Like Tree5Likes
Old 08-15-2015, 02:43 PM   #6031
The towers do fit, but the towers are held by 2 screws, not 4
tiny tom is offline   Reply With Quote
Old 08-16-2015, 06:11 AM   #6032
AL1983's Avatar
Thx everyone for answering the short shock conversion set question.
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 08-16-2015, 06:48 AM   #6033
DirkW's Avatar
Default FDR range 13.5T blinky?
I'm planning to race 13.5T blinky with BD7'15 (ORCA TX motor)
What FDR range should I aim for when choosing a spur gear (I will buy a whole range of pinions that fits, since it's much less hassle to change pinion than it is to change spur)?
I know the specific FDR depends on the actual track I'll be running on, but between large flowing outdoor asphalt tracks and technical indoor carpet tracks, what is the maximum/minimum I should need?
Would a range between 4.2 and 6.2 be sufficient? Or should the min be lower / max be higher?
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Yokomo YR-10F | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17| Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is online now   Reply With Quote
Old 08-16-2015, 06:59 AM   #6034
niznai's Avatar
You can't really cover that range with one spur only. The adjustment of the motor is not that much and some ratios just jump too much changing pinions. You'll find soon that another spur (or a few) are needed. In actual fact, changing spurs allows a finer adjustment than changing pinions.
For our track for instance (large outdoor asphalt) we are in the low 3 to 3.5 FDR.
Here's Yokomo's gear chart that shows clearly you're not going to cover that range with a single spur
http://www.teamyokomo.com/download/m...7_gear_48p.pdf
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-16-2015, 07:10 AM   #6035
DirkW's Avatar
That's 48dp. Naturally the gearing jumps would be bigger there.
I'm using 64 dp, and the Yokomo chart for that actually shows the numbers I gave (ok, 4.200 to 6.176 to be precise) for a single spur (105T). And the steps are reasonably small in 64 dp as well, IMO.
Dirk
Old 08-16-2015, 04:33 PM   #6036
Trader Rating: 23 (100%+)
On a track with about 50m straight, we run FDR of about 4.0 - 4.7. I have a BD7 15 and use a 78 spur 48dp
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 08-16-2015, 05:00 PM   #6037
AL1983's Avatar
Hi,
I use 96 or 99 teeth spur 64dp (panaracer). Pinions between 41-46. Depends on track and motor.
Old 08-16-2015, 05:06 PM   #6038
evochick's Avatar
For 13.5 you realistically only need 2 spurs, a 96T which is readily available and a 97T to give you some in between ratios.
I usually carry pinions from 46 to 56, this gives me a good range, from high speed outdoor tracks to small indoor tracks. 4.1 to 3.4 should be enough range for an Orca TX, but you may need to go lower on really small tracks, which you still can do with the 96T spur.
I love forums, ask one question get 3 different answers
UnRetired
evochick is offline   Reply With Quote
Old 08-16-2015, 06:05 PM   #6039
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
This is solid advice. My only thing is that I keep pinions from 43T-52T. Anything bigger than 52T pinion is a chore to put on and take off.
Racing4Evo is offline   Reply With Quote
Old 08-17-2015, 01:54 AM   #6040
DirkW's Avatar
Really? That's an FDR of 3.8-4.2 That looks like the range people usually advise around here for 17.5T and even 21.5T, wouldn't that cook a 13,5T ?
Dirk
Old 08-17-2015, 02:14 AM   #6041
evochick's Avatar
Nope i usually ran the 13.5 orca at about 3.7- 3.8. The d3.5s we would usually turn down past 3.4 on a big track, d4 1s 3.8-4.
I use a R1 fan at full voltage to keep temps down.
UnRetired
Old 08-17-2015, 04:04 AM   #6042
J.Mackie's Avatar
Yes here is AUS we are crazy. I have used ORCA for the last few years and yes i run about 3.7 fdr in 13.5 with TX motor for bigger tracks a bit lower for more speed motor reaches 83 which is what I am advised to stop at.
AWESOMATIX/FANTOM/HIGHEST
J.Mackie is offline   Reply With Quote
Old 08-17-2015, 05:58 AM   #6043
niznai's Avatar
I read "outdoors" and didn't even consider 64p as an option.
Still don't.
Team Greasy Weasel
Old 08-17-2015, 08:02 AM   #6044
DirkW's Avatar
Still don't.
Guess people are just different. Fair enough.
I on the other hand have never used anything but 64p for onroad. (Never had any problems with it either, not even outdoors.)
So for me it is not only an option, it's pretty much the only option.
Ok, so for FDRs in the 3.x range, I definitely need a smaller spur. Thanks.
Dirk
Old 08-17-2015, 09:01 AM   #6045
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Haven't run 48p since I was new to the hobby
Never an issue with 64p
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
