Like Tree5Likes
Old 10-02-2015, 02:41 AM   #6166
skyball's Avatar
Originally Posted by Jerem View Post
I know it's 40mm on the 2013.
My caliper says it's still 40mm on the 2014.
Christian
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 10-02-2015, 05:29 AM   #6167
Christian
Thanks Christian ;-)
Vintage Trans-Am FRENCH Series !
Jerem is offline   Reply With Quote
Old 10-04-2015, 10:21 AM   #6168
xyN
Hey everyone,
did someone of you test a one way in the front instead of spool in the last time?
Im thinking of getting one for 17,5T blinky class.
What do you think?
Greetz xyN
xyN is offline   Reply With Quote
Old 10-04-2015, 03:55 PM   #6169
Originally Posted by xyN View Post
Hey everyone,
What do you think?
Greetz xyN
I haven't used one in this car but just from experience I would only use one on a large track with large sweeping turns.
2uzferunner03 is offline   Reply With Quote
Old 10-04-2015, 05:39 PM   #6170
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
What's the difference between the db7 and db7 rs? Is it worth just buying the db7?
Are there any mandatory upgrades necessary?
Thx
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-04-2015, 06:11 PM   #6171
EDWARD2003's Avatar
Originally Posted by Racing4Evo View Post
Edward2003-
This is also because you are using too thin of an oil. Go up much higher in viscosity and use less oil. The operating temperature of the diff is much higher than bench testing so you will have to do a little trial and error on the feel that you are pursuing. A warm diff will be a more accurate indicator of diff action. Generally people prefer 5k-7k these days.
I did quite a bit of testing and found 10K work out really nice for 13.5 boosted on a tight and technical track layout.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 10-04-2015, 06:22 PM   #6172
EDWARD2003's Avatar
Here is the setup I ended up testing out with great success. The setup isn't mine. Keep note of the ball studs which are short necks.
Remember this is for 13.5 boosted on a tight technical track layout with medium grip.
Sorex 28's, Sweep blue inserts, and SAI 5 spoke wheels. <--- These wheels added some flex, dish were to stiff.
https://drive.google.com/file/d/0B_Y...ew?usp=sharing
                 VBC 12M - D08 - FX
Old 10-04-2015, 08:29 PM   #6173
OriginalDonk's Avatar
Trader Rating: 38 (100%+)
The first photos of Yokomo's new 4wd offroad buggy, the YZ-4, have reached the internet. They are touting a revolutionary drive train. I'm still unsure if any of this has any bearing on the next few BD's, whatever never or letters are associated with them.
OriginalDonk is offline   Reply With Quote
Old 10-05-2015, 02:21 AM   #6174
DirkW's Avatar
Thx
Sorry, but it's BD7, not DB 7 (that's an Aston Martin)
The RS versions are lower level (in pricing) and usually have plastic in many places where a full BD7 has carbon or aluminium. The first RS really had lots of plastic, and Yokomo offered IIRC 3 different upgrade packages. The newer versions, RS2 and RS3 have carbon chassis and damper mounts, etc. - I don't see that much plastic left in them... lower bulkheads probably. But the price went up quite a bit as well.
Oh and the RS3 comes with black anodized aluminium and 2014 parts, where the RS2 comes with blue parts and should be 2013 parts IIRC.
So unless we're talking about the original RS, I can't think of any mandatory upgrades - of course one can even upgrade the full BD7 kits further, but I wouldn't call that mandatory (even though most people seem to change damper bladders and o-rings for example).
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 10-05-2015, 03:29 AM   #6175
Thx
Upgrades you'll need is an aluminium spool. Every BD7 spool will fit. The standard plastic spool with plastic outdrives will break fairly quick.
Another thing I would personally do is change the diff outdrives to ones that use blades. The RS version has steel on steel contact. So buy some outdrives from the normal BD7 version and some blades and you are fine.
The RS is more than excellent. I have build quite a few and RS2 version as well. Yokomo quality and the build is excellent. Even the plastic dampers are butter smooth!
Govert is offline   Reply With Quote
Old 10-05-2015, 04:29 AM   #6176
Hi,
Here my "Lipo Stopper" for BD7, BD7 Rs & BD7 2014 !
http://shpws.me/Kj0v
Old 10-05-2015, 06:40 AM   #6177
teeforb's Avatar
Got it! Thanks. So no upgrades needed on the bd7 and rs3 version! Cool
Old 10-06-2015, 09:02 AM   #6178
Need a little help on front dcj's ......... Ive got 40mm ones in mine but I need 42mm lengths.
Working on a hybrid using my '14 and need a little extra in the outdrives. Anyone know of another kit that would work or if Yokomo has an inner shaft to the cup I could use?
Robbob is offline   Reply With Quote
Old 10-06-2015, 11:18 AM   #6179
Tamiya axles fit the knuckles. Not sure what length bones they come in.
Old 10-06-2015, 11:37 AM   #6180
That helps too - thanks
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
