Like Tree6Likes
Old 08-06-2015, 08:40 PM   #6016
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
This car weighed 1385 at Reedy race...
Racing4Evo is offline   Reply With Quote
Old 08-06-2015, 08:45 PM   #6017
Originally Posted by Racing4Evo View Post
This car is 1381 with body. 50g added weight.
do you have the fan blowing on the motor or extracting air from the motor?
and if so why?
BruceCampbell is offline   Reply With Quote
Old 08-06-2015, 09:00 PM   #6018
Racing4Evo's Avatar
always blowing on the motor. There is not enough ventilation under a body to have extraction work well.
Old 08-06-2015, 09:40 PM   #6019
Trader Rating: 23 (100%+)
Thanks guys, i'll make some changes n hopefully cut out some weight. Just a question, how do you mount the fan onto the chassis without a bracket? Just using some servo tape? Will it fall off in a crash event?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 08-06-2015, 09:41 PM   #6020
id too like to know this is have so wrecked 2 fans when crashing as they tend to fly off
Old 08-06-2015, 09:53 PM   #6021
evochick's Avatar
Use 3M scotch heavy duty exterior double sided tape, and clean the surfaces with an alcohol wipe before applying,
I have actually broken fans trying to remove them with this tape, its super strong.
UnRetired
evochick is offline   Reply With Quote
Old 08-06-2015, 11:37 PM   #6022
I use a bracket works fine and doesn't have much weight.
DamianW is offline   Reply With Quote
Old 08-07-2015, 04:06 PM   #6023
tbrymer's Avatar
I just shoo goo it and it holds fine.
CRC - C&C Motorsports - SpeedZone
tbrymer is online now   Reply With Quote
Old 08-14-2015, 03:11 PM   #6024
Originally Posted by LloydLoar View Post
This is incorrect - the shorter arms should free up the car. I wouldn't recommend only using short arms on one end of the car - it will make the car feel broken.
Think about the length of the 'lever' that is exerting force on the tire with a longer lower arm vs. a shorter lower arm. Same shock position, same spring, but with a shorter lever (inboard mounting location is moved outwards.)
If you really want to feel a huge difference, try going short shocks and short arms...
Yep tried that tonight at a club meeting, started out with a yellow spring in the front, went back to a pink, blue in the rear. 42.5wht alround, but was leaning the rear shocks over to soften the rear so it didn't break away. But that car turns in a hell of a lot. But drives really nice
tiny tom is offline   Reply With Quote
Old 08-15-2015, 05:54 AM   #6025
AL1983's Avatar
Hi,
Does the short shock conversion kit B7-2014SS fit the 2015 model? I want to know if the shock towers fit the 2015 BD7.
Thx anyone for replying!
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 08-15-2015, 06:38 AM   #6026
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by AL1983 View Post
Hi,
Yes
2015 Parts List HERE
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-15-2015, 07:28 AM   #6027
Originally Posted by RedBullFiXX View Post
Yes
You might want to get a second opinion on that. I remember trying to fit my '14 Short Towers on my '15 with no success.
Now a '15 part Short Tower on a '15 yes.
MDawson is offline   Reply With Quote
Old 08-15-2015, 07:42 AM   #6028
You bring up a good point
The B7-2014SS14 Short Shock conversion set does not have towers
And the Yokomo parts guide is a bit confusing on that
Attached are the correct 15 SST Fr & Rr
YOKOMO Touring Car BD-7-15ssc.jpg   YOKOMO Touring Car BD-7-fsst.jpg   YOKOMO Touring Car BD-7-rsst.jpg
Old 08-15-2015, 09:41 AM   #6029
Anyone here using the yokomo suspension block spacer kit instead of shims? I have to manually set the slop in the arms no matter what shims I put in.
It's like the screw holes in the chassis are larger than the screw so you have to tighten it down in the perfect spot. This is on the ff and rr suspension mounts. Not sure if that's how it comes as I got it used. It seems like the spacer kit with the bridged spacer would be easier to set. Any feedback is appreciated.
2uzferunner03 is offline   Reply With Quote
Old 08-15-2015, 09:48 AM   #6030
Korey Harbke's Avatar
Hi,
The B7-2014SS part number comes with the short shocks, and short towers suitable for the 2014 spec car.
The 2015 towers are to accommodate the attachment without the locating pin feature that are on the 2014 car.
If you purchase the B7-2014SS set... use the shocks, toss the towers and get:
B7-01715S Short Shock Tower 2015 Front
B7-01815S Short Shock Tower 2015 Rear
Otherwise you can purchase B7-2014S which is just the SLF Short shocks with no towers and purchase the 2015 towers.
Hope that helps!
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
