Like Tree6Likes
Old 11-16-2015, 11:43 PM   #6331
JimmyMac's Avatar
The Yokomo BD series have always had 40/20 gears as far as remember. Interesting that they changed it for 2016. Looks like a good car.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-16-2015, 11:51 PM   #6332
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
First BD7 was 13
Still my favorite asphalt chassis
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-17-2015, 12:21 AM   #6333
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by niznai View Post
When did it change? The first BD7 (2014) had 41 tooth diff crowns. Did it change when the new diff came out? That's probably the smallest diff tooth count on the market right now (and seems pretty small at that).
Personally I prefer an irrational internal ratio otherwise you'll have the same tooth and the same belt tooth running in all the time. Something like 19/37. Even these have at some point a common multiple, but in my opinion it's better for longer lasting drive trains.
First BD7 was introduced 2013 and it has always been 40T/20T pulley. Also there are many other brands with lower IDR and smaller pulleys. Not sure where you are getting all of this info...
Racing4Evo is offline   Reply With Quote
Old 11-17-2015, 01:16 AM   #6334
Are you sure it's tightness and not some bonding solution? You might be able to use acetone and let it sit for a while to make sure the bonding agent is dissolved. Or if you want to avoid losing the colour, you can try freeze and release, it's liquid nitrogen in a can. Spray the bearing and it should drop out.
Yes could be some bonding agent too. Acetone would probably harm the blue ionisation. 'Freeze and release' is a brilliant idea though. Didn't cross my mind. I'm sorted now but its good to know for next time. Thanks for sharing.
buzz777 is offline   Reply With Quote
Old 11-17-2015, 02:58 PM   #6335
Default which BD7 to choose
hi,
I`m offroad guy who is going to try my luck at touring cars during the winter
I wish to get used BD7...as Yoko parts are easy to get, but could somebody tell me if its remarkable difference how BD7, BD7-14 Blue and BD7-14 Black editions performs on high grip carpet tracks?
Wish to start with used car- with limited budget for the test car, but if its remarkable difference between those above, then I will try to get best from those.
Any advise is welcome
and if somebody from Europe sell their BD7 I`m waiting your offers at pm.
hardijs is offline   Reply With Quote
Old 11-17-2015, 03:08 PM   #6336
Originally Posted by hardijs View Post
hi,
BD7 13 great for asphalt
BD7-14 Blue and BD7-14 Black edition; these are the same aside from color
With aluminum chassis is great on carpet, 15, 16 should be even better, but 14 is a weapon anyway
Old 11-17-2015, 03:39 PM   #6337
Thank`s a lot for this info!
So I`ll search for BD7-14.
Any offers from Europe are wellcome
Old 11-17-2015, 05:30 PM   #6338
I currently have the '14 bd7 and love everything about it. Good luck on your winter season!!
Gel2al2d is offline   Reply With Quote
Old 11-17-2015, 08:33 PM   #6339
niznai's Avatar
From my own cars. True, I miscounted the diff.
Smaller than a 34 pulley? What are those brands?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-17-2015, 08:36 PM   #6340
niznai's Avatar
There is a risk with freeze and release as well, because the parts being so small, they may shrink equally. The colour shouldn't be affected though.
With heat, you might also try a heat gun, that should be a quick one, but again, I am not sure if the colour would be affected or not.
Team Greasy Weasel
Old 11-17-2015, 08:39 PM   #6341
policeman0077's Avatar
Which one? Cranks or rack?
Never mind, they're all replaceable, you just have to fiddle a bit.
both crank and rack, is there any trick to easily get them off?
多情自古伤离别。更那堪、冷落清秋节。
policeman0077 is offline   Reply With Quote
Old 11-17-2015, 08:42 PM   #6342
They are replaceable but rather hard to remove original ones especially if you do not have a press. They fit tightly! New ones will slip in no problem once you remove the original ones. I had to heat mine to get it off. Be aware once you heat you will loose the blue ionisation colour - it will turn silver! Good luck.
P.S. I changed bearings on mine as I needed a quick repair, but ordered the new steering parts and had them replaced anyway. its up to you though.
How u heat it? With a tourch or hot air gun? Can I boil it in the water?
多情自古伤离别。更那堪、冷落清秋节。
Old 11-17-2015, 11:55 PM   #6343
EDWARD2003's Avatar
Hello! I'm seeking some advice on gear differential oil for high traction (Yatabe Area) with a 13.5 boosted motor.
My current setup is 10k for my low-medium grip track. However, I am a little skeptical that the differential oil might be too hard for high traction surfaces. Where should one start? I have three gear differentials to test.
What oil range should I test within?
3k
5k
7k
Or do you think 10k will be fine?
Let me hear your thoughts and suggestions.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 11-18-2015, 12:04 AM   #6344
Racing4Evo's Avatar
7k 1.2grams.
The volume of oil is just as important as the viscosity. 10k is too thick for most carpet tracks like those with many sharp and 180 deg turns. I used 5k 1.5grams but it takes too long to come up to temp and the handling change is drastic when it does.
I think the new '15 diff is a step backwards from the old BD-5/7 diff.
Old 11-18-2015, 01:46 AM   #6345
daleburr's Avatar
Put them in an electric oven at ~200degC. The alloy will expand more than the steel bearings and the bearings will just fall out. Shouldn't harm the anodizing either.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
