Like Tree6Likes
Old 11-18-2015, 05:49 AM   #6346
niznai's Avatar
Originally Posted by policeman0077 View Post
How u heat it? With a tourch or hot air gun? Can I boil it in the water?
For such small parts, I would try the trick I used to do on some of lab machinery and use a high power soldering iron applied directly to the aluminium. Keep in mind it might affect the anodising colour. I used to take interference fit pinions off motor drives like that. I guess anything that will heat rapidly and locally is good (with variables).
These days, I would try the freeze and release agent first though. That is also a lubricant. I have had some brilliant results pulling sheared studs out of engine blocks I would have just scrapped in the past.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-18-2015, 07:41 AM   #6347
dawgmeat's Avatar
Pre- Order
http://rcmarket.com.hk/product_info....ducts_id=18045
dawgmeat is offline   Reply With Quote
Old 11-18-2015, 07:59 AM   #6348
I don't have experience with a 13.5 motor but on my 17.5 motor im running 3k diff oil on a carpet track. I've tried 7k and the rear just washes out on power exiting a turn. I've talked to many people they run 3k at my local track.
Originally Posted by EDWARD2003 View Post
Hello! I'm seeking some advice on gear differential oil for high traction (Yatabe Area) with a 13.5 boosted motor.
My current setup is 10k for my low-medium grip track. However, I am a little skeptical that the differential oil might be too hard for high traction surfaces. Where should one start? I have three gear differentials to test.
What oil range should I test within?
3k
5k
7k
Or do you think 10k will be fine?
Let me hear your thoughts and suggestions.
Gel2al2d is offline   Reply With Quote
Old 11-18-2015, 09:11 AM   #6349
dawgmeat's Avatar
Old 11-18-2015, 03:33 PM   #6350
Originally Posted by dawgmeat View Post
Interesting. Alot less mass and less contact patch for the belt. Should help stock classes.
2uzferunner03 is offline   Reply With Quote
Old 11-18-2015, 09:07 PM   #6351
niznai's Avatar
I think the main benefit will be keeping the pinion/spur sizes to planetary dimensions rather than intergalactic.
Thanks, Dawgmeat, that's quite a difference. Might even help me resurrect my old YR4!
Team Greasy Weasel
Old 11-18-2015, 09:20 PM   #6352
evochick's Avatar
As I said earlier, the FDR didn't change so we will all be using the same pinions and spurs,
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 11-19-2015, 12:32 AM   #6353
heretic's Avatar
With a smaller pulley the belts are bent more and you may also have to run your belts tighter to avoid skipping, so I would say it's quite the opposite.
I see no talk of driveshaft/ bone angle with these new diffs position. Anyone has relevant info on the subject?
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 11-19-2015, 07:42 AM   #6354
niznai's Avatar
True, but you can run the older 20 tooth centre to bring down the ratio.
Team Greasy Weasel
Old 11-19-2015, 07:47 AM   #6355
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Questions??
If you feel the need you can try with yours I guess, looks like it would be a tight fit though ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-19-2015, 07:55 AM   #6356
dawgmeat's Avatar
If the Center pulley remained the same then the FDR will change
Old 11-19-2015, 07:59 AM   #6357
niznai's Avatar
If the motor mount is the same, it will take the 20 tooth pulley easily, after all that's how it came back whenever it was invented. But I was thinking of getting the new diffs to use in my old car to lower the ratio, that's why I confused people.
Team Greasy Weasel
Old 11-19-2015, 08:26 AM   #6358
Skiddins's Avatar
If the centre pulley remains the same, but the pulleys change, then different belts will be required as well.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-19-2015, 08:29 AM   #6359
Skiddins's Avatar
I think that picture of the new and old pulleys has been manipulated a little as well, to exaggerate the difference between them.
The old Xray pulleys were 34t as well, towards the end of the T2's lifetime, and I don't recall there being that much difference in diameter
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-19-2015, 08:53 AM   #6360
niznai's Avatar
I have an entire collection I acquired when doing such modifications to my cars to allow me to change the internal ratio. Xray for instance has belts almost at every length you want around the right size (one tooth increments). You can find them on the Xray website in the parts section. There's also a website with the lengths of all the belts available (new or old) on a drifting forum, if I remember correctly.
Team Greasy Weasel
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
