has the same dimensions.
The '15 diff gasket also fits the new diff, even if there is new part number for the '16 diff gasket. I'm using the '15 diff gasket in a '16 diff with no problems.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 12-20-2015, 01:50 PM   #6482
Svendc's Avatar
Originally Posted by mac853 View Post
Dear for any Yokomo expert:
As i drove from last carpet races with my bd715 then i verified of this car is too much sensitive.
As i didn't drive previous bd7s.
Only through this forum, i concluded the best carpet should be 2014 and asphalt is 2013, isn't it?
Could anyone confirm then comment and explain to me, please?
the most mistakes are stiffen up the front and making the rear to soft, will have a very sensitive car in front.
if the car is to sensitive, try the follow basic things.
softer front springs, at least equal to rear or little bit softer in front.
This make the car softer in corner entry but more steer in mid to exit corner, so less aggressive entry.
remove washers on the steeringrack ballstuds to give less entry steering, less aggresive corner entry.
use at least 2000 to 3000 in diff.
and on some tracks reduce steering on transmitter 90-85% of max steering.
You should have a hole differnt car ;-)
gtz
VBC Wildfire D08
AE B5M CE
Svendc is offline   Reply With Quote
Old 12-20-2015, 03:19 PM   #6483
thanks. i really don't see much of a difference either. the studs are still 8mm apart and the posts are the same distance apart. i havent measured the length of the steering arms yet though but they look the same as the 15 also.
DOTMAN is offline   Reply With Quote
Old 12-21-2015, 02:31 AM   #6484
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by DOTMAN View Post
is the aluminum bell cranks on the 2016 car different from the 2015 car?
Is it possible they are lower height (narrow) on the bearing end than previous vers
Hard to tell from pics ?
16
15
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-21-2015, 02:46 AM   #6485
evochick's Avatar
The steering post part number is still BD-201P7. But it might be a bearing manufacturer change. I know the steering bearings in my old 13/14 kit are much better then the ones in my 15. Who knows really ???
UnRetired
evochick is offline   Reply With Quote
Old 12-21-2015, 06:15 AM   #6486
Plus, in its stock form, the car uses the original BD7 RS bell crank arm and bridge... So I think it's safe to assume they are pretty much the same as the BD7 14-15 parts. Maybe a little modification on how it is machined, or like Evochick said, different bearings.
-- EDIT--
Went through what's included in my conversion kit and there are no bell crank parts included. So I have to assume that the original BD7 14-15 parts are meant to be used with it and are thus fully compatible with the 16 spec car.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 12-21-2015, 06:43 AM   #6487
Damon's Avatar
-- EDIT--
Martin Paradis
only the bell crank bridge isn't the same from '14-'15 because of lower topdeck
so if you want to mount the bridge you must buy the new one B7-201B6, also the plastic one included in the kit (from BD7 RS) can't mount!
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 12-21-2015, 07:37 AM   #6488
Jorge T's Avatar
I've seen 2 built; one with '15 aluminum bell cranks and one with the plastic that comes in the kit, both seem to work.
RSD MS
Jorge T is offline   Reply With Quote
Old 12-21-2015, 08:28 AM   #6489
CristianTabush's Avatar
This is correct, the new car has a lower top deck, so Yokomo will probably offer the bridge as an option part.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-21-2015, 08:44 AM   #6490
All good info. Thanks, guys and gals
Old 12-21-2015, 10:47 AM   #6491
mikeygar's Avatar
Trader Rating: 14 (100%+)
For the guys who've ran their 2016's, what's your spring choice for asphalt? I've read that even the stock silver ones are sometimes too stiff for carpet.
Any feedback?
Manila On-Road RC on Facebook
https://www.facebook.com/ManilaRC
mikeygar is offline   Reply With Quote
Old 12-21-2015, 03:30 PM   #6492
evochick's Avatar
For those that have purchased the conversion kit did it come with the lower 16 belt tensioner or ZC-206LH longer inner ball studs ??
just curious before my kit arrives
UnRetired
Old 12-21-2015, 06:23 PM   #6493
No tensioner
Yes on ball studs
Old 12-21-2015, 07:21 PM   #6494
evochick's Avatar
Originally Posted by RedBullFiXX View Post
No tensioner
Yes on ball studs
UnRetired
Old 12-21-2015, 11:42 PM   #6495
Damon's Avatar
I don't know what you have seen, but I have both versions of BD7, 2015 and 2016, and both versions of bell crank bridges...and they are different!!!
The 2015 version is 18 cm high, 2016 version is 16 cm high, please see the attachments
The plastic bridge in 2016 kit is 18 cm high like the 2015 alluminium version, so it can't mount...it's not a good thing
YOKOMO Touring Car BD-7-20151221_201126.jpg   YOKOMO Touring Car BD-7-12405046_1187842081229162_1578007669_o.jpg
Awesomatix A800
Awesomatix A800X
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
