Like Tree5Likes
Old 08-19-2015, 11:26 PM   #6061
Trader Rating: 23 (100%+)
Originally Posted by CLovely View Post
Hi guys, ever so often I freshen up the diff oil.
And when I do this I like to replace o rings and the gaskets
Is there a cheaper alternative for the gaskets, as the yokomo ones only come one in a packet, and it becomes expensive
How often are you replacing the gasket? They're $2 or less ea so unless you're replacing them every week or something, its not too bad.
I would replace them every 2 months or so, the new 2015 diff is pretty good, doesn't leak
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 08-19-2015, 11:53 PM   #6062
EDWARD2003's Avatar
If the differential is leaking around the gasket area then replace the gasket. I'm still running on the same gaskets from when I bought my BD7 '13.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 08-20-2015, 12:01 AM   #6063
EDWARD2003's Avatar
I had some free time and did some modifications which you can do with your BD7 at home.
First modification - steering cross brace.
The kit steering cross brace was designed to connect the upper deck and provide support for the two steering arms.
However, most drivers remove this part in order to gain more steering in the front end. This gain in steering has now left the steering arms without any proper support. It's not necessarily a big deal if you leave it off, but it doesn't hurt to put it on.Now, many aftermarket companies have come out with carbon fiber braces which add support for the two steering arms.
I figured doing this modification would save me a few bucks. If I don't like it I can always throw it back into my parts box. lol
It took me 5 minutes to do with a hacksaw and a file.
                 VBC 12M - D08 - FX
Old 08-20-2015, 08:23 AM   #6064
Are the steering bell crank bearings removable?
Mine are pretty rough but still functional. I don't want to destroy an expensive still functional part if they can't come out.
2uzferunner03 is offline   Reply With Quote
Old 08-20-2015, 08:24 AM   #6065
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Thats a clean job.
Running without the screw through the upper deck gives the same feel as what you did. It is different though than running without the brace entirely. There are 3 options, all of which give you different steering feel:
-run the brace with the top screw
-without the top screw
-remove the brace entirely.
Racing4Evo is offline   Reply With Quote
Old 08-20-2015, 09:11 AM   #6066
Korey Harbke's Avatar
I usually put them in the oven for a bit at 350 deg F, and let them warm up for a little while. The aluminum will expand more than the steel and loosen up the fit of the bearing enough so they just drop out.
For putting new bearings in, I just put them in the freezer for 20 min to get them cold, and drop them into the heated aluminum parts. and let them cool naturally.
I've done this on other cars, but not the Yokomo stuff yet. Might be worth a try to save some $$$$. Just remember to wear some gloves (I used mechanics gloves I use for working on my full size race machine).
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-20-2015, 03:01 PM   #6067
Buys carbon trunklid with APR wing and KW V3s, thinks he has a race car.
-Mike
Old 08-20-2015, 03:20 PM   #6068
That was referring to the BMW touring car I work on :P
Old 08-25-2015, 09:27 AM   #6069
Anybody here running an alloy chassis? Need some setup advice for a small technical carpet track with about 9 second lap times.
I'm running the 14 bd7 with radtec chassis. I've only ran the cf chassis before and haven't strayed far from the regular carpet setup. Should I just leave that setup on it? Thanks
Old 08-27-2015, 06:04 PM   #6070
EDWARD2003's Avatar
BD7 differential build (My Method)
https://www.youtube.com/watch?v=vIQL3bS_12I
Lightweight screws on the top deck.
https://www.youtube.com/watch?v=kp-AD9rhwms
BD7 axle modification.
https://www.youtube.com/watch?v=iPfaOQSqLi8
Improving BD7 drive train efficiency.
https://www.youtube.com/watch?v=uRyjmbgDRXY
Square RC ball cup wrench specifically for BD7 and 4.3 ball cups.
https://www.youtube.com/watch?v=_8-uaaCgV_I
                 VBC 12M - D08 - FX
Old 08-28-2015, 06:34 AM   #6071
Bar
Cool videos, how do the Much More shock o-rings compare to the Yokomo blue ones, the Yokomo ones don't have a number on so was quite curious how they compare in hardness, I also see Hpi do some as well?
Luke Burr
Bar is offline   Reply With Quote
Old 08-31-2015, 10:53 PM   #6072
EDWARD2003's Avatar
I'm not to sure about the Yokomo ones. I think they would be a 40 or 50. 60 is stiff. I haven't track tested the o-rings yet. I'll let you know.
                 VBC 12M - D08 - FX
Old 09-01-2015, 02:27 AM   #6073
Salkin's Avatar
Just replaced an Xray T4'15 with a BD7 2015.
On the Xray's a very commonly used tuning option is to run 1mm shims under the topdeck to allow for more flex, and run with various mm shims on the shock mounts, placing the shock further in or out on the tower/arm.
I cannot see that this is used on the BD7. Has anybody tried this on the BD7 ?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 09-01-2015, 05:21 AM   #6074
Bar
Cheers that would be good to know
Luke Burr
Old 09-01-2015, 02:14 PM   #6075
Interesting decision. What made you decide to "upgrade" - especially when the new models are likely so close?
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
