Like Tree6Likes
Old 08-02-2015, 09:08 PM   #5986
evochick's Avatar
Here you go. I installed the esc cap on top of it to get it out of the way.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 08-02-2015, 09:10 PM   #5987
cheer did you find it made a difference on low grip tracks
BruceCampbell is offline   Reply With Quote
Old 08-02-2015, 09:40 PM   #5988
evochick's Avatar
not really, my car is very underweight and needs 50g to get it up to weight, so I had to put it somewhere.
Unretired
Old 08-03-2015, 06:29 AM   #5989
Stuff Of Legend's Avatar
Talking
Originally Posted by LloydLoar View Post
This is incorrect - the shorter arms should free up the car. I wouldn't recommend only using short arms on one end of the car - it will make the car feel broken.
Think about the length of the 'lever' that is exerting force on the tire with a longer lower arm vs. a shorter lower arm. Same shock position, same spring, but with a shorter lever (inboard mounting location is moved outwards.)
If you really want to feel a huge difference, try going short shocks and short arms...
Full disclosure the purpose of asking how the short arm conversion affects the handling separately is because i use Nitro foam tires 26mmF/30mmR , and i am looking for more front end traction/side bit.
Stuff Of Legend is offline   Reply With Quote
Old 08-03-2015, 07:02 AM   #5990
The One They Call Dirty's Avatar
Trader Rating: 57 (100%+)
Default Indoor Carpet Question
So I'm a few weeks out from starting to run on the rug, and I had a few questions regarding running on carpet. I've seen alot of people talking about the aluminum chassis on carpet, but to my knowledge there's 4, Yokomo, Excellab, Samix, and Radtec. Has anyone tried more than one on this list and have an idea on which is better for what reason?
I've also heard/read about guys running short arms and short shocks on carpet, is there any advantages to doing so?
FYI, running 17.5 and 13.5, I'm sure it'll make some kind of difference.
Chris Sanchez, Chicago, IL
92zero Designs - Diggity Designs
Fantom Racing - Fenix Racing - Hobbywing
Lunsford - MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 08-03-2015, 12:21 PM   #5991
bukil's Avatar
Trader Rating: 39 (100%+)
Does anyone have the toe chart for the short arm suspension conversion?
Thanks!
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 08-03-2015, 01:07 PM   #5992
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-03-2015, 02:05 PM   #5993
bukil's Avatar
Originally Posted by RedBullFiXX View Post
Thanks Dave!
☆ ActivRC ☆
Old 08-03-2015, 03:22 PM   #5994
Default traction on outdoor asphalt
so other than shorter arms and maybe some ballast weight for low grip outdoor asphalt in winter were the track surface temp is about 10-15deg and no sugar water is used
Rex34's I don't think have a low enough temp rating and literally cool off within 2 mins being on the track.
I have also removed the sway bars
Old 08-03-2015, 08:09 PM   #5995
EDWARD2003's Avatar
Well my lightly used BD7 '13 chassis is tweaked. On the left rear it's 0.4 mm and right front is 0.2 mm. I'm kinda scratching my head as to why this has occurred. I haven't hit anything hard and I've only broken a front left hub carrier.
I guess it's time for a new chassis plate.
Has anyone swapped out the stock chassis for an aftermarket version?
Samix, Smokem?
Aluminum or carbon fiber ?
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 08-03-2015, 08:14 PM   #5996
Originally Posted by EDWARD2003 View Post
Well my lightly used BD7 '13 is tweaked. Time for a new chassis plate. Has anyone swapped out the stock chassis for an aftermarket version?
Samix, Smokem?
What is tweaked ?
Been racing a 13 inside and out for a few years now, still perfect on scales
Old 08-03-2015, 08:40 PM   #5997
evochick's Avatar
When you tightened the top deck down did you do it on a flat surface with something like this pushing down on the shock towers ??
http://www.muchmoreracing.net/produc....php?pidx=1094
you don't need anything this fancy, but I always make sure I am pushing down on the shock towers as I tighten it up. If you don't, just the tension on the front belts can cause the chassis to twist.
Edit: I always check this after every run regardless if I hit anything or not, as on the yokomo there is some play in the topdeck holes to allow it to be aligned without any tweak.
Unretired
Old 08-03-2015, 09:35 PM   #5998
EDWARD2003's Avatar
The video below shows the chassis tweak.
https://www.youtube.com/watch?v=tpLs4t98Mxs
evochick - Yes, I do all of the above to untweak my chassis.
                 VBC 12M - D08 - FX
Old 08-04-2015, 07:10 AM   #5999
Trader Rating: 23 (100%+)
How heavy is your car in race trim? I have 30g of ballast to balance out the car and mine is almost 1440g race ready
Zhangesh is offline   Reply With Quote
Old 08-04-2015, 08:44 AM   #6000
Thumbs up haha!Got u
Originally Posted by Nuno Gancho View Post
Tried to have front link in longer position but they hit the spool only solution I see is raising a lot with shims is that correct.
Haha!Got u!
Eric_Choi is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
(0000000000)
